Newbie With a Progect
hi all, i would like to know if anyone has done anything like this
before, i have a Widband Oxygen sensor controler that will output
from 0-5volts, i want to take this and display it on an lcd.
http://www.diy-wb.com/v_out.htm
Above is a table of voltage VS AFR wich is what i would like to
display, how ever i do not know how i would go about this, i am
guessing i would need a ADC to interface with the 0-5v signal and the
basic stamp, but code is where i am falling down here....
Can any one give me any ideas on this or some where to look ????
Thanks..
Thanks..
places]. If the voltage vs AFR relationship is linear you can use Stamp
math to convert to AFR, otherwise you can create a look-up table in DATA
statements.
-- Jon Williams
-- Dallas Office
From: mazda_gtx_man [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=X-YQeKSQmZYK9xRoTbyulVf_R1PPpYxjlaznB0t0_v1I8KF1LsMjN_jB7C4n-bLTsQcYNUHKGzSfJwyB2mAkvuE]mazda_gtx_man@y...[/url
Sent: Wednesday, October 08, 2003 2:51 PM
Subject: [noparse][[/noparse]basicstamps] Newbie With a Progect
Thanks..
Your use of Yahoo! Groups is subject to
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
do not know how to do a lookup table i have only ever done very basic
stuff with the stamp...
Also what kinda refesh rate could i get, i need a max of 1 second.
do you thibnk that would be possible..???
Jason
--- In basicstamps@yahoogroups.com, "Jon Williams" <jwilliams@p...>
wrote:
> We have ADC0831 (simple 8-bit ADC) code on our web site [noparse][[/noparse]in several
Stamp
DATA
> statements.
> -- Jon Williams
> -- Dallas Office
> From: mazda_gtx_man [noparse][[/noparse]mailto:mazda_gtx_man@y...]
the
> Thanks..
Subject
> abuse@p...
the tar out of a long-winded explanation. This little program uses
values from your chart and shows how to do a lookup table in DATA
statements using Word values. Note that the Get_AFR expects a value of
at least 140
'{$STAMP BS2}
'{$PBASIC 2.5}
vOut VAR Byte ' 100 = 1.00 volts
afr VAR Word ' fuel ratio (?)a
eePntr VAR Word ' pointer into EE table
AFRTable DATA Word 1008, Word 1023, Word 1038, Word 1053
DATA Word 1069, Word 1086, Word 1103, Word 1120
Demo:
FOR vOut = 140 TO 175 STEP 5
GOSUB Get_AFR
DEBUG DEC vOut / 100, ".", DEC2 vOut, TAB
DEBUG DEC2 afr / 100, ".", DEC2 afr, CR
next
END
Get_AFR: ' convert vOut to AFR
eePntr = vOut / 5 - 28 * 2 ' create table pointer
READ (AFRTable + eePntr), Word afr ' read AFR from table
RETURN
-- Jon Williams
-- Dallas Office
From: mazda_gtx_man [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ic1TYxE7zbQ3KazgyORfNYgIAuSNzPatSHuBaxFEiznhv0owgspi__B_t44hcNpDVUN0PkrX4tr5o5RWTA]mazda_gtx_man@y...[/url
Sent: Thursday, October 09, 2003 8:30 AM
Subject: [noparse][[/noparse]basicstamps] Re: Newbie With a Progect
no it is not a liner out put, that is why i am having the problems, i
Also what kinda refesh rate could i get, i need a max of 1 second. do
Jason
Stamp
DATA
> statements.
> -- Jon Williams
> -- Dallas Office
the
> Thanks..
Subject
> abuse@p...
abuse@p....
that is a lot simpler than i thought it would be....!!!!
but the values in the AFRTable are what?? they do not seem to relate
to anything i can see off hand, just want to know before i get into
somthing i can not do here, but it dos not look like it is going to
be to dificult.
wrote:
> Here you go. If a picture is worth a 1000 words, a demo program
beats
value of
> at least 140
> '{$STAMP BS2}
> '{$PBASIC 2.5}
table
> Demo:
> GOSUB Get_AFR
> next
> END
AFR
pointer
table
> RETURN
> -- Jon Williams
> -- Dallas Office
i
basic
do
> Thanks
> Jason
several
> Stamp
in
> DATA
> > statements.
