DEBUG qusetion....
my question is this, in my sample program below, i want to be able to
debug how often input 15 gose high, in other words i want to monitor
it has how fast the program is running... the reason for this is , is
that i want to see how many times a minite , input 15 gose high (BUT!
not useing the count command , sence that takes time away from the
program running rest of the code...)
'{$STAMP BS2}
TB_POS VAR BYTE
X VAR WORD
x0 CON 1000
x1 CON 2000
x2 CON 3000
x3 CON 4000
x4 CON 5000
x5 CON 6000
x6 CON 7000
x7 CON 7500
x8 CON 8000
x9 CON 8500
x10 CON 9000
x11 CON 9500
x12 CON 10000
MAIN:
INPUT 15
IF IN15 = 1 THEN TB
GOTO MAIN
TB:
PULSIN 8, 1, TB_POS
lookup TB_POS min 5 max 18 - 5,
[noparse][[/noparse]x0,x1,x2,x3,x4,x5,x6,x7,x8,x9,x10,x11,x12], x
pulsout 7,x
GOTO MAIN
*** u see i have the program run "TB" once input 15 gose high ... so
every time my engine's crank sensor triggers the input 15 to cause it
high, it will then run the sub program "TB" then look back to
the "MAIN" program....
Sean....
'{$STAMP BS2}
TB_POS VAR BYTE
X VAR WORD
x0 CON 1000
x1 CON 2000
x2 CON 3000
x3 CON 4000
x4 CON 5000
x5 CON 6000
x6 CON 7000
x7 CON 7500
x8 CON 8000
x9 CON 8500
x10 CON 9000
x11 CON 9500
x12 CON 10000
MAIN:
INPUT 15
IF IN15 = 1 THEN TB
GOTO MAIN
TB:
PULSIN 8, 1, TB_POS
pulsout 7,x
GOTO MAIN
Sean....
djrevolution99@y... writes:
If I am not mistaken (others please chime in) debug itself takes time from
your program, lots of time in fact.
If you have access to an o-scope connect it to pin 15 and watch it for one
period, and multiply that result times 60. This is assuming you are checking
pin 15 at a constant engine speed.
Ken
I think you want to detect when the in15 goes from low to high. The
way you have it now, it detects the high state, and that might cause
the loop to run more than once per revolution. That depends on the
engine timing. Here is a debouncing routine:
main:
main1:
IF in15 THEN main1 ' stay in this loop while in15 is high
main0: ' now it is low
BRANCH in15,[noparse][[/noparse]main0,TB] ' stay in this loop while in15 is low
' branch to TB when it goes high
TB:
PULSIN 8, 1, TB_POS
pulsout 7,x
debug "X" '<---- this shows one character on screen
GOTO MAIN
The debug command does take a bit of time, printing one X per
revolution. The timing question is, how fast is your engine running?
How long are the pulses you expect? There are people on this list
who are much more qualified than I am to advise about engine timing.
The PULSIN command on the BS2 will wait for up to 0.13 second for the
start of the TB_POS, and the pulse on TB_POS can be up to 0.13
seconds long. Does the pulse you expect fall within those limits?
If not, you will have to take a different approach.
-- regards,
Tracy
>'{$STAMP BS2}
>TB_POS VAR BYTE
>X VAR WORD
>x0 CON 1000
>x1 CON 2000
>x2 CON 3000
>x3 CON 4000
>x4 CON 5000
>x5 CON 6000
>x6 CON 7000
>x7 CON 7500
>x8 CON 8000
>x9 CON 8500
>x10 CON 9000
>x11 CON 9500
>x12 CON 10000
>MAIN:
>INPUT 15
>IF IN15 = 1 THEN TB
>GOTO MAIN
>TB:
>PULSIN 8, 1, TB_POS
>pulsout 7,x
>GOTO MAIN
>Sean....
It looks like what you want is to detect the status of PIN 8, active
or not. In this case PULSIN is not proper for your application because
PULSIN works like a stopwatch counting the the timing between two
states. What you need is just an INPUT command paired with IF
statement or DO - LOOP
main:
IF IN15 = 1 THEN TB
GOTO main 'Sometime you need to replace this with IF IN15 = 0 THEN
'main, if for strange reason it breaks away from the loop
main:
DO
LOOP UNTIL IN15 = 1
GOTO TB 'This may not be necessary if TB is just below it
But from my experience with PBasic 2.5 those two examples sometime
just break away from the loop for no reason especially when the
program gets larger. The IF statement can't seem to exist on its own.
It needs the comparison between the two states like 'IF IN15 = 1'. But
when IN15 = 0 and if you don't specify it what to do, the program got
confused. Even monitoring the PIN status with a scope, the program
just breakaway from the loop while the status of the PIN didn't
change. Perhaps guys from Parallax could explain this strange behaviour.
Cheers,
- Johari
--- In basicstamps@yahoogroups.com, "djrevolution99"
> '{$STAMP BS2}
> TB_POS VAR BYTE
> X VAR WORD
> x0 CON 1000
> x1 CON 2000
> x2 CON 3000
> x3 CON 4000
> x4 CON 5000
> x5 CON 6000
> x6 CON 7000
> x7 CON 7500
> x8 CON 8000
> x9 CON 8500
> x10 CON 9000
> x11 CON 9500
> x12 CON 10000
> MAIN:
> INPUT 15
> IF IN15 = 1 THEN TB
> GOTO MAIN
> TB:
> PULSIN 8, 1, TB_POS
> pulsout 7,x
> GOTO MAIN
> Sean....
