BS2 Without Stamp Stack
I would like to use my SX28AC/DP Basic Stamp chip without the Stamp Stack II
provided by www.HVWTech.com <http://www.hvwtech.com/> . I've built a small
PCB which has only the SX28AC/DP chip attached to it and I'm attaching it to
the breadboard which is set up exactly as it was when I was using the Stamp
Stack II (All pins, buttons, the power supply and the LCD. are in the same
place). I've downloaded my program onto the chip (using the Stamp Stack),
carefully connected the IO pins I'm using, provided 5V continuous power to
Vdd and Ground to Vss. But the program does not seem to be running.
Obviously nothing is showing on the LCD but the IO pins don't change as they
should either. The LCD is powered up and working it is just that it is not
receiving input from my program. What am I missing? This is a pretty basic
program that drives an LCD. I've included the program below but the problem
should not be the program. The program runs fine when connected through the
Stamp Stack. Do I need to connect a resonator to OSC1 and OSC2? Is there
some sort of power up sequence I'm not following? Remember, I'm new to
electronics and BS programming so I may be missing something that is plain
as day to those of you who are more experienced.
Thanks for your help!
Scott
'{$STAMP BS2sx}
'{$PBASIC 2.5}
Lock VAR Bit 'Used to only count button press once per press
Lock = 0
Trip VAR Nib 'Holds which round's score is to be Dsplyed
Trip = 100
TTShots VAR Word
TTShots = 0
TTHits VAR Word
TTHits = 0
TTPct VAR Word
TTPct = 0
'RESET VAR Word 'Count how long reset button is held
INPUT 0 'Dsply button
HIGH 0
INPUT 2 'Shot button
HIGH 2
INPUT 3 'Reset or Alt button
HIGH 3
INPUT 4 'Hit button
HIGH 4
RS PIN 5
RW PIN 6
E PIN 7
Hole DATA @200, $0E,$1F,$1F,$1F,$1F,$1F,$0E,$00 '@100 stores starting at
location 100
CGRam CON $40 ' Custom character RAM
SNDCHAR VAR Byte 'Char to write
LoopCount VAR Byte 'Used exit wait if wait is stuck
ii VAR Nib 'Used for char write loop
HOLD1 VAR Word 'Holds the number of 50ms loops clear button was held
pressed
Dsply VAR Bit 'Change what Dsply holds
Dsply = 0 'Default to Shots Hits
INIT:
PAUSE 20
DIRH = %11111111 ' setup pins for LCD
OUTPUT 5'RS
OUTPUT 6'RW
OUTPUT 7'E
LOW RS
LOW RW
OUTD = %0011
PULSOUT E,1
PAUSE 5
OUTD = %0011
PULSOUT E,1
PAUSE 100
OUTD = %0011
PULSOUT E,1
OUTH = %00001100'00001111
PULSOUT E,1
OUTH = %00000001
PULSOUT E,1
OUTH = %00000010
PULSOUT E,1
OUTH = %00000010
PULSOUT E,1
PAUSE 100
GOSUB INTRO
PAUSE 500
'DEBUG "INIT"
'Clear the LCD and Post Score for given round
GOSUB CLEAR_LCD
GOSUB CALC_PCT
MAINLOOP:
'PAUSE 1000
GOSUB Check_Shot
GOSUB Check_Hit
GOSUB Check_Reset
GOSUB Check_Alt
GOTO MAINLOOP
Check_Shot:
IF(IN0 > 0 AND IN2 > 0 AND IN3 > 0 AND IN4 > 0) THEN DO_UNLOCK
IF (IN2 = 0 AND Lock = 0) THEN
Dsply = 0
GOSUB Add_Shot
ENDIF
RETURN
Check_Hit:
IF (IN4 = 0 AND Lock = 0) THEN
Dsply = 0
GOSUB Add_Hit
ENDIF
RETURN
Check_Reset:
IF (IN3 = 0 AND Lock = 0) THEN
Lock = 1
GOSUB DO_RESET
GOTO MAINLOOP 'Had to put in to prevent program auto reboot???
