Is a stamp 2 quick enough?....
in this program below, i have it setup to inject fuel from a fuel
injector that is triggered by input 15 going high which is a magnetic
coil pick up with a 10k resistor from the input pin going to 5+ ...
when i have this program running on my engine it will idle and pull
up to around 1500~2000 rpm's (25 ~ 33 times a second input15 is being
pulled high) but once i give it full thottle or 3/4''s thottle it
will start to rev up then die and rev up and die, but i tried fooling
around with the pulseout command to have it open up more to alow more
fuel into the engine but for some reason still acts the same, am
starting to think that ither the stamp isnt keeping up with magnetic
pick up coil, or could i be over driveing the input coil with the
engien rev'ing up so high it pulses to much current/voltage into the
input15...... or is my stamp not being able to be triggered quickley
enoguh so it can open injector and look back to it self once
more .... ive heard from other people stamp 2 can only go so fast but
i figure if im runing my engine with in 5000~6000 rpm range that it
should be able to see the input pin, trigger the sub routine, read
the thottle postion then do the lookup command for the correct pulse
for the injector and loop back to its self agian....
another question would be , in dealing with magnetic pick up coils
and interfaceing them into the stamp, i probley need a better way to
interface the two, in low rpm's it works fine but i have no idea how
to tell if the stamp is realling reading every time the input is high
then low agian or if its "skipping" sometimes across the coil
pickup....
also befor i forget... on the injector, i have a NPN power swithcing
transistor to switch the state of the injector off/on , i have it
setup where the base is pluged directly into the stamps output pin,
the collector pluged into the ground and the emitter pluged into the
injector and the other wire for injector is pluged into 12+ dc...
hopefully someone can help me with this it sucks to see it my
invention work but still have bugs in it... let me know what u guys
think...
Sean...
'{$STAMP BS2}
TB_POS VAR BYTE
X VAR WORD
x0 CON 1300
x1 CON 1700
x2 CON 2000
x3 CON 3000
x4 CON 4000
x5 CON 4000
x6 CON 5000
x7 CON 6000
x8 CON 8000
x9 CON 10000
x10 CON 12000
x11 CON 13000
x12 CON 14000
MAIN:
input 15
IF IN15 = 1 THEN tb
goto main
TB:
PULSIN 8, 1, TB_POS
lookup TB_POS min 5 max 18 - 5,
[noparse][[/noparse]x0,x1,x2,x3,x4,x5,x6,x7,x8,x9,x10,x11,x12], x
pulsout 7,x
GOTO MAIN
**********end of programm
pickup....
think...
Sean...
'{$STAMP BS2}
TB_POS VAR BYTE
X VAR WORD
x0 CON 1300
x1 CON 1700
x2 CON 2000
x3 CON 3000
x4 CON 4000
x5 CON 4000
x6 CON 5000
x7 CON 6000
x8 CON 8000
x9 CON 10000
x10 CON 12000
x11 CON 13000
x12 CON 14000
MAIN:
input 15
IF IN15 = 1 THEN tb
goto main
TB:
PULSIN 8, 1, TB_POS
pulsout 7,x
GOTO MAIN
if it gets any higher RPM's? I ask this because an ECU not only reads
RPM but air flow as well. It could be via speed density or mass flow.
Your program doesn't read any of this so the engine runs lean.
Just a thought. Good luck.
--- In basicstamps@yahoogroups.com, "djrevolution99"
magnetic
being
fooling
more
magnetic
the
quickley
but
pulse
to
how
high
> pickup....
swithcing
the
> think...
> Sean...
> '{$STAMP BS2}
> TB_POS VAR BYTE
> X VAR WORD
> x0 CON 1300
> x1 CON 1700
> x2 CON 2000
> x3 CON 3000
> x4 CON 4000
> x5 CON 4000
> x6 CON 5000
> x7 CON 6000
> x8 CON 8000
> x9 CON 10000
> x10 CON 12000
> x11 CON 13000
> x12 CON 14000
> MAIN:
> input 15
> IF IN15 = 1 THEN tb
> goto main
> TB:
> PULSIN 8, 1, TB_POS
> pulsout 7,x
> GOTO MAIN
cozz.home@v... writes:
Have you tried grounding the injector apart from the transistor? See
Don't ground it for very long though, inductors are not meant to continuously
pass current. On a 4 cylinder gasoline engine, the maximum injector pulse
width is in the neighborhood of 25 mS, give or take.....it's been a few years
since I actually looked at the max on time.
drops as well. It is necessary to condition this signal so that it is the
same at all rpms. (one-shot). You need to check the switching speed of the
transistor you are using to trigger the injector and verify it can switch at
the speeds you are running. You may need to use a more complex circuit to
turn off the device more quickly (possibly a circuit to applay a reverse
voltage on switch off to force a more rapid and controlled turn off), and
you should isolate the base from the stamp with as a minimum a resistor so
as to not require excess current under all switching conditions. This type
of control is more complex than initially conceived and you should emulate
the control without stamp control and then interface the stamp to give the
same operational results. A large value capacitor is typically used to
supply initial current to get a very quick turn on.
jim
http://www.geocities.com/jimforkin2003/
From: djrevolution99 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=lU-GXa86F3aSdYhZaY3TYlTh7Uy5Q0AGu5CUtU1qXcuIoUA15L77C0biT8LtLmSLsThifU3R4q5YYtMON3I]djrevolution99@y...[/url
Sent: Monday, October 06, 2003 6:11 PM
Subject: [noparse][[/noparse]basicstamps] Is a stamp 2 quick enough?....
pickup....
think...
Sean...
'{$STAMP BS2}
TB_POS VAR BYTE
X VAR WORD
x0 CON 1300
x1 CON 1700
x2 CON 2000
x3 CON 3000
x4 CON 4000
x5 CON 4000
x6 CON 5000
x7 CON 6000
x8 CON 8000
x9 CON 10000
x10 CON 12000
x11 CON 13000
x12 CON 14000
MAIN:
input 15
IF IN15 = 1 THEN tb
goto main
TB:
PULSIN 8, 1, TB_POS
pulsout 7,x
GOTO MAIN
