SRF04 Ultrasonic Range Finder
Help! Help!
I thought I would not have any trouble with the SRF04, but I
seem to be unable to get consistent readings.
It seems to bounce over and over, and the readings are not
accurate.
Specifically, part of the code that I run ( from Nuts & Bolts)
is the following:
(All the initializations and parameter settings have been done
earlier)
Main:
GOSUB Get_Sonar ' take sonar reading
DEBUG MoveTo, 15, 3
temp = rawDist
GOSUB RJ_Print ' display raw value
DEBUG MoveTo, 15, 4
distance = rawDist ** 8886 ' divide by 7.3746
temp = distance / 10
GOSUB RJ_Print ' display inches
DEBUG ".", DEC1 distance
DEBUG MoveTo, 15, 5
distance = rawDist ** 22572 ' divide by 2.9033
GOSUB RJ_Print ' display centimeters
PAUSE 200 ' delay between readings
GOTO main
If I replace "GOTO main" with END, and run the code over
and over,
I get totally inconsistent and erroneour readings. I thought
there was something wrong with the
SRF04 itself, and I send back to Parallax, but, it was
returned with the message that there is
nothing wrong with it.
What am I doing wrong? Please help!!!!!
accurate.
is the following:
earlier)
Main:
DEBUG MoveTo, 15, 3
temp = rawDist
DEBUG MoveTo, 15, 4
DEBUG MoveTo, 15, 5
GOTO main
and over,
change in the SRF04 (which you cannot identify just by looking at it)
seemed to cause our original code to have problems. I spent a day last
week rewriting the code so that it will work with old or new SRF04 units
and on any of our BS2 micros.
Here's the link:
http://www.parallax.com/detail.asp?product_id=28015
-- Jon Williams
-- Dallas Office
From: John Colonias [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Ajl8VdsMbxFAjQV6op1Ko0PzWNyUXaHDRUKGRBQvILeZhti3QOTyDcXPu-4TqbYYuJ9ekcPYNGFTUvA73a0I-TAm]jcolonias@i...[/url
Sent: Tuesday, October 07, 2003 11:34 AM
Subject: [noparse][[/noparse]basicstamps] SRF04 Ultrasonic Range Finder
Help! Help!
accurate.
is the following:
earlier)
Main:
DEBUG MoveTo, 15, 3
temp = rawDist
DEBUG MoveTo, 15, 4
DEBUG MoveTo, 15, 5
GOTO main
and over,
Your use of Yahoo! Groups is subject to
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
Thank you very much. I will try it tonight when I get home, and let you know
tomorrow.
John
On 7 Oct 2003 at 9:56, Jon Williams wrote:
We've got new code on our web site. The problem is that a firmware
Here's the link:
-- Jon Williams
-- Dallas Office
From: John Colonias [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=XnOqlo5q880uNkALjA8m4GTTAsz5ZdYpAR7XKdi753oyS2IHakCCbhFLrQDjF3WZgeCHZ_neCFtqL5evXw19rxEw]jcolonias@i...[/url
Help! Help!
accurate.
is the following:
earlier)
Main:
DEBUG MoveTo, 15, 3
temp = rawDist
DEBUG MoveTo, 15, 4
DEBUG MoveTo, 15, 5
GOTO main
and over,
abuse@p....
from the same email address that you subscribed. Text in the Subject and Body
Tried new code and it is consideably better than the previous ones. However,
it
still, occassionally, registers erroneous reading. I also noticed that I get
consistendly
lower readings that what actually the distance should be, therefore, I thought
of
writing code to pick the highest of three readings. Any better way ?
Thanks, John
Here's the link:
-- Jon Williams
-- Dallas Office
From: John Colonias [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=7E-sKFH2Czgk0Hjx5ZVH829DAA8hvtqfRdBmZcTIdp9WuO9An5AoXdBgiIBR9OYr4oGVixdFMAdE7bcxLbsn3h-0OwU]jcolonias@i...[/url
Help! Help!
accurate.
is the following:
earlier)
Main:
DEBUG MoveTo, 15, 3
temp = rawDist
DEBUG MoveTo, 15, 4
DEBUG MoveTo, 15, 5
GOTO main
and over,
abuse@p....
Here's the thing. If you have a *new* unit (built May 2003 or later)
there is a hidden function. The problem is that there is no way to
physically tell one unit from the next because they aren't marked.