ENDIF
RETURN
Check_Alt:
'BUTTON 2,1,255,255,BtnWrk,1,Add_Shot
'pin,downstate,delay,rate,bytevariable,targetstate,address
IF (IN0 = 0 AND Lock = 0) THEN
Lock = 1
IF Dsply = 1 THEN
Dsply = 0'Show Shots Hits
ELSE
Dsply = 1'Show Pct
ENDIF
GOSUB Calc_Pct
ENDIF
GOTO MAINLOOP
Add_Shot:
'WRITE 1, 0
LOCK = 1
READ Trip, TTShots
TTShots = TTShots + 1
WRITE Trip, TTShots
'I VAR Byte
'FOR I = 1 TO TTShots
'FREQOUT 1,1500,1500,2500
'NEXT
GOSUB Calc_Pct
GOTO MAINLOOP
Add_Hit:
Lock = 1
READ Trip, TTShots
READ (Trip + 1), TTHits 'Changed to 2 from 1 because storing Word takes
2 bytes
TTHits = TTHits + 1 MAX TTShots 'Can't have more hits than shots
WRITE (Trip + 1), TTHits
'FREQOUT 1,750,2500
'FREQOUT 1,750,2500
GOSUB Calc_Pct
'Skip_Hit:
GOTO MAINLOOP
Calc_Pct:
READ Trip, TTShots
READ Trip+1,TTHits
'TTPct = ((TTHits * 100) / TTShots)
TTPct = (TTHits * 1000) / TTShots
'WRITE (Trip + 4), TTPct 'Can always calculate percent no need to store
GOSUB CLEAR_LCD
IF Dsply < 1 THEN
FOR ii=2 TO 0
SNDCHAR=TTShots DIG ii + 48 ' get jth digit, add 48 for ascii
GOSUB WRITE_TEXT ' put it on the lcd, not shown
NEXT
GOSUB POSITION_CURSOR
FOR ii=2 TO 0
SNDCHAR=TTHits DIG ii + 48 ' get jth digit, add 48 for ascii
NEXT
ELSE 'Show Percent
OUTH = %10000010
GOSUB POSITION_CURSOR_SEND
FOR ii=3 TO 0
SNDCHAR=TTPct DIG ii + 48 ' get jth digit, add 48 for ascii
IF ii = 1 THEN
SNDCHAR = %00101110'Period
GOSUB WRITE_TEXT
ENDIF
NEXT
SNDCHAR = %00100101'%
GOSUB WRITE_TEXT
ENDIF
'GOSUB Print
RETURN
DO_RESET:
WRITE Trip, 0 'TTShots
PAUSE 500
WRITE (Trip + 1), 0 'TTHits
PAUSE 500
'WRITE (Trip + 4), 0 'TTPct
'PAUSE 500
GOSUB CALC_PCT
RETURN
DO_UNLOCK:
LOCK = 0
RETURN
Print:
'DEBUG ? OUT15
'DEBUG ? OUT0
'DEBUG ? IN4,CR
'DEBUG ? IN3,CR
'DEBUG ? Lock, CR
RETURN
LCD
CODE
WAIT_LCD:
LoopCount = LoopCount + 1
LOW RS
HIGH RW
INPUT 15'IN DB7
IF IN15 = 1 AND LoopCount < 50 THEN WAIT_LCD
PULSOUT E,1
LOW RW
OUTPUT 15
LoopCount = 0
RETURN
CLEAR_LCD:
LOW RS
LOW RW
OUTH = %00000001
PULSOUT E,1
GOSUB WAIT_LCD
RETURN
WRITE_TEXT:
HIGH RS
LOW RW
OUTH = SNDCHAR
PULSOUT E,1
LOW RS
GOSUB WAIT_LCD
RETURN
MOVE_RIGHT:
LOW RS
LOW RW
OUTH = %00010000
PULSOUT E,1
GOSUB WAIT_LCD
RETURN
SHIFT_LEFT:
LOW RS
LOW RW
OUTH = %00011000
PULSOUT E,1
GOSUB WAIT_LCD
RETURN
POSITION_CURSOR:
LOW RS
LOW RW
OUTH = %10000101
PULSOUT E,1
GOSUB WAIT_LCD
RETURN
POSITION_CURSORB:
LOW RS
LOW RW
OUTH = %10001000
PULSOUT E,1
