First night''s hamster data is in ...
Michael--
Why not just post it in the FILES section of the group site?
It would save you a lot of emailing.
Sent: Friday, October 10, 2003 10:48 AM
Subject: [noparse][[/noparse]basicstamps] Re: First night's hamster data is in ...
> Sorry, didn't realize that the board will remove e-mail addresses. If
> you want to see the data, send an e-mail to "webbm at comcast dot net".
> Michael
> --- In basicstamps@yahoogroups.com, "webbm03" <webbm@c...> wrote:
> > Since there've been a few people interested in the "hamster"
> > experiment, I thought I'd post a brief note.
> > The stamp setup worked well. I decided not to use COUNT, but instead I
> > wrote a simple "state loop" that counts clock cycles (in effect) while
> > waiting for the reed switch to close and bring the input pin low. I
> > found that I got some bounce in the reed switch, but this was overcome
> > with a simple bypass capacitor across the reed swtich. The stamp setup
> > counts revolutions accurately and stably. I had to calibrate the cycle
> > counter, but this was simple: I simply ran the wheel by hand for a few
> > minutes and then multiplied the total number of clock cycles by a
> > conversion factor to get real time. The clock cycles ended up being
> > very close to 4 miliseconds, so even when the hamster was running his
> > fastest, I was getting a count of at least 120 per revolution. I can
> > post the code if anybody wants to see it.
> > "Smokey" (my daughter's hamster) was busy last night! He started
> > around 2130, and went to sleep this morning just after 0800. He ran a
> > total of 20580 meters--I was surprised; that's over 12 miles! He
> > averaged 0.9 m/s, and ran essentially all night. He took a couple of
> > relatively long rest intervals (11 and 37 minutes), but other than
> > that 1/2 of his rests were less than 30 seconds, and 90 percent were
> > less than 2 minutes.
> > I have a PPT with some data in it. If anybody's interested, e-mail me
> > at webbm@c..., and I'll send it to you.
> Michael