Anyway, if you ground the "Do Not Connect" pin on the new units it
extends the time before the sonic burst out to about 300 uS -- this
gives the BS2 plenty of time to get ready with PULSIN. PULSIN will be
more accurate because it sees the whole return pulse which is
proportional to the object distance -- RCTIME misses a bit of the front
edge. That said, the SRF04 is not a lab grade instrument and getting 1
cm resolution is all that can be expected -- if that.
Another thing. The setup time for PULSIN can be affected by the pins
you choose. I always used 0 (trigger) and 1 (echo) and NEVER had any
problems with my original program running on a stock BS2.
-- Jon
From: John Colonias [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ZirzW_5yEQ0ayx6qJ93Y9NvtnZP4YimqjZWshe9cqMjtlM0I8XzFsXsuZTenEPD7GyiwN-figZcYcyCTPNX97bolEA]jcolonias@i...[/url
Sent: Monday, October 13, 2003 1:21 PM
Subject: RE: [noparse][[/noparse]basicstamps] SRF04 Ultrasonic Range Finder
Jon,
However, it
get consistendly
thought of
Thanks, John
Here's the link:
-- Jon Williams
-- Dallas Office
Help! Help!
accurate.
is the following:
earlier)
Main:
DEBUG MoveTo, 15, 3
temp = rawDist
DEBUG MoveTo, 15, 4
DEBUG MoveTo, 15, 5
GOTO main
and over,
abuse@p....
abuse@p....
> [noparse][[/noparse]...] still, occassionally, registers erroneous reading. I also noticed
that I
> get consistendly lower readings that what actually the distance should be,
> therefore, I thought of writing code to pick the highest of three
readings.
> Any better way ?
The first thing you mention is easy to explain: the consistently low
readings. The measurement of pulse width begins a noticeable time period
after the leading edge of the acoustic pulse train leaves the emitter can.
At least 300 microseconds if you're using a fast Stamp and the PULSIN
command. A little bit longer if you're using a BS2 and the RCTIME command.
You need to calibrate this delay as an offset in the raw pulse measurement.
Don't worry about theory. Just take repeated measurements at a near distance
like 18" and determine how much to add the raw reading. It is a fixed offset
and not a percentage of the total range.
As to the erroneous readings, I've been testing two examples of the SRF04
for a few weeks, John. Before playing with your code too much, consider what
you might expect from "perfect" code. If we're not careful, it's easy to
create a clean fiction in software that doesn't reflect the messy real
world. And from a sensor, we want data not fiction.
Recognize that this is not a narrow-beam, high-frequency sensor. For
contrast, it specifically is NOT a laser rangefinder. Devantech's published
chart in the manual is interpreted by them as indicating a 30° beam width.
It looks more like 45° at least, and 60° for practical purposes. We're
talking about a couple of very small acoustic cans here. My point is that
for testing its performance, don't set the equipment on a cluttered tabletop
and expect consistent readings. Use a flat surface; a flat target plate to
provide a return; and nothing else above, below, left, or right of the beam
path to the target. This will avoid "erroneous" readings that actually are
giving you the valid distance to an intermediate object you didn't realize
was within that broad beam width.
I'm not an acoustic engineer, so I wasn't sure if it would be a problem, but
I also turned off my in-computer stereo sound system while running tests. I
figured it couldn't hurt to be careful, and a lot of the music was creating
high energy levels at sub-harmonics of that 40 kHz frequency of the sonar.
For all I knew, that might lead to spurious lock-ups. If nothing else, the
music would add to the background noise level and thereby reduce the
signal-to-noise ratio the receiver will enjoy.
Even with those precautions, don't expect the same raw reading each time.
Even with an artificially empty test environment, the real world is not that
smooth. Let me run down some of the causes I've seen for readings that seem
erratic to us.
First, the Stamp is not an oscilloscope. It is counting discrete "ticks" of
it's own clock to measure the pulse duration on that echo line. The actual
duration necessarily falls on one side of the other of a "tick" boundary.
That means a raw reading of 1000 this time might be followed by 1001 and
then by 999 -- and they all would be right, with no way to choose a "best"
one. This is discretization error and it's inherent in assigning an integer
value to a real number.
Second, this is a 40 kHz acoustic wave train at a pretty low energy level.