GOSUB WAIT_LCD
RETURN
POSITION_CURSOR_SEND:
LOW RS
LOW RW
OUTH = SNDCHAR
PULSOUT E,1
GOSUB WAIT_LCD
RETURN
INTRO:
HIGH RS ' prepare to write CG
data
LOW RW
SNDCHAR = CGRam ' point to CG RAM
addr VAR Byte ' address in EE and Dsply
FOR addr = HOLE TO HOLE + 7 ' build 4 custom chars
READ addr,SNDCHAR ' get byte from EEPROM
GOSUB WRITE_TEXT ' put into LCD CG RAM
NEXT
LOW RS
GOSUB POSITION_CURSORB
SNDCHAR = %01001000'H
GOSUB WRITE_TEXT
GOSUB SHIFT_LEFT
PAUSE 50
'GOSUB POSITION_CURSORB
SNDCHAR = %01001111'O
GOSUB WRITE_TEXT
GOSUB SHIFT_LEFT
PAUSE 50
SNDCHAR = %01010100'T
GOSUB WRITE_TEXT
GOSUB SHIFT_LEFT
PAUSE 50
SNDCHAR = %01010011'S
GOSUB WRITE_TEXT
GOSUB SHIFT_LEFT
PAUSE 50
GOSUB WRITE_TEXT
GOSUB SHIFT_LEFT
PAUSE 50
GOSUB WRITE_TEXT
GOSUB SHIFT_LEFT
PAUSE 50
GOSUB WRITE_TEXT
GOSUB SHIFT_LEFT
PAUSE 2000
SNDCHAR = %10001001'First O
SNDCHAR = %00000000'HOLE
GOSUB WRITE_TEXT
PAUSE 500
SNDCHAR = %10001101'Second O
GOSUB WRITE_TEXT
PAUSE 2000
GOSUB SHIFT_LEFT
PAUSE 50
GOSUB SHIFT_LEFT
PAUSE 50
GOSUB SHIFT_LEFT
PAUSE 50
GOSUB SHIFT_LEFT
PAUSE 50
GOSUB SHIFT_LEFT
PAUSE 50
GOSUB SHIFT_LEFT
PAUSE 50
GOSUB SHIFT_LEFT
PAUSE 50
GOSUB SHIFT_LEFT
PAUSE 50
RETURN
WRITE_PINS:
'DEBUG ? IN0
'DEBUG ? IN2
'DEBUG ? IN3
'DEBUG ? IN4
'PAUSE 500
'DEBUG "INS="
'DEBUG BIN ? INS, CR
'DEBUG "OUTS="
'DEBUG BIN ? OUTS, CR
'DEBUG "DIRS="
'DEBUG BIN ? DIRS, CR
'PAUSE 500
RETURN
Scott
'{$STAMP BS2sx}
'{$PBASIC 2.5}
Lock = 0
Trip = 100
TTShots VAR Word
TTShots = 0
TTHits VAR Word
TTHits = 0
TTPct VAR Word
TTPct = 0
HIGH 0
HIGH 2
HIGH 3
INPUT 4 'Hit button
HIGH 4
RS PIN 5
RW PIN 6
E PIN 7
location 100
pressed
INIT:
PAUSE 20
OUTPUT 5'RS
OUTPUT 6'RW
OUTPUT 7'E
LOW RS
LOW RW
OUTD = %0011
PULSOUT E,1
PAUSE 5
OUTD = %0011
PULSOUT E,1
PAUSE 100
OUTD = %0011
PULSOUT E,1
PULSOUT E,1
OUTH = %00000001
PULSOUT E,1
OUTH = %00000010
PULSOUT E,1
OUTH = %00000010
PULSOUT E,1
PAUSE 100
GOSUB INTRO
PAUSE 500
'DEBUG "INIT"
GOSUB CLEAR_LCD
GOSUB CALC_PCT
MAINLOOP:
'PAUSE 1000
GOSUB Check_Shot
GOSUB Check_Hit
GOSUB Check_Reset
GOSUB Check_Alt
GOTO MAINLOOP
Check_Shot:
Dsply = 0
GOSUB Add_Shot
ENDIF
RETURN
Check_Hit:
Dsply = 0
GOSUB Add_Hit
ENDIF
RETURN
Check_Reset:
Lock = 1
GOSUB DO_RESET
ENDIF
RETURN
Check_Alt:
Lock = 1
IF Dsply = 1 THEN
ELSE
Dsply = 1'Show Pct
ENDIF
GOSUB Calc_Pct
ENDIF
GOTO MAINLOOP
Add_Shot:
'WRITE 1, 0
LOCK = 1
READ Trip, TTShots
WRITE Trip, TTShots
