LCD refresh, how?
Hello,
While displaying a variable temperature on an lcd, when the temp.
decreases, the F remains on the screen from the previous larger
number. If I put the clear screen command at the start of the lcd
code, then the lcd refreshes so fast that it doesn't look nice.
Almost looks like it's flashing.
When it says: 100 F
And the temp decreases, you get: 99 FF
And more: 9 FFF
Does someone know how to solve this??
Thank you,
John
When it says: 100 F
And more: 9 FFF
Thank you,
John
". Then when you drop to 99 you won't see "99FF".
You could also get fancy and use a little math to calculate the proper
number of spaces and print them in a loop or something.
> From: cn00728 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=OAEtLWQJamnyE_-MuflHNK_io-2bt3k5UHNmZXe0F1GRvO_MH-EhJnceUF65oOicbj2vuLi7mpwqBg]cn00728@y...[/url
> Sent: October 7, 2003 6:05 PM
> Subject: [noparse][[/noparse]basicstamps] LCD refresh, how?
> Hello,
> When it says: 100 F
> And more: 9 FFF
> Thank you,
> John
> from the same email address that you subscribed. Text in the
I've had to do this before when displaying a value. The extra spaces will
cover up the F that gets left behind from the larger number.
73 de KG6SGY
Sent: Tuesday, October 07, 2003 6:05 PM
> Hello,
> When it says: 100 F
> And more: 9 FFF
> Thank you,
> John
I'd use a 5-byte wide array on the Stamp and a constant beginning
address of choice on the LCD. To refresh the display:
- Fill the array with blanks
- Overwrite the (blank) array with the desired text
- Send set display address command to LCD
- Write all 5 array bytes to the LCD
Steve
On 8 Oct 03 at 1:05, cn00728 wrote:
> Hello,