The receiver has to lock up on the reflected energy of that pulse in the
presence of acoustic energy of all sorts reaching that can. Without getting
into the theory of doing such, I seem to remember that the absolute
theoretical best for a phase-locked loop to detect the beginning of a wave
form is three cycles. It's been several decades since a true expert on this
subject told me that, so there's a ten percent chance I'm misremembering and
he said two cycles -- but I don't think so. The reason is I'm a stubborn guy
and I seem to remember him having to work hard to convince me it couldn't be
done one cycle sooner. Catching a waveform on the first cycle is just plain
silly so we surely were arguing about doing by the second, with him
insisting a third cycle was necessary.
For the sake of argument, let's assume it takes three cycles in a best case.
Even in a cleaned-up test situation, you don't have a perfect signal and a
perfect sensor. So it's usually going to take much longer -- say five or six
cycles -- to "recognize" the returning waveform. That is, to lock up by
synchronizing with it. That "lock up" is what will drop the echo line and
terminate the pulse from the point of view of the Stamp. The sensor doesn't
know how many cycles it took to achieve lock-up, so it can't tell us even if
the interface gave us a way to ask.
There actually are some tricky ways to approximate that, but this isn't a
billion dollar sonar suite on a submarine we're talking about. So the sensor
cannot tell us, because it does not "know" when the real leading edge
arrived for that returning echo.
Lock up, schmock up. All we know is the echo line went low. What we can
observe is that it even after we take out the little variations of one Stamp
tick more or less, we still get "big" jumps of 12 to 13 clocks regularly. At
least I do with a BS2 conducting the tests. Your mileage with vary with a
Stamp that has a different clock rate. Because a little arithmetic explains
those jumps. This is 40 kHz signal. That's 40,000 times per second that it
goes from one peak of acoustic pressure to the next peak. Take the inverse
of 40,000 and you have 25 millionths, or 25 microseconds, from peak to peak.
We can't measure 25 microseconds from a BS2 -- only 24 microseconds or 26
microseconds. That's 12 clocks or 13 clocks.
So every time the receiver takes one cycle more or less to lock up, we see a
jump of 12 or 13 clocks up or down. Or sometimes 25 clocks between one
"ping" and the next. Or even 36 to 40 clocks, because each reading must vary
up and down by a clock or two because of measurement resolution in the
stamp, and the sensor itself is varying by some multiple of 25 microseconds
up or down because of the frequency of the waveform.
6. Don't average all this. I disagree with the Parallax app note on this
point. It was a good chance to teach people how to average values with a
limited number of bits available in the accumulator, but the average is not
appropriate to this raw data. (Technically, we say that this is not a
Gaussian source of noise, so the mean is not an appropriate metric.)
Instead, pick one answer and use that. The average will be some in-between
number whose only sure trait is being wrong. (It might land on the right
value like a stopped clock, but that's another joke for another day.) If you
feel compelled to use multiple pings when you've already got a valid
measurement, just put the results in "buckets" and pick the bucket that gets
the most hits. This still won't be any more "right" than the next bucket
over, because we have no idea how many cycles into the returning echo that
lock-up occurred. But it might be fun to try, and do it if it makes you feel
better about the answer your subroutine returns.
7. Don't use a rope as a micrometer. The acoustic wave train from this
sensor is two inches long for a reason. Well, probably. Maybe they did it
because they saw somebody else use that pulse width, but for the sake of
argument we'll assume that Devantech or that somebody else did the work to
know how likely it is to pick up the returning waveform in a particular
length of time -- that is, a particular pulse width. At short range in good
conditions, half that pulse duration might work 90% of the time. But we
can't pick our conditions when the sensor actually goes to work. Across the
usable range of the sensor, we're talking about multi-path returns
interfering with the waveform, noise spikes reducing some parts to a
signal-to-noise ratio too low for lock-up, phase distortions from umpteen
causes, and so forth and so on. I'm surprised a low cost receiver can lock
up in eight cycles as reliably as this one does. But those eight cycles are
needed sometimes, and we can't assume lock-up occurred at any particular
point in that returning waveform. The receiver may have locked up by the
third cycle, or it may not have locked until the eighth cycle.
A precision of about two cycles is achieved under optimum conditions. In
other words, if I take that raw reading and divide by 25 clocks (or 50
microseconds), I start to get consistent reports from my subroutine. This is
optimum conditions remember. That flat plate target business with my robot
unmoving on a steady surface looking at a wall less than six inches away.
