Fwd: [basicstamps] Newbie in temp control
i did a similar project like this a while ago. i used a 12 Vdc PC fan like
you said. i used a 2N2222A NPN trasistor found at radio shack and a relay.
a separate 12vdc regulator or power supply is needed to supply voltage to
the fan. connecting +12vdc to one end of the coil of the relay and the
other end to the collector side of the NPN transistor. also connect the
emitter to ground of the 12vdc and VSS of the stamp. use a 1k ohm resistor
connected to the base of the transistor and th I/O pin of the stamp you
want to use. all you have to use for the code is to make that I/O pin high.
i used this in my program using a BS2
High 0 ' where I/O 0 is the I/O used
reverse 0 ' use this code to turn of the fan
hope this helps, it worked for me.
>X-eGroups-Return:
>sentto-1327227-35685-1066075657-gdii=cox.net@r...
>X-Sender: terewbonf@y...
>X-Apparently-To: basicstamps@yahoogroups.com
>User-Agent: eGroups-EW/0.82
>X-Mailer: Yahoo Groups Message Poster
>From: "terewbonf" <terewbonf@y...>
>X-Originating-IP: 219.95.166.158
>X-Yahoo-Profile: terewbonf
>Mailing-List: list basicstamps@yahoogroups.com; contact
>basicstamps-owner@yahoogroups.com
>Delivered-To: mailing list basicstamps@yahoogroups.com
>List-Unsubscribe: <mailto:basicstamps-unsubscribe@yahoogroups.com>
>Date: Mon, 13 Oct 2003 20:07:33 -0000
>Subject: [noparse][[/noparse]basicstamps] Newbie in temp control
>Reply-To: basicstamps@yahoogroups.com
>Hi guys,
>I own a BS2 based TABRobotkit SUMO Bot, planning on adding aditional
>functionalities:-
>Temperature Detector - Once a certain temp reached, turn on Fan(s)
>This is what i already have now,
>(1) 10K Ohm Resistor
>(1) 10uF Capacitor
>(1) ADC0831
>(1) LM34 Temperature Sensor
>Are these all the things i need, in addition to the SUMO Bot itself?
>Secondly, what type of 120/80mm fan should i get (12v DC? or 3 pin
>Computer fan) and how do i actually wire and power it ?
>And would the usage of a shiftin method be recommended?
>Any replies would be received with utmost gratitude... [noparse]:)[/noparse]
>from the same email address that you subscribed. Text in the Subject and
>Body of the message will be ignored.
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
>X-eGroups-Return:
>Hi guys,
>functionalities:-
>(1) 10uF Capacitor
>(1) ADC0831
