Stamp Triggering
My question is about how to setup the stamp to be triggered when say
a input pin gose high, and then run a program and wait once agian for
input to go high to run it once more....
in my sample program below:
MAIN:
input 2
IF IN2 = 0 THEN TB
IF IN2 = 1 THEN MAIN
TB:
debug "input is high"
input 2
IF IN2 = 1 THEN main
goto main
now what seems to happen with this code hear (even thought i know
its detecting the low state of the pin) i have a 555 timmer setup to
read a photo transistor and on the other side of the transistor is a
IR emmiting led, so basicly if the two are pointed together it wont
run nothing or debug "input is high" but!.... if i break the line it
will keep looking "input is high,etc...." over and over , i just want
it to say it once, then if the IR sight is returned , do nothing ,
but if broken agian will debug "input is high" (not haveing the
sucker keep looping..)
im sure theres probley a better way to code this maybe someone with a
beter brain then me can figure it out, its anoying that this stupid
thing repeats it self even tho i just want it to do sorta like a "one
shot" and if the IR line sight is returned, but then broken once more
to repeat it self, and so on....
please help!
Sean...
MAIN:
input 2
IF IN2 = 0 THEN TB
TB:
input 2
goto main
please help!
Sean...
main:
main1:
IF in2=1 THEN main1 ' stay in this loop while in2 is high
main0: ' now it is low
IF in2=0 then main0 ' stay in this loop while in2 is low
' fall through to TB when it goes high
TB:
debug "input went high"
goto main
or in PBASIC 2.5 syntax:
main:
DO : LOOP WHILE in1=1
DO : LOOP WHILE in1=0
TB:
goto main
-- Tracy
>MAIN:
>input 2
>IF IN2 = 0 THEN TB
>TB:
>input 2
>goto main
>please help!
>Sean...
>from the same email address that you subscribed. Text in the
>Subject and Body of the message will be ignored.
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
Lets clarify the hardware side of this problem. You mentioned that you
are using IR LED and on the receiving side is a photo transistor. My
question is, is the photo transistor is an IR receiver type or just
ordinary detecting luminance type? Have you tried it out on a
breadboard using the transistor to drive an LED to see if the two
pairs really work?
On the code side I see that you didn't balance the detection between
the two state like this:
MAIN:
IF IN2 = 0 THEN MAIN
IF IN2 = 1 THEN DISPLAY1
GOTO MAIN
DISPLAY1:
DEBUG "Input is HIGH"
TB:
IF IN2 = 1 THEN TB
IF IN2 = 0 THEN DISPLAY2
GOTO TB
DISPLAY2:
DEBUG "Input is LOW"
GOTO MAIN
Cheers,
- Johari
--- In basicstamps@yahoogroups.com, "djrevolution99"
> MAIN:
> input 2
> IF IN2 = 0 THEN TB
> TB:
> input 2
> goto main
> please help!
> Sean...