That precision is 0.45 inches or 1.1 cm in the raw counts. For convenience,
I multiplied by the range factor and report my result to the calling routine
in multiples of half an inch. After multiplying, I apply that offset I
mentioned at the beginning. Calibrated in half inches, because nothing
closer is meaningful.
This half inch is the precision of course, NOT the accuracy unless
conditions are ideal. The accuracy of any particular return over the full
range cannot be assumed to be better than plus or minus four clocks unless
you are willing to take into account a lot other factors. You could, for
example, de-rate the expected accuracy in accordance with the reported
range. Personally, I don't expect an accurate resolution of less than one
inch even when looking straight down at a flat surface: a distance of 8.5"
for my robot. Not unless I know the surface is flat and no objects are down
there -- in which case I didn't need the sensor...
8. Finally, don't expect a reading every time. For two reasons. You didn't
specify what kind of erroneous results you were getting, so I can't guess
which applies. First, the echoes may return in such a gnarly garbled state
that the receiver never sees a clean enough sine wave to lock up. This
results in the echo line remaining high for 36 ms. On a BS2 your raw reading
will be about 18,000. The second possibility is a problem at the interface.
We have two devices here designed thousands of miles apart. Like men and
women, their timing will not always agree when they try to interface.
That conditional compilation code deals with this by using one instruction
for the fast Stamps and another for the slow Stamps, but the Devantech unit
appears to be an analog interface design. That is, it is not controlled by a
crystal oscillator. (I can't imagine bothering. This is not a criticism,
just an explanation.) That means timing on its side of the interface will
vary with temperature of the components, which in turn varies with the duty
cycle of the emitter as well as the ambient. Sometimes a particular unit
could be a little too slow to raise the echo line for RCTIME to work, even
on the slower Stamps like my BS2. One of my examples was like that. I doubt
any unit would be fast enough to beat one of the faster Stamps using PULSIN,
but using PULSIN with the slower Stamps rarely works. Only occasionally will
the Devantech be slow enough for PULSIN to catch the leading edge of the
echo line.
If your unit slows down just enough for the RCTIME command to be set up and
looking at the pin before the echo line is raised, then RCTIME will return a
value of one. This means "I looked for the signal condition you told me to
measure and it went away in one clock or less." Really, RCTIME was not
patient enough for the signal to appear in the first place, but we have to
supply the patience. Computers just do what we literally ask.
So, the nasty messy reality of echoes and their detectors in the physical
world mean you should expect all sorts of differences from one call to the
next of the SRF04:
1. A simple 1. The sonar raised the echo line a little late for RCTIME to
work. Natural variation in analog components. Just include a loop to send
out pings until a result other than one is achieved.
2. A simple 0. The sonar raised the echo line a little early while you were
using a PULSIN to measure the result. Jon's new sample code does not do this
with the slower Stamps, but the old sample code did. Use RCTIME as Jon does.
Or if you insist, accept this also as a natural variation in analog
components and include a loop to send out pings until a result other than
zero is achieved. Expect to require a lot of pings sometimes to get a signal
valid range. I don't recommend this, understand. I'm just reporting my
results with this technique.
3. An equally simple 18000 (or so). No echo was detected. This is a valid
answer that means the nearest target is out of range.
4. Variation of one or two clocks up or down. Sometimes called "jitter", but
most of this is just the natural effect of examining data from an analog
event measured to a spurious digital precision. Nothing happening out there
is known to a resolution of two microseconds. Don't even bother looking at
the data until it's been reduced to the practical precision of half an inch
or so. Or centimeters if you prefer metric.
5. Variation of some multiple of 12 to 13 clocks up or down. Caused by
lock-up with the acoustic waveform occurring one or two cycles either way.
Or three or four. Not only natural, but inherent in any "interesting"
environment. That is, one where we're measuring an unknown reality and
attempting to learn about it from the sensor data. We can avoid these
cycle-to-cycle variations only in artificially ideal lab situations.
6. Big shifts in distance from one reading to the next. Ten inches, three
feet, what have you. The effect of a very wide beam angle on this sensor. If
the echo from a near field object at the fringe of the beam is marginal, we
might lock up on its echo one time in three or even less. When we do, it's
distance will be reported. When we don't, the stronger echo from the more
distant object will be reported. Both are valid distances, and your software
must recognize this as indicating multiple objects in the beam pattern, not
a sensor "error." This is characteristic of active sensors emitting a beam.
