You could set up a "timebase" by using the D.U.T., to charge a capacitor,
and use the stamp to monitor how long it took to charge. Mathematically,
you could then find the resistance.
Russ
> Is there any way to measure a resistance using the basic stamp, almost as if
it
> was a digital multimeter?
In a message dated 10/9/2003 10:51:36 AM Pacific Daylight Time, MP1428@a... writes:
it was a digital multimeter?
Yes, there is a command called RCTIME and it will measure an unknown
resistance. I am almost sure there is a tutorial you can download that will give
you
the code and the hardware set up example.
Russ
it
> of the message will be ignored.
MP1428@a... writes:
you
