Creative Design Problem -- Thanks ALL!
Thank you everyone for the outstanding input to the water bowl design
problem! The question was "how do u detect water level for a full or empty
bowl".
There were SO many ways to do it, and after reading everyone's idea, I stumbled
upon an incredible and simple approach.
I constructed a small circuit composed of one capacitor and 2 resistors,
similar to the circuit given for RCTIME in the manual. But what I did was to
intentionally create an open circuit between the resistor and ground. We all
know
current doesnt flow in an open circuit. I placed the open part of the circuit
into the top level of an empty water bowl and told the microprocessor "if
current =0, then water is empty"
Now when the water begins to fill, guess what happens? The water rises and
then touches the open in the circuit. The amazing thing is that the water
actually completes the circuit! Water is actually behaving like a high
resistance
conductor. At this point current is not zero, because there is now a current
running from the circuit, in through the water, and then back to the circuit.
I wouldnt recommend this approach for determining fuel level though. I dont
know about you guys, but i wouldnt want to ride in a car whose fuel gage
operates by running a small current through gasoline [noparse]:)[/noparse]
bowl".
know
resistance
cars actually are variable resistors with a float on the wiper. The wire
wound resistor element is usually in the fuel and current does run through
it. This is a voltage divider and the gauge just responds to the change in
resistance.
jim
http://www.geocities.com/jimforkin2003/
From: MP1428@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=E-E_2pjGV1vnxD0CTjmyq-DaHOKIMLOBUnQO1_Z9leSe8zDEoOm3DSUPsiv_h9LKGFvgj6hE]MP1428@a...[/url
Sent: Monday, October 13, 2003 9:52 PM
Subject: [noparse][[/noparse]basicstamps] Creative Design Problem -- Thanks ALL!
bowl".
stumbled
know
circuit
resistance
circuit.
jjf@p... writes:
Just a bit of information for you. Most fuel gauge sender units used in
resistance.
True for the fuel gauge, but not for the low fuel warning lamp. The low fuel
indicator lamp is completely independent of the fuel gauge circuit on MOST
cars.
Ken
MP1428@a... writes:
Got news for you, the fuel gauge with current in it is immersed in
gasoline......see the post by JIM. His description is spot on!!!!!!!!
some of the low fuel level lights are turned on by wound aircore
capacitors whose capacitive reactance is measured.
--- smartdim@a... wrote:
> In a message dated 10/13/2003 6:55:26 PM Pacific Daylight Time,
> MP1428@a... writes:
> I dont
> gage
> Mike
> and Body of the message will be ignored.
__________________________________
Do you Yahoo!?
The New Yahoo! Shopping - with improved product search
http://shopping.yahoo.com
sensor was a wire-wound potentiometer thingie right down in the gasoline
with the float-arm moving the contact. Even back then it was a little scary
to contemplate what would happen if that nichrome wire wore through and
sparked when the contact bridged the gap. I've never heard of a fuel tank
explosion from that sort of thing, except for perhaps TWA Flight 800.
Food for thought, isn't it?
Mike Sokol
www.modernrecording.com
mikes@m...
" One should not increase, beyond what is necessary,
the number of entities required to explain anything"...
-William of Occam-
Sent: Tuesday, October 14, 2003 11:05 AM
Subject: Re: [noparse][[/noparse]basicstamps] Creative Design Problem -- Thanks ALL!
> MP1428@a... writes:
dont
> Mike
hear or read about Flight 800.
> tank
> Mike Sokol
> mikes@m...
> -William of Occam-
> From: <smartdim@a...>
> > MP1428@a... writes:
> though. I
> dont
> gage
> > Mike
> on!!!!!!!!
> Subject and
Do you Yahoo!?