It's just more evident when the beam cone is as wide as this one.
Finally, if you're seriously bothered by the occasional missed reading
because of timing at the interface, you can add a pulse delay to the trigger
pulse using a 555 in monostable mode. This can be adjusted to push the
actual trigger pulse far enough after the PULSOUT command that even a slow
Stamp will always get to the next command before the Devantech can raise the
echo line. Then you can use the PULSIN command to measure the result. Not
all examples of the SRF04 will be subject to this problem. Production
variation of components, supplier changes, and all these things affect
analog circuits as well the environmental effects on a specific example once
you have it in hand. So if your example does seem to have occasional timing
problems at the interface, you can either ignore it or wire up a quick
solution. Gotta be an app note around on that somewhere. If not, I'll post a
circuit.
In this situation, you're still missing the first part of the travel time
for the acoustic pulse, because Devantech does not raise the echo line until
they turn on the receiver, and they have to wait to do that until the tail
end of the acoustic waveform passes the receiver. Plus a little bit to let
ringing die down I suppose. Basically, you'll still need to calibrate that
offset value I mentioned.
Good luck, and don't expect too much of a $35 sensor<g>.
Gary
P.S. Has anyone seen a $35 LASER rangefinder we can fool around with? I'd
even go to $40 or $41... Oh well<sigh>.
Bravo, bravissimo!
Dov Yassky
Sent: Tuesday, October 14, 2003 03:32
Subject: Re: [noparse][[/noparse]basicstamps] SRF04 Ultrasonic Range Finder
> From: "John Colonias" <jcolonias@i...>
> that I
be,
> readings.
> > Any better way ?
measurement.
distance
offset
what
published
tabletop
beam
but
I
creating
that
seem
> erratic to us.
of
integer
getting
this
and
guy
be
plain
case.
six
doesn't
if
sensor
Stamp
At
explains
peak.
a
vary
microseconds
not
you
gets
feel
good
the
are
is
convenience,
routine
down
reading
interface.
unit
a
duty
doubt
PULSIN,
will
> echo line.
and
a
> next of the SRF04:
were
this
does.
signal
but
there
inch
If
we
software
not
beam.
trigger
the
once
timing
a
> circuit.
until
> Gary
Thanks for taking the time to reply in such a detailed manner. I agree with you
that
averaging in not the right way. Actually, I did disect the code and wrote a
better
averaging algorithm , but it was useless. The erroneous answers I was referring
to
were that they jumped around. One reading would be preety close to the actujal
distance, the next almost 200% of, then the next pretty close to the previous,
etc.
That lead to believe that it would be better to selectively ignore those
readings that
deviate so much from a norm.
I really dont expect great accuracy from a $35 device, but I will take your
advices
and play with it a little more.
Thanks again,
John
that I
readings.
> Any better way ?
erratic to us.
echo line.
next of the SRF04:
circuit.
Gary
> The erroneous answers I was referring to were that they jumped
> around. One reading would be preety close to the actujal distance,
> previous, etc. That lead to believe that it would be better to
> selectively ignore those readings that deviate so much from a norm.
Well, you could ignore the readings in a range that is not of interest.
(That is, you could deal only with the closer returns for example.) Or you
could treat them both as targets to evaluate. That's what we do in
significant sensor applications.
In your test situation, make sure you have that completely flat test bench I
mentioned, and that the target is a fairly large flat plate. I'm betting one
or the other distance reading will stop appearing once that's the case.
The situation you describe is the result I got when secondary targets in the
cone of the emitter were returning echos as well. Sometimes the primary
would return the echo that locked up the PLL in the receiver, and sometimes
one or the other secondary target would generate the lock-up.
Gary
wrote:
> Help! Help!
> accurate.
John,
I feel compelled to reply if for nothing else to complete some of the
comments.
The SRF04 is not a PLL based unit (not hardware anyway, and most
certainly not software). So the PLL acquisition time does not apply
to it (and 3 cycles is certainly the lowest acquisition time - 1
extra for discrimination). It is actually based on counting
techniques (open loop in nature). Eight cycles is what was previously
used in actual PLL-based devices (such as the Polaroid ranger).
Devantech probably just figure (empirically) this was a good average
number for the counting technique. If I read their code right, the
SRF04 is nothing more than a tuned frequency counter.
The main reason for erroneous readings should be the sample rate if
nothing else. The BS2 samples from what I gather here at 25usec,
which is not really that inadequate for something that travels at
74usec/in (approx). A PIC would give a better resolution at 1-2usec.