'I VAR Byte
'NEXT
GOSUB Calc_Pct
GOTO MAINLOOP
Add_Hit:
Lock = 1
READ Trip, TTShots
2 bytes
'FREQOUT 1,750,2500
'FREQOUT 1,750,2500
GOSUB Calc_Pct
'Skip_Hit:
GOTO MAINLOOP
Calc_Pct:
READ Trip, TTShots
READ Trip+1,TTHits
GOSUB CLEAR_LCD
IF Dsply < 1 THEN
FOR ii=2 TO 0
NEXT
FOR ii=2 TO 0
NEXT
ELSE 'Show Percent
OUTH = %10000010
FOR ii=3 TO 0
IF ii = 1 THEN
GOSUB WRITE_TEXT
ENDIF
NEXT
GOSUB WRITE_TEXT
ENDIF
'GOSUB Print
RETURN
DO_RESET:
PAUSE 500
PAUSE 500
'PAUSE 500
GOSUB CALC_PCT
RETURN
DO_UNLOCK:
LOCK = 0
RETURN
Print:
'DEBUG ? OUT15
'DEBUG ? OUT0
'DEBUG ? IN4,CR
'DEBUG ? IN3,CR
'DEBUG ? Lock, CR
RETURN
LCD
CODE
WAIT_LCD:
LOW RS
HIGH RW
INPUT 15'IN DB7
PULSOUT E,1
LOW RW
OUTPUT 15
LoopCount = 0
RETURN
CLEAR_LCD:
LOW RS
LOW RW
OUTH = %00000001
PULSOUT E,1
GOSUB WAIT_LCD
RETURN
WRITE_TEXT:
HIGH RS
LOW RW
OUTH = SNDCHAR
PULSOUT E,1
LOW RS
GOSUB WAIT_LCD
RETURN
MOVE_RIGHT:
LOW RS
LOW RW
OUTH = %00010000
PULSOUT E,1
GOSUB WAIT_LCD
RETURN
SHIFT_LEFT:
LOW RS
LOW RW
OUTH = %00011000
PULSOUT E,1
GOSUB WAIT_LCD
RETURN
POSITION_CURSOR:
LOW RS
LOW RW
OUTH = %10000101
PULSOUT E,1
GOSUB WAIT_LCD
RETURN
POSITION_CURSORB:
LOW RS
LOW RW
OUTH = %10001000
PULSOUT E,1
GOSUB WAIT_LCD
RETURN
LOW RS
LOW RW
OUTH = SNDCHAR
PULSOUT E,1
GOSUB WAIT_LCD
RETURN
INTRO:
data
LOW RW
NEXT
LOW RS
GOSUB WRITE_TEXT
GOSUB SHIFT_LEFT
PAUSE 50
GOSUB WRITE_TEXT
GOSUB SHIFT_LEFT
PAUSE 50
GOSUB WRITE_TEXT
GOSUB SHIFT_LEFT
PAUSE 50
GOSUB WRITE_TEXT
GOSUB SHIFT_LEFT
PAUSE 50
GOSUB WRITE_TEXT
GOSUB SHIFT_LEFT
PAUSE 50
GOSUB WRITE_TEXT
GOSUB SHIFT_LEFT
PAUSE 50
GOSUB WRITE_TEXT
GOSUB SHIFT_LEFT
PAUSE 2000
GOSUB WRITE_TEXT
PAUSE 500
GOSUB WRITE_TEXT
PAUSE 2000
GOSUB SHIFT_LEFT
PAUSE 50
GOSUB SHIFT_LEFT
PAUSE 50
GOSUB SHIFT_LEFT
PAUSE 50
GOSUB SHIFT_LEFT
PAUSE 50
GOSUB SHIFT_LEFT
PAUSE 50
GOSUB SHIFT_LEFT
PAUSE 50
GOSUB SHIFT_LEFT
PAUSE 50
GOSUB SHIFT_LEFT
PAUSE 50
RETURN
WRITE_PINS:
'DEBUG ? IN0
'DEBUG ? IN2
'DEBUG ? IN3
'DEBUG ? IN4
'PAUSE 500
'DEBUG "INS="
'DEBUG "OUTS="
'DEBUG "DIRS="
'PAUSE 500
RETURN
programming connector and components (two caps) -- the rest are critical
to the operation of the Stamp. Remember that the Stamp is a
microcontroller so yes, it needs a clock source (resonator). And the
program is stored in an external EEPROM, so you need that too. You can
get schematics of our OEM BASIC Stamps (the parts the Stamp Stack is
built from) from our web site.
