Hurtin input
Hi guys,
I'm in a bit of a pickle.
A few months ago I came up with a cool little project to replace one of our
old wind displays (can't get parts for old one any more).
I had it output to an LCD and it was great. Might not have been
accurate...but baby steps right?!
Well, it's 3 or 4 months later and I told my boss about it. He wanted to
see it....so I decided to get things hooked up and testing before he came
down. Well....crud!! It wouldn't accept any data any more.
The equipment we are using runs off of Current Loop. No problem! I have a
Current Loop to RS232 converter.
I hook that up and pick off the signal from Rx and plug push it through a
22k resistor and then into my Stamps' input.
Well, I can't seem to get ANY serial data in...at least not reliably.
So my question is....:
...as the manuals says that the 22k res is there to limit current and that
there are clamping diodes on board....
If the diodes got zapped, what would I expect to see as far as a voltage on
my Rx pin? If the diodes were shorted (to ground??) I'm guessing that when
I go to measure Rx I won't see anything....
NOW....if I move to a different Stamp Input....will the same thing happen?
Are these clamping diodes on the I/O buss?
I'm not entirely sure how it might have happened....but there were lots of
wires bobbing around (short?).
Next question...being that I've had my head elsewhere and not on my STAMP
(yes sorry...sacriledge!), what's the easiest way to view serial data if you
aren't sure what 'type' of data it is?
Sometimes I'm thinking that I'm just not syncing up to the stream (300e71 ==
11505)
I had it working before (hopefully I didn't kill whatever code I had it
working under), but how would I know if it was INVERTED RS232??? Been
reading that but don't quite understand when I'd use it!!
Here's the code below (trimmed):
'{$STAMP BS2}
NNNN var word
EEEE var word
TT var byte
serin 0, 11505, [noparse][[/noparse]wait (2), shex4 NNNN, skip 1, shex4 EEEE, skip 1, hex2 TT]
11505)
'{$STAMP BS2}
NNNN var word
EEEE var word
TT var byte
I guess I'll start small. (baby steps??)
When you guys read rs232 data to your Stamps. What pins do you 'always'
use? Rx is the obvious one for half duplex. What else would you use in
half dup.?
I had a problem receiving rs232 data and couldn't get a voltage reading when
using the Stamp ED.Boards ground plane to the Rx pin. BUT, I do recall
using pin 7 (sig GND) against Rx and I was getting voltage readings.
SO....would I connect Sig GND to Vdd (Stamp GND) to make one ground plane?
I might be getting some nasty 60Hz in there somewhere.
sb
From: Brady,Steven [noparse]/noparse]PYR] [noparse][[/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=S0X-K42REjd6718SXK_rYjw0uxxKm_6NZMpL5vYZgytVNxw_0YWwCITEVoPTAIUrhi8lW9fvjX7QZYF_3LI]steven.brady2@e...[/url
Sent: October 8, 2003 20:55
To: 'basicstamps@yahoogroups.com'
Subject: [noparse][[/noparse]basicstamps] Hurtin input
Hi guys,
Current Loop to RS232 converter. I hook that up and pick off the signal from
Rx and plug push it through a 22k resistor and then into my Stamps' input.
Well, I can't seem to get ANY serial data in...at least not reliably. So my
question is....: ...as the manuals says that the 22k res is there to limit
current and that there are clamping diodes on board.... If the diodes got
zapped, what would I expect to see as far as a voltage on my Rx pin? If the
diodes were shorted (to ground??) I'm guessing that when I go to measure Rx
11505)
'{$STAMP BS2}
NNNN var word
EEEE var word
TT var byte
SEROUT 16, 84+16384, [noparse][[/noparse]DEC UnkVal]
This will convert 'UnkVal' into a human readable
decimal number. If you just output 'UnkVal',
if it is a 0, for instance, it will clear your
terminal window.
--- In basicstamps@yahoogroups.com, "Brady,Steven [noparse][[/noparse]PYR]"
<steven.brady2@e...> wrote:
> Hi guys,
one of our
wanted to
he came
I have a
through a
reliably.
and that
voltage on
that when
happen?
lots of
STAMP
data if you
(300e71 ==
> 11505)
had it
Been
> '{$STAMP BS2}
> NNNN var word
> EEEE var word
> TT var byte
hex2 TT]
From: Allan Lane [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ygPXp9s4R6naSa3KDqLLis0oIGb6t2ELN8-pJ5PPNBMEdJv-kBeyE6wbz26Xm1kPaiQVXyGbpX9lL6lLNgtaEmBZx974]allan.lane@h...[/url
Sent: October 9, 2003 07:57
Subject: [noparse][[/noparse]basicstamps] Re: Hurtin input
Best way to output unknown input is as 'DEC' --
terminal window.
> Hi guys,
one of our
wanted to
he came
I have a
through a
reliably.
and that
voltage on
that when
happen?
lots of
STAMP
data if you
(300e71 ==
> 11505)
had it
Been
> '{$STAMP BS2}
> NNNN var word
> EEEE var word
> TT var byte
hex2 TT]
clear it. Very annoying if it wasn't what
you wanted to happen.
> Would it clear the debug window as well?
> From: Allan Lane [noparse][[/noparse]mailto:allan.lane@h...]
> terminal window.
> > Hi guys,
> one of our
> wanted to
> he came
> I have a
> through a
> reliably.
> and that
> voltage on
> that when
> happen?
> lots of
my
> STAMP
> data if you
> (300e71 ==
> > 11505)
> had it
> Been
> > '{$STAMP BS2}
> > NNNN var word
> > EEEE var word
> > TT var byte
> hex2 TT]
Subject and
the Preferences dialog. This can be useful when debugging mysterious
serial streams.
-- Jon Williams
-- Dallas Office
From: Allan Lane [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=r7lQTBWv3aXm7jQJF6Gh35A7vJHRTUuxo1ZImZUsdvcApcEBiHxENko8tj7DFkqR8OQ6TYP6frkPmgKWBPL3xiTl]allan.lane@h...[/url
Sent: Thursday, October 09, 2003 10:00 AM
Yes, outputting a CHAR(0) to the debug window will
> terminal window.
> > Hi guys,
> one of our
> wanted to
> he came
> I have a
> through a
> reliably.
> and that
> voltage on
> that when
> happen?
> lots of
my
> STAMP
> data if you
> (300e71 ==
> > 11505)
> had it
> Been
> > '{$STAMP BS2}
> > NNNN var word
> > EEEE var word
> > TT var byte
> hex2 TT]
Subject and
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