But even with the BS2, if you were at the theoretical limit
(~3.5cm),that is only 25% variation (and gets better as your distance
increases).
Now, I believe the 25usec instruction cycle time is average. The BS2
is not really good for accurate timing because everything is
interpreted (i.e., you have no real control of the timing). An MCU is
ideal for something like this because you can control the timing down
to the cycle time. Anyway, averaging is simple but as was mentioned
it is not the proper way to interpret the signal. Mainly, because if
nothing else you will be averaging the own measurement system error
as well as the multi-path signal error. God knows what answer you get?
In a good receiver system (where the measurement system is
consistent - precise) your main source of error is the signal
environment. You already know the signal statistics since you're
generating it, you also can estimate the environment and thus create
a good detector (discriminator) for the new statistics. In any case,
a good trick used in such systems is the median. This is nothing else
than accumulating returns in different 'bins' and selecting the one
with the most (same as a histogram). On a reliable system (note that
I would not consider the BS2 timing as reliable - or repeatable I
should say), this method 'throws' out the outliers and uses the
strongest return. Not by signal strength, which gives you the closest
one (most likely a non-primary path), but by statistical strength.
This is used in almost any pulsed radar detection scheme (for clutter
reduction and many other things) but it is much more complex than
this description. The sampling rate must be enough to guarantee
return at maximum distance (i.e. power), the pulse width gives you
the best resolution (with no additional signal processing), and all
this have to be selected so the samples can be considered
statistically independent to some degree.
I know this is far more than the original question, but I felt the
need to complete an other wise very good answer.
Langue.
suggested below. The unit is "noisy" (readings will bounce around a
bit) so it is best to take several samples and average.
-- Jon Williams
-- Dallas Office
From: languer [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=B8QgwlnjUd6u8sw-1OATyB9rYO0pVYYS7z5RZnmOdlMUsJ1IGv97QH8sqG0tBlIyI80EaVHiEm78mhYq3tIzB-rDbkw]langue_rodriguez@m...[/url
Sent: Wednesday, October 15, 2003 4:36 PM
Subject: [noparse][[/noparse]basicstamps] Re: SRF04 Ultrasonic Range Finder
--- In basicstamps@yahoogroups.com, "John Colonias" <jcolonias@i...>
wrote:
> Help! Help!
> accurate.
John,
comments.
increases).
Langue.
abuse@p....
wrote:
> Both RCTIME and PULSIN deliver 2 uSec resolution, not 25 uSec as
> -- Jon Williams
> -- Dallas Office
I stand corrected, 2usec resolution is right. In my mind (not really
knowing how the tokens in the Stamp are structured), what you do not
have control over is the instruction timing. Once the instruction is
initiated and the pulse goes out you can discriminate between pulses
2usec apart, but you can not tell the overall return with such
accuracy (i.e. the time from the pulse initiation 'PULSOUT' to the
actual time the measurement starts 'RCTIME'). Or maybe you can?
langue.
timed by some Stamp users but are usually not useful nor required. The
tricky part about the SRF04 is that the setup time for PULSIN on the BS2
and BS2e can take longer than the delay between the trigger and the
front-end of the echo input -- so the low-to-high transition is missed.
Hence the use of RCTIME with the BS2 and BS2e, which is just looking
(the way we use it in the demo) for a high-to-low transition.
-- Jon Williams
-- Dallas Office
From: languer [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=h3KGNHY4jBzLZUFrlCPFtoXfV1rU2tABj5FaazLq5Xv6p4a5MEDsZSjredi4PEbTnICAnw92AtTpyEZFqLPtAVpyKRPh2Q]langue_rodriguez@m...[/url
Sent: Wednesday, October 15, 2003 6:08 PM
--- In basicstamps@yahoogroups.com, "Jon Williams" <jwilliams@p...>
> -- Jon Williams
> -- Dallas Office
langue.
abuse@p....
is ready to accept an input pulse is close to 240 microseconds. At
1100 feet per second, sound can travel about 3 inches during that
dead time.
The time that the stamp interpreter takes to read the commands is
quite deterministic. There is only a small dependence on position in
memory and exact values of pin numbers etc.