-- Jon Williams
-- Dallas Office
From: Scott Wilkinson [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Y9v87lmiUmiDg64UXz7tFaBrfgX53vTMttFnz4iM3e22WtArmvpXsJCnN3QVWBiuqlDIE7sKN3Flj27CUWdzdYrs]smwilkinson@e...[/url
Sent: Saturday, October 04, 2003 12:22 PM
Subject: [noparse][[/noparse]basicstamps] BS2 Without Stamp Stack
Stack II provided by www.HVWTech.com <http://www.hvwtech.com/> . I've
built a small PCB which has only the SX28AC/DP chip attached to it and
I'm attaching it to the breadboard which is set up exactly as it was
when I was using the Stamp Stack II (All pins, buttons, the power supply
and the LCD. are in the same place). I've downloaded my program onto
the chip (using the Stamp Stack), carefully connected the IO pins I'm
using, provided 5V continuous power to Vdd and Ground to Vss. But the
program does not seem to be running. Obviously nothing is showing on the
LCD but the IO pins don't change as they should either. The LCD is
powered up and working it is just that it is not receiving input from my
program. What am I missing? This is a pretty basic program that drives
an LCD. I've included the program below but the problem should not be
the program. The program runs fine when connected through the Stamp
plain
Scott
'{$STAMP BS2sx}
'{$PBASIC 2.5}
Lock = 0
Trip = 100
TTShots VAR Word
TTShots = 0
TTHits VAR Word
TTHits = 0
TTPct VAR Word
TTPct = 0
HIGH 0
HIGH 2
HIGH 3
INPUT 4 'Hit button
HIGH 4
RS PIN 5
RW PIN 6
E PIN 7
starting at
location 100
held
pressed
INIT:
PAUSE 20
OUTPUT 5'RS
OUTPUT 6'RW
OUTPUT 7'E
LOW RS
LOW RW
OUTD = %0011
PULSOUT E,1
PAUSE 5
OUTD = %0011
PULSOUT E,1
PAUSE 100
OUTD = %0011
PULSOUT E,1
PULSOUT E,1
OUTH = %00000001
PULSOUT E,1
OUTH = %00000010
PULSOUT E,1
OUTH = %00000010
PULSOUT E,1
PAUSE 100
GOSUB INTRO
PAUSE 500
'DEBUG "INIT"
GOSUB CLEAR_LCD
GOSUB CALC_PCT
MAINLOOP:
'PAUSE 1000
GOSUB Check_Shot
GOSUB Check_Hit
GOSUB Check_Reset
GOSUB Check_Alt
GOTO MAINLOOP
Check_Shot:
Dsply = 0
GOSUB Add_Shot
ENDIF
RETURN
Check_Hit:
Dsply = 0
GOSUB Add_Hit
ENDIF
RETURN
Check_Reset:
Lock = 1
GOSUB DO_RESET
ENDIF
RETURN
Check_Alt:
Lock = 1
IF Dsply = 1 THEN
ELSE
Dsply = 1'Show Pct
ENDIF
GOSUB Calc_Pct
ENDIF
GOTO MAINLOOP
Add_Shot:
'WRITE 1, 0
LOCK = 1
READ Trip, TTShots
WRITE Trip, TTShots
'I VAR Byte
'NEXT
GOSUB Calc_Pct
GOTO MAINLOOP
Add_Hit:
Lock = 1
READ Trip, TTShots
takes 2 bytes
'FREQOUT 1,750,2500
'FREQOUT 1,750,2500
GOSUB Calc_Pct
'Skip_Hit:
GOTO MAINLOOP
Calc_Pct:
READ Trip, TTShots
READ Trip+1,TTHits
store
GOSUB CLEAR_LCD
IF Dsply < 1 THEN
FOR ii=2 TO 0
NEXT
FOR ii=2 TO 0
NEXT
ELSE 'Show Percent
OUTH = %10000010
FOR ii=3 TO 0
IF ii = 1 THEN
GOSUB WRITE_TEXT
ENDIF
NEXT
GOSUB WRITE_TEXT
ENDIF
'GOSUB Print
RETURN
DO_RESET:
PAUSE 500
PAUSE 500
'PAUSE 500
GOSUB CALC_PCT
RETURN
DO_UNLOCK:
LOCK = 0
RETURN
Print:
'DEBUG ? OUT15
'DEBUG ? OUT0
'DEBUG ? IN4,CR
'DEBUG ? IN3,CR
'DEBUG ? Lock, CR
RETURN
LCD
CODE
WAIT_LCD:
LOW RS
HIGH RW
INPUT 15'IN DB7
PULSOUT E,1
LOW RW
OUTPUT 15
LoopCount = 0
RETURN
CLEAR_LCD:
LOW RS
LOW RW
OUTH = %00000001
PULSOUT E,1
GOSUB WAIT_LCD
RETURN
WRITE_TEXT:
HIGH RS
LOW RW
OUTH = SNDCHAR
PULSOUT E,1
LOW RS
GOSUB WAIT_LCD
RETURN
MOVE_RIGHT:
LOW RS
LOW RW
OUTH = %00010000
PULSOUT E,1
GOSUB WAIT_LCD
RETURN
SHIFT_LEFT:
LOW RS
LOW RW
OUTH = %00011000
PULSOUT E,1
GOSUB WAIT_LCD
RETURN
POSITION_CURSOR:
