Dimming a light with a photo sensor — Parallax Forums
edited 2003-10-08 03:08 in General Discussion
Hey all. Extreme newbie here. I searched the forum and found a few
posts that sort of deal with what I'm trying to accomplish, and I'm
just hoping that maybe someone can point me in the direction of some
basic sample code that somewhat resembles what I'm going for (my
PBasic knowledge is very slim, but I'm trying).
Basically, I would like to be able to dim a small light (maybe a small
flashlight or something similar that doesn't suck much power) using a
photo sensor. The idea is that when it's bright outside, the light
inside will barely be on, and when it's night time, full power will
run through it, along with maybe 10-12 variances inbetween. I figure
the actual mechanics of such a setup to be somewhat simple, but it's
the code part that's freaking me out. I'm not asking anyone to write
it for me or anything, but if anyone knows where to find the code for
something similar in concept, I'd be extremely greatful for it. I
haven't been able to really find anything for it on the net (as
opposed to my next project, a wearable midi interface, there's a good
deal of info for that on the net), so many thanks to any who can help.
ry
    edited 2003-10-04 21:33
    Here's an idea...
    Use RCTIME to read the photocell and the delay in reading is used to
    control the "on" portion of a synthesized PWM wave. In psuedocode,
    something like this:
    Main:
    HIGH LightCtrl
    RCTIME photocell, 1, anyWordVar
    LOW LightCtrl
    PAUSE x
    GOTO Main
    You can use the output pin called LightCtrl to control a small MOSFET
    that switches the current for the light bulb.
    The idea is that the dimmer the light, the longer the RCTIME function
    will take to return a value, so the on portion of the PWM waveform will
    be longer. You'll have to experiment with the PAUSE value. Note that
    PAUSE 0 will pause for about 100 microseconds.
    -- Jon Williams
    -- Dallas Office (but not at home this weekend ... so I'm working)
    From: r_couldrey [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=lMTymPb1r9toXPv3uflftJlA1kvy_IHXEIJQtlS31euvx4z6Rc-t-aTsB4u55OFj5sr4EkzUNbFTJ6iCtsc]r_couldrey@y...[/url
    Sent: Saturday, October 04, 2003 12:40 PM
    Subject: [noparse][[/noparse]basicstamps] Dimming a light with a photo sensor
    ry
    Your use of Yahoo! Groups is subject to
    This message has been scanned by WebShield. Please report SPAM to
    abuse@p....
    edited 2003-10-04 21:40
    In a message dated 10/4/2003 1:22:40 PM Pacific Daylight Time,
    r_couldrey@y... writes:
    I figure
    Since it sounds like you are willing to do some work (not expecting the code
    to be written for you) start with downloading the stamp manual from the
    parallax web-sight. You can also download a tutorial that will tell you and show
    you
    how to use the RCTIME command.
    This command will return a numerical value based on the resistance of your
    sensor. You can then output PWM to your lamp or LED based on the value returned
    from the RCTIME command.
    If this is not enought information to get you going, don't hesitate to write
    back.
    Ken
    edited 2003-10-04 23:16
    In a message dated 10/4/2003 2:00:11 PM Pacific Daylight Time,
    jwilliams@p... writes:
    Main:
    HIGH LightCtrl
    LOW LightCtrl
    PAUSE x
    GOTO Main
    Jon,
    That's brilliant, but you knew that.....
    Thanks a lot, I'm gonna give this a shot with LEDs this week.
    ry
    --- In basicstamps@yahoogroups.com, "Jon Williams" <jwilliams@p...>
    wrote:
    > Here's an idea...
    > Main:
    > HIGH LightCtrl
    > LOW LightCtrl
    > PAUSE x
    > GOTO Main
    MOSFET
    function
    will
    that
    > -- Jon Williams
    > From: r_couldrey [noparse][[/noparse]mailto:r_couldrey@y...]
    small
    a
    for
    good
    help.
    > ry
    Subject
    > abuse@p...