RCtime is a little faster, 220 microseconds. I have timing data I
collected as well as some that Steve Parkis contributed, posted at
http://www.emesystems.com/BS2speed.htm
Input commands like PULSIN and RCtime were a little tricky. I
measured those latencies by feeding the Stamp pin a high frequency
signal, so it would trigger ASAP.
An range finder needs to be calibrated empirically. But it should
come out pretty close to theory!
-- Tracy
>> -- Jon Williams
>> -- Dallas Office
>langue.
> to it [noparse][[/noparse]...] It is actually based on counting techniques [noparse][[/noparse]...]
Langue's comments made me curious enough to dig up the design material for
the Devantech unit. The schematic is a curious blend of digital and analog
circuit techniques. The designer's own comments are available at
http://makeashorterlink.com/?P4E921A36 and you can link to the PIC code and
the schematic from that page if you'd like to see it also.
As Langue says, the designer does not use a PLL IC, which caught me by
surprise. [noparse][[/noparse]Feel free to delete all after if you don't give a hoot how
Devantech did their sonar<g>.] He simply amplifies the signal from the
piezoelectric transducer with a couple of op-amps in series and then runs an
LM311 comparator on the result. The digital output from that chip is watched
by the PIC microcontroller. It times the interval between falling edges --
the high-to-low transitions -- and accepts anything between 22 and 30
microseconds as being an echo of the eight square-wave pulses he just
transmitted. If he gets three transitions in a row, spaced appropriately, he
calls it a valid echo of his pulse. Any missed edge, and he restarts the
count.
Looking at the schematic in conjunction with the code, it is not really a
frequency counter, but I can see how it looked like one from the PIC code
with no schematic. It wouldn't take much of a change to use it that way, but
he never really produces a frequency except by inference, because he will
accept the transitions created by anything from 33 kHz to 45 kHz. Three
consecutive transitions, or cycles. Just like a PLL.
Like most designs seen for the first time, this technique puzzled me at
first. He does "acquire" in the sense a digital designer might use the word,
but it's nothing like the phase lock that is meant by acquisition in an
analog context. It's rather like treating the signal as acoustic bits. It's
reminiscent of our old delay-line memories, where you transmit the bits you
want to remember and then catch them when they come back and re-transmit
them. [noparse][[/noparse]See your local Smithsonian...] Makes me wonder if this guy is my age
or just successfully re-invented a smallish wheel.
Actually, I'm still puzzled about his reasons after thinking about it. PLL's
are not priced like resistors, but they're pretty cheap chips, and emitting
a square wave signal as a sensor does interesting things to your return in
different conditions. My doctor sometimes uses the word that way for my test
results: "Ah. This is interesting..."
But basically, his objective was to make a smaller unit than the Polaroid at
lower cost, and it works. So he did his job. He takes longer than a PLL to
lock up in noisy conditions (at least I think so after a quick review), but
he carefully specifies a lack of interest in ranges where that is likely to
be the case. (Not that he puts it that way.) In other words, he may have
used a technique that cost him range, but he decided the grapes were sour
that far out on the vine anyway.
The only performance objective was to reduce the minimum range compared to
the Polaroid Ranger. Minimum. Not maximum range. Polaroid uses a much longer
blanking interval, I gather. He avoided that necessity by observing that any
return from short range is a much stronger signal than the ringing from the
nearby emitter. (In this context, "ringing" actually means the mechanical
vibrations that continue after the powered pulses have quit.) So instead of
blanking until that ringing quits, he substituted a period of very reduced
sensitivity that gradually returns to full sensitivity. Very nice.
I'm sure the misunderstanding here arose from that code listing without a
schematic. Jon Williams already has mentioned the actual speed of the BS2.
And of course, it's not the BS2 doing any of that stuff the code describes,
it's the other microcontroller -- the one on the SRF-04 board itself. You're
right that it does sample though.
The code mentions a 25 usec cycle, but it's referring to the time between
transitions from the LM311 while observing a valid signal. While waiting, it
samples at 2 usec intervals. Hmmm. Actually, this is very interesting... I
had started to say that his code is vulnerable to higher frequencies being
misrecognized as valid, because he samples every two usec while waiting for
a transition, but he goes away for fifteen usec or so every time he catchs a
transition. A transition during that period will be missed. That would be
another defect of not using a PLL, but I went back to re-read the code
before making that assertion...