LOW RS
LOW RW
OUTH = %10000101
PULSOUT E,1
GOSUB WAIT_LCD
RETURN
POSITION_CURSORB:
LOW RS
LOW RW
OUTH = %10001000
PULSOUT E,1
GOSUB WAIT_LCD
RETURN
LOW RS
LOW RW
OUTH = SNDCHAR
PULSOUT E,1
GOSUB WAIT_LCD
RETURN
INTRO:
CG
data
LOW RW
Dsply
NEXT
LOW RS
GOSUB WRITE_TEXT
GOSUB SHIFT_LEFT
PAUSE 50
GOSUB WRITE_TEXT
GOSUB SHIFT_LEFT
PAUSE 50
GOSUB WRITE_TEXT
GOSUB SHIFT_LEFT
PAUSE 50
GOSUB WRITE_TEXT
GOSUB SHIFT_LEFT
PAUSE 50
GOSUB WRITE_TEXT
GOSUB SHIFT_LEFT
PAUSE 50
GOSUB WRITE_TEXT
GOSUB SHIFT_LEFT
PAUSE 50
GOSUB WRITE_TEXT
GOSUB SHIFT_LEFT
PAUSE 2000
GOSUB WRITE_TEXT
PAUSE 500
GOSUB WRITE_TEXT
PAUSE 2000
GOSUB SHIFT_LEFT
PAUSE 50
GOSUB SHIFT_LEFT
PAUSE 50
GOSUB SHIFT_LEFT
PAUSE 50
GOSUB SHIFT_LEFT
PAUSE 50
GOSUB SHIFT_LEFT
PAUSE 50
GOSUB SHIFT_LEFT
PAUSE 50
GOSUB SHIFT_LEFT
PAUSE 50
GOSUB SHIFT_LEFT
PAUSE 50
RETURN
WRITE_PINS:
'DEBUG ? IN0
'DEBUG ? IN2
'DEBUG ? IN3
'DEBUG ? IN4
'PAUSE 500
'DEBUG "INS="
'DEBUG "OUTS="
'DEBUG "DIRS="
'PAUSE 500
RETURN
Your use of Yahoo! Groups is subject to
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
Thanks for the reply. I learn a little more each day. If I might
ask an uneducated follow-up question. Is there such a thing as a
Programmable Integrated Circuit that does not need external memory
(EEPROM) and resonators... to operate?
Ultimately I'd like to be able to create a low cost reproducible
product. I was hoping that the unit cost per product wouldn't cost
as much as a single Basic Stamp.
I've looked at the Basic Stamp FAQ "How can I move to a PIC?". But
the information there seems to point to different software and
hardware resources to program the chip. None of it explains what is
necessary to make the chip do work in a project environment.
As a novice I'm having trouble sorting through all of the acronyms
and information to understand what is available and or necessary to
accomplish my task. A simple link or book reference would be a more
than sufficient response.
Thanks again!
Scott
--- In basicstamps@yahoogroups.com, "Jon Williams" <jwilliams@p...>
wrote:
> About the only thing you can give up from the Stamp Stack is the
critical
the
You can
is
> -- Jon Williams
> -- Dallas Office
> From: Scott Wilkinson [noparse][[/noparse]mailto:smwilkinson@e...]
I've
and
was
supply
onto
I'm
the
on the
from my
drives
not be
Stamp
there
new to
is
> plain
> Scott
> '{$STAMP BS2sx}
> '{$PBASIC 2.5}
> Lock = 0
> Trip = 100
> TTShots VAR Word
> TTShots = 0
> TTHits VAR Word
> TTHits = 0
> TTPct VAR Word
> TTPct = 0
> HIGH 0
> HIGH 2
> HIGH 3
> INPUT 4 'Hit button
> HIGH 4
> RS PIN 5
> RW PIN 6
> E PIN 7
> starting at
> location 100
was
> held
> pressed
> INIT:
> PAUSE 20
> OUTPUT 5'RS
> OUTPUT 6'RW
> OUTPUT 7'E
> LOW RS
> LOW RW
> OUTD = %0011
> PULSOUT E,1
> PAUSE 5
> OUTD = %0011
> PULSOUT E,1
> PAUSE 100
> OUTD = %0011
> PULSOUT E,1
> PULSOUT E,1
> OUTH = %00000001
> PULSOUT E,1
> OUTH = %00000010
> PULSOUT E,1
> OUTH = %00000010
> PULSOUT E,1
> PAUSE 100
> GOSUB INTRO
> PAUSE 500
> 'DEBUG "INIT"
> GOSUB CLEAR_LCD
> GOSUB CALC_PCT
> MAINLOOP:
> 'PAUSE 1000
> GOSUB Check_Shot
> GOSUB Check_Hit
> GOSUB Check_Reset
> GOSUB Check_Alt
> GOTO MAINLOOP
> Check_Shot:
> Dsply = 0
> GOSUB Add_Shot
> ENDIF
> RETURN
> Check_Hit:
> Dsply = 0
> GOSUB Add_Hit
> ENDIF
> RETURN
> Check_Reset:
> Lock = 1
> GOSUB DO_RESET
reboot???
