Timing in a BS2 app
I'm involved in a project where we know there will be a lot of experimentation
and "on the fly" changes. Except for a few applications with a BS1 I'd consider
myself pretty new to PBASIC.
I have a BOE and a Stamp Modem board. The project involves taking some ADC
readings and watching how often a motor is run. Essentially what happens is I
need to count how many seconds the motor runs. This value is accumulated until
the temperature exceeds a certain value. Once that happens the modem board is
used to call a PC and transfer the data.
I come from a microcontroller background so all the ADC stuff, modem dialing,
etc. seems pretty straight forward. I'm sitting here this evening wondering how
to accumulate the motor run time?
There's an opto device that gives me a logic high when there's 120 VAC on the
input. I essentially need to poll this input to the Stamp and count the number
of seconds it's active. Too many years having timer interrupts and lack of
experience with PBASIC have me puzzled. At this point high resolution timing
isn't critical. If the motor runs for 78 seconds and I report it ran from 75 to
80 that's perfectly acceptable for proof of concept.
Suggestions?
Tim
Suggestions?
Tim
>experimentation and "on the fly" changes. Except for a few
>applications with a BS1 I'd consider myself pretty new to PBASIC.
>some ADC readings and watching how often a motor is run. Essentially
>what happens is I need to count how many seconds the motor runs.
>This value is accumulated until the temperature exceeds a certain
>value. Once that happens the modem board is used to call a PC and
>transfer the data.
>dialing, etc. seems pretty straight forward. I'm sitting here this
>evening wondering how to accumulate the motor run time?
>VAC on the input. I essentially need to poll this input to the Stamp
>and count the number of seconds it's active. Too many years having
>timer interrupts and lack of experience with PBASIC have me puzzled.
>At this point high resolution timing isn't critical. If the motor
>runs for 78 seconds and I report it ran from 75 to 80 that's
>Suggestions?
>Thanks,
>Tim
For the proof of concept (until springing for a real time clock
chip), you can do something like the following
DO
DO
' read adc
timer = timer + motorState ' <-- by calc to keep loop time
state independent
IF temperature>threshold THEN EXIT
PAUSE 990 <--- adjust this value empirically to get
good approximation
LOOP
' stuff to do with modem etc. to relay timer seconds
LOOP
enamored with interrupts, programmers used to trace their code paths,
counting cycles and could do accurate timing and measuring. I used to
work in the irrigation industry building sprinkler timers, and this
process is still used on small (four-bit processor!) models.
Can it be done in the BASIC Stamp? Yes, in a way -- I did it for a
product that I developed for my previous employer. Of course, you can't
count cycles. What I did is use a spare pin as an indicator and a scope
to measure the paths through my code. I was able to the 0.1 sec
accuracy on a four-channel alarm device. In the micro world, 100
milliseconds is forever, but in the *real* world it far exceeded the
requirements of that application.
PBASIC is designed well for state-machine applications. The framework
for most of my apps looks like this:
Main:
DO
GOSUB Real_Important_Task
ON state GOSUB Task1, Task2, Task3
LOOP
In my alarm application I padded the routines such that any state would
cause the "Main" loop to run at 100 milliseconds. My "Real Important
Task" was monitoring inputs -- I simply added the value of the input,
then multiplied, like this...
counter1 = (counter1 + C1in) * C1in
If the input was one the counter was incremented; if zero the counter
was cleared. The next step in my system checked counts and directed the
proper task (by setting the variable state).
I hope that some of this helps you with your application.
-- Jon Williams
-- Dallas Office
From: Tim McDonough [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=BKvnc1sxAx9X3gCIB8QcpOz3Fmo0q2jOEmZfBRXBxok6afkYSRtwzP1l-4hAazcFtLRh1SD9UiqNyg]tim@m...[/url
Sent: Monday, October 13, 2003 6:59 PM
Subject: [noparse][[/noparse]basicstamps] Timing in a BS2 app
experimentation and "on the fly" changes. Except for a few applications
ADC readings and watching how often a motor is run. Essentially what
happens is I need to count how many seconds the motor runs. This value
is accumulated until the temperature exceeds a certain value. Once that
happens the modem board is used to call a PC and transfer the data.
on the input. I essentially need to poll this input to the Stamp and
count the number of seconds it's active. Too many years having timer
interrupts and lack of experience with PBASIC have me puzzled. At this
point high resolution timing isn't critical. If the motor runs for 78
seconds and I report it ran from 75 to 80 that's perfectly acceptable
Suggestions?