> > -- Jon Williams
> > -- Dallas Office
> the
> > Thanks..
> Subject
> > abuse@p...
Subject
> abuse@p...
this thread. In that table the left-most column is voltage, the third
column is AFR -- which I thought you wanted to extract. Didn't you? I
only used the first eight values, you can fill in the rest. There is a
slight trick in calculating the address, but only slight. I noticed
that the voltages in that table were in increments of 0.05 -- so I
divided the voltage by five, then offset for the table starting at 1.40
(hence the -28). Since the AFR table holds Word (two byte) values, the
pointer is multiplied by two to for correct alignment.
-- Jon Williams
-- Dallas Office
From: mazda_gtx_man [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=wZpGT-V6or4mJOzZ06T4UngO-eQeUlMkRZ6pNxqaO2BnEW3pXATw4dClTZCe0tt4tiO0mNdTY0psf943TYuNHQM]mazda_gtx_man@y...[/url
Sent: Thursday, October 09, 2003 10:23 AM
Wow you answer fast, thanks [noparse]:)[/noparse]
be to dificult.
beats
value of
> at least 140
> '{$STAMP BS2}
> '{$PBASIC 2.5}
table
> Demo:
> GOSUB Get_AFR
> next
> END
AFR
pointer
table
> RETURN
> -- Jon Williams
> -- Dallas Office
i
basic
do
> Thanks
> Jason
several
> Stamp
in
> DATA
> > statements.
> > -- Jon Williams
> > -- Dallas Office
> the
> > Thanks..
> Subject
> > abuse@p...
Subject
> abuse@p...
abuse@p....
on the controller in about a week, so i will com back and let you
know then...
and yes you use the right to colums....
i have a LTC1286 would this be ok for the ADC ?? as i already have it.
and i also have a few graphical LCDs handing around, are these hard
to control with the stamp ????
wrote:
> The values in AFRTable come from the link you posted at the
beginning of
third
you? I
is a
1.40
the
> -- Jon Williams
> -- Dallas Office
relate
> be to dificult.
> beats
uses
> value of
> > at least 140
> > '{$STAMP BS2}
> > '{$PBASIC 2.5}
> table
> > Demo:
> > GOSUB Get_AFR
> > next
> > END
> AFR
> pointer
> table
> > RETURN
> > -- Jon Williams
> > -- Dallas Office
problems,
> i
> basic
> do
> > Thanks
> > Jason
<jwilliams@p...>
> several
use
> > Stamp
> in
> > DATA
> > > statements.
> > > -- Jon Williams
> > > -- Dallas Office
this
output
and
> > the
> > > Thanks..
> > Subject
to
> > > abuse@p...
> Subject
> > abuse@p...
Subject
> abuse@p...
You just need to put your nose to the grindstone and do your project.
Should be fun.
-- Jon
From: mazda_gtx_man [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=BmAm_-dbUvTMZINLLnl7xxUTM1WGzkW6zZbvtdYUZlUfDadJKw8Cjk8IACk_N5g0ZvOEKPE3Dp52dwE5JZ9BC_WI]mazda_gtx_man@y...[/url
Sent: Thursday, October 09, 2003 10:45 AM
OK i got you [noparse]:)[/noparse] thanks for your help sofar i will be getting my hands
know then...
beginning of
third
you? I
is a
1.40
the
> -- Jon Williams
> -- Dallas Office
relate
> be to dificult.
> beats
uses
> value of
> > at least 140
> > '{$STAMP BS2}
> > '{$PBASIC 2.5}
> table
> > Demo:
> > GOSUB Get_AFR
> > next
> > END
> AFR
> pointer
> table
> > RETURN
> > -- Jon Williams
> > -- Dallas Office
problems,
> i
> basic
> do
> > Thanks
> > Jason
<jwilliams@p...>
> several
use
> > Stamp
> in
> > DATA
> > > statements.
> > > -- Jon Williams
> > > -- Dallas Office
this
output
and
> > the
> > > Thanks..
> > Subject
to
> > > abuse@p...
> Subject
> > abuse@p...
Subject
> abuse@p...
abuse@p....