> ENDIF
> RETURN
> Check_Alt:
> Lock = 1
> IF Dsply = 1 THEN
> ELSE
> Dsply = 1'Show Pct
> ENDIF
> GOSUB Calc_Pct
> ENDIF
> GOTO MAINLOOP
> Add_Shot:
> 'WRITE 1, 0
> LOCK = 1
> READ Trip, TTShots
> WRITE Trip, TTShots
> 'I VAR Byte
> 'NEXT
> GOSUB Calc_Pct
> GOTO MAINLOOP
> Add_Hit:
> Lock = 1
> READ Trip, TTShots
Word
> takes 2 bytes
shots
> 'FREQOUT 1,750,2500
> 'FREQOUT 1,750,2500
> GOSUB Calc_Pct
> 'Skip_Hit:
> GOTO MAINLOOP
> Calc_Pct:
> READ Trip, TTShots
> READ Trip+1,TTHits
> store
> GOSUB CLEAR_LCD
> IF Dsply < 1 THEN
> FOR ii=2 TO 0
> NEXT
> FOR ii=2 TO 0
> NEXT
> ELSE 'Show Percent
> OUTH = %10000010
> FOR ii=3 TO 0
> IF ii = 1 THEN
> GOSUB WRITE_TEXT
> ENDIF
> NEXT
> GOSUB WRITE_TEXT
> ENDIF
> 'GOSUB Print
> RETURN
> DO_RESET:
> PAUSE 500
> PAUSE 500
> 'PAUSE 500
> GOSUB CALC_PCT
> RETURN
> DO_UNLOCK:
> LOCK = 0
> RETURN
> Print:
> 'DEBUG ? OUT15
> 'DEBUG ? OUT0
> 'DEBUG ? IN4,CR
> 'DEBUG ? IN3,CR
> 'DEBUG ? Lock, CR
> RETURN
LCD
> CODE
> WAIT_LCD:
> LOW RS
> HIGH RW
> INPUT 15'IN DB7
> PULSOUT E,1
> LOW RW
> OUTPUT 15
> LoopCount = 0
> RETURN
> CLEAR_LCD:
> LOW RS
> LOW RW
> OUTH = %00000001
> PULSOUT E,1
> GOSUB WAIT_LCD
> RETURN
> WRITE_TEXT:
> HIGH RS
> LOW RW
> OUTH = SNDCHAR
> PULSOUT E,1
> LOW RS
> GOSUB WAIT_LCD
> RETURN
> MOVE_RIGHT:
> LOW RS
> LOW RW
> OUTH = %00010000
> PULSOUT E,1
> GOSUB WAIT_LCD
> RETURN
> SHIFT_LEFT:
> LOW RS
> LOW RW
> OUTH = %00011000
> PULSOUT E,1
> GOSUB WAIT_LCD
> RETURN
> POSITION_CURSOR:
> LOW RS
> LOW RW
> OUTH = %10000101
> PULSOUT E,1
> GOSUB WAIT_LCD
> RETURN
> POSITION_CURSORB:
> LOW RS
> LOW RW
> OUTH = %10001000
> PULSOUT E,1
> GOSUB WAIT_LCD
> RETURN
> LOW RS
> LOW RW
> OUTH = SNDCHAR
> PULSOUT E,1
> GOSUB WAIT_LCD
> RETURN
> INTRO:
write
> CG
> data
> LOW RW
and
> Dsply
> NEXT
> LOW RS
> GOSUB WRITE_TEXT
> GOSUB SHIFT_LEFT
> PAUSE 50
> GOSUB WRITE_TEXT
> GOSUB SHIFT_LEFT
> PAUSE 50
> GOSUB WRITE_TEXT
> GOSUB SHIFT_LEFT
> PAUSE 50
> GOSUB WRITE_TEXT
> GOSUB SHIFT_LEFT
> PAUSE 50
> GOSUB WRITE_TEXT
> GOSUB SHIFT_LEFT
> PAUSE 50
> GOSUB WRITE_TEXT
> GOSUB SHIFT_LEFT
> PAUSE 50
> GOSUB WRITE_TEXT
> GOSUB SHIFT_LEFT
> PAUSE 2000
> GOSUB WRITE_TEXT
> PAUSE 500
> GOSUB WRITE_TEXT
> PAUSE 2000
> GOSUB SHIFT_LEFT
> PAUSE 50
> GOSUB SHIFT_LEFT
> PAUSE 50
> GOSUB SHIFT_LEFT
> PAUSE 50
> GOSUB SHIFT_LEFT
> PAUSE 50
> GOSUB SHIFT_LEFT
> PAUSE 50
> GOSUB SHIFT_LEFT
> PAUSE 50
> GOSUB SHIFT_LEFT
> PAUSE 50
> GOSUB SHIFT_LEFT
> PAUSE 50
> RETURN
> WRITE_PINS:
> 'DEBUG ? IN0
> 'DEBUG ? IN2
> 'DEBUG ? IN3
> 'DEBUG ? IN4
> 'PAUSE 500
> 'DEBUG "INS="
> 'DEBUG "OUTS="
> 'DEBUG "DIRS="
> 'PAUSE 500
> RETURN
Subject
> abuse@p...