Tim
Your use of Yahoo! Groups is subject to
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
When using the input update or clear thing that I describe below, it's
probably faster to do it with the & operator:
counter1 = (counter1 + C1in) & C1in
-- Jon Williams
-- Parallax
Sent: Tuesday, October 14, 2003 8:33 AM
Subject: RE: [noparse][[/noparse]basicstamps] Timing in a BS2 app
Back in the "dark days" [noparse][[/noparse]being facetious] before everyone become so
Main:
DO
LOOP
-- Jon Williams
-- Dallas Office
From: Tim McDonough [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=nbW9R0u5r31BzozglNhVRrmHAeXfBTaX2FNnly8WAnJA-tImqKJeBh0Rhlh4lr6--YVefM8hT_s]tim@m...[/url
Suggestions?
Tim
abuse@p....
abuse@p....
>·Back in the "dark days" [noparse][[/noparse]being facetious] before everyone become so
>·enamored with interrupts, programmers used to trace their code
>·paths, counting cycles and could do accurate timing and measuring.
>·I used to work in the irrigation industry building sprinkler
>·timers, and this process is still used on small (four-bit processor!
>·) models.
I'll date myself here, the cobwebs are clearing away and I'm remembering a lot
of those techniques from jobs past.
>·In my alarm application I padded the routines such that any state
>·would cause the "Main" loop to run at 100 milliseconds. ·My "Real
>·Important Task" was monitoring inputs -- I simply added the value
>·of the input, then multiplied, like this...
>·counter1 = (counter1 + C1in) * C1in
>·If the input was one the counter was incremented; if zero the
>·counter was cleared. ·The next step in my system checked counts and
>·directed the proper task (by setting the variable state).
>·I hope that some of this helps you with your application.
Several good suggestions from list members. At this stage I like your technique
best as I won't need an external counter or clock for what I need to accomplish.
Thank you Jon!
Tim
just a minor correction to the follow up, which would be,
counter1 = (counter1 + C1in) & -C1in
C1in is a bit and counter1 is probably a word or a byte. -1=$ffff is
the mask to maintain the counter and 0 will reset it. (Note: unary
"-" takes precedence over binary "&" in PBASIC)
While in machine language execution time, negation-followed-by-AND
would be far faster than full multiplication, on the Stamp BS2, each
math operator takes about 140 microseconds of interpreter
fetch+execute time, so the two operator sequence &- might be slower
than the single *.
-- Tracy
>Just a follow-up:
>-- Jon Williams
>-- Parallax
>From: Jon Williams
>Main:
> DO
> LOOP
>-- Jon Williams
>-- Dallas Office
>From: Tim McDonough [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=PAu-XoP3H5pyl06eNJ9UBIuQ_3B2gAYCmevM1c1OScuZMSuezsFUNPm-1z5szMtlVhhbxM8czA]tim@m...[/url
>Suggestions?
>Thanks,
>Tim
>abuse@p....
>abuse@p....
>Subject and Body of the message will be ignored.
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
-- Jon
From: Tracy Allen [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=6pX5yPNut1sDdXXDjPMJfsKKMwZEnuacrmPHB3GvbwC62_RdStLHpEuoAUBCI3VpRghRDR9HcKqt2w]tracy@e...[/url
Sent: Tuesday, October 14, 2003 12:58 PM
Hi Jon,
than the single *.
-- Tracy
>Just a follow-up:
>-- Jon Williams
>-- Parallax
>From: Jon Williams
can't
scope
>Main:
> DO
> LOOP
the
>-- Jon Williams
>-- Dallas Office
>From: Tim McDonough [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Ut4RYH9wFLUFLaw-10WaUp3GcndK3hEqOJwK74yzS4hXAOnSALIWdUg9Up4zbwTuR-a9sLwr18xMvw]tim@m...[/url
>Suggestions?
>Thanks,
>Tim
>abuse@p....
>abuse@p....
abuse@p....