When I did, I spotted a comment I missed the first time. Suddenly I'm not
puzzled any more. The SRF-04 does not do any frequency checks at all. At
least not in the code. Could, but does not. All that stuff about counting
three bits -- all that was hypothetical. The code is there, but what he
used for the production model is a single transition from the comparator. He
relies on the piezo transducer to keep signals of the wrong frequency from
reaching the LM311. So as soon as he gets that first transition, he drops
the echo line. Reporting what would be a phase lock condition in a PLL, but
since he doesn't wait for any fancy shmancy lock up, he won't be affected by
all that three-cycle stuff, will he? Free at last of analog nonsense! Well,
not really. The world is analog. Suck it up.
This just means all that stuff about phase-locked loops comes back into
play, but in an interesting way I admit. Such circuits were conceived in the
early twentieth century as a way to achieve the behavior of a wine glass in
the presence of a strong acoustic signal, or the waves in a tidal race like
the Bay of Fundy, or what have you: the ability of some objects to achieve
phase resonance with an impinging energy source. And this designer is saying
that he chose (or was given as a precondition) a piezoelectric component
with a strong notch, a very narrow band of frequencies for which it will
resonate and produce an output signal. I can't find a spec on that piece, so
we'll have to take his word for it -- but it's a credible assertion. (And
the device works sitting here on my desk, so...)
On the other hand, I can't think of any reason why such a device would
escape the same limitations and sources of error as a conventional PLL,
which is derived from those physical phenomena after all. But I had fun
trying<g>. Sadly, we're back to the original problem of phase lock, and
which cycle of the echo is going to be "caught" -- it's just an
electro-mechanical origin instead of a modern PLL circuit.
Me too, Langue. We've gone far off the basic question, which was "why do I
get funky answers from my SRF-04?" if I remember correctly, but personally
I'm glad we did. I understand my unit a lot better now after reviewing the
design material.
Did you catch all that, John? We said: "Funky answers? Murphy's Law." None
of the rest matters unless you also wanted to know to how it worked.
Gary
I have been reading all the materail that you guys have been writing and I
have been experimenting at the same time, because it seems like that one has to
empirically "tune" his device to perform according to specs.
So my results are the following: The SRF-04 gives bursts of consisted readings
at
perhaps two or three levels. For example, I set up the Bot at a distance of
exactly
1.0 ft from a wall. The SRF-04 produced 4 readings showing 9.6" and 3 readings
showing 11.8". Well, encouraged, I changed the distance to 2 ft. and expected a
reading of 19.2". I did get 2 readings of 19.2 and 3 readings of 23.8.
I played with a lot of various conditions and all produced similar results. My
strategy, then is to create stacks of readings, maybe 8-10 and set them up in
similar
piles. Then choose the one reading that has the most hits.
I am very pleased with the device now that I understand better its
idiosyncrasies.
Thanks to all those who have contributed to this understanding. Once, I have it
tuned I will report my results.
John
count.
design material.
Gary
consecutive readings that agree<G>. With a complex target, it is possible
to get reflections and echos back that are confusing. I built my own
doppler radar and found that I had seriously bouncing data. I built a
coincidence counter, where if it found two speeds that agreed, it would
display the speeds. The 2 coincidence indicator worked "better," but was
still insufficient. It was at that point I received the police radar and
found out about the 5 consecutive readings.
Though my radars were looking for speed instead of range, I would think that
the problems would be similar.
From: Gary W. Sims [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=S84mL7DUU0D09d_w6d97_WxydiHoODIE8MQhzCPRxlyE63AO2L2d24NicwCjxZDi1ILEfgLudtKkyI9W1fAPNw]simsgw@c...[/url
Sent: Wednesday, October 15, 2003 4:06 PM
> The erroneous answers I was referring to were that they jumped around.
> One reading would be preety close to the actujal distance, the next
> almost 200% of, then the next pretty close to the previous, etc. That
Gary
Jon
tomorrow.
John
Here's the link:
-- Jon Williams
-- Dallas Office
From: John Colonias [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=VfGMzVCMiq4pgKjdqDD1Jw60p-VaIX5TIFeCWB8btuZ75RxKMCYV2Cs5QfAevltW97naqHNOH1hpJNT0ZqxnsLd-]jcolonias@i...[/url
Help! Help!
accurate.
is the following:
earlier)
Main:
DEBUG MoveTo, 15, 3
temp = rawDist
DEBUG MoveTo, 15, 4
DEBUG MoveTo, 15, 5
GOTO main
and over,
abuse@p....
