Best way to get 4 temp measurements - sensors
--- In basicstamps@yahoogroups.com, "Matt Evans" <kaptnknemo@y...>
wrote:
> I want to measure some temperatures under the hood. I have read a
> lot about the OW stuff and even found an obscure reference on
> multiplexing sensors. I want to pick everyones brain and find out
> what you have done. Note that I didn't say "inside the engine" ie
> combustions temps, I am mostly interest in intake and ambient air
> temps in various locations.
> Thanks a bit
> KK
Use thermocouples for the exhaust.
use the existing water jacket sensor, it is a resistance based sensor
so you would get either a variable current or variable voltage.
for the intake you can try different things. probably juse rig up
yoru unit and take the sensor near the car for a reading and move it
around the car once you have started the engine to see if the high
voltage from the spark plugs will cause errors.
Dave
> Thanks a bit
> KK
Dave