is: a PIC or SX micro running a Parallax program that fetches and
executes PBASIC tokens (similar to Java bytecodes) from an external
EEPROM.
If you want to move to a single-chip solution there are many
opportunities. You can stick with Parallax and go the SX route; we have
tools and training materials. Of course, there's the PICmicro; it has a
broad line of parts and is very popular -- and some devices can use very
inexpensive tools. Atmel is also very popular, as is Motorola ... as
you can see, you have a lot of choices.
If you're an electronics/microcontroller novice you may want to spend a
bit more time with your Stamp Stack to build some confidence. Again,
you can download our SX documentation and software at no charge. And
you can also download two books by our friend -- and Stamp list
contributor -- Al Williams: "Introduction to Assembly Language
Programming with the SX Microcontroller" and "I/O Control With the SX
Microcontroller."
-- Jon Williams
-- Dallas Office
From: lcg30339 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=215iy7k4azqXdf-Liwiwsk06xx_XAKyz5mbsuK4Xb4lxUP3mboXBCoPWVMw6Lk6vBSeCjhWPQVgQk-S4S-asIQdanQ]smwilkinson@e...[/url
Sent: Sunday, October 05, 2003 11:24 AM
Subject: [noparse][[/noparse]basicstamps] Re: BS2 Without Stamp Stack
Jon,
Thanks again!
Scott
critical
the
You can
is
> -- Jon Williams
> -- Dallas Office
I've
and
was
supply
onto
I'm
the
on the
from my
drives
not be
Stamp
there
new to
is
> plain
> Scott
> '{$STAMP BS2sx}
> '{$PBASIC 2.5}
> Lock = 0
> Trip = 100
> TTShots VAR Word
> TTShots = 0
> TTHits VAR Word
> TTHits = 0
> TTPct VAR Word
> TTPct = 0
> HIGH 0
> HIGH 2
> HIGH 3
> INPUT 4 'Hit button
> HIGH 4
> RS PIN 5
> RW PIN 6
> E PIN 7
> starting at
> location 100
was
> held
> pressed
> INIT:
> PAUSE 20
> OUTPUT 5'RS
> OUTPUT 6'RW
> OUTPUT 7'E
> LOW RS
> LOW RW
> OUTD = %0011
> PULSOUT E,1
> PAUSE 5
> OUTD = %0011
> PULSOUT E,1
> PAUSE 100
> OUTD = %0011
> PULSOUT E,1
> PULSOUT E,1
> OUTH = %00000001
> PULSOUT E,1
> OUTH = %00000010
> PULSOUT E,1
> OUTH = %00000010
> PULSOUT E,1
> PAUSE 100
> GOSUB INTRO
> PAUSE 500
> 'DEBUG "INIT"
> GOSUB CLEAR_LCD
> GOSUB CALC_PCT
> MAINLOOP:
> 'PAUSE 1000
> GOSUB Check_Shot
> GOSUB Check_Hit
> GOSUB Check_Reset
> GOSUB Check_Alt
> GOTO MAINLOOP
> Check_Shot:
> Dsply = 0
> GOSUB Add_Shot
> ENDIF
> RETURN
> Check_Hit:
> Dsply = 0
> GOSUB Add_Hit
> ENDIF
> RETURN
> Check_Reset:
> Lock = 1
> GOSUB DO_RESET
reboot???
> ENDIF
> RETURN
> Check_Alt:
> Lock = 1
> IF Dsply = 1 THEN
> ELSE
> Dsply = 1'Show Pct
> ENDIF
> GOSUB Calc_Pct
> ENDIF
> GOTO MAINLOOP
> Add_Shot:
> 'WRITE 1, 0
> LOCK = 1
> READ Trip, TTShots
> WRITE Trip, TTShots
> 'I VAR Byte
> 'NEXT
> GOSUB Calc_Pct
> GOTO MAINLOOP
> Add_Hit:
> Lock = 1
> READ Trip, TTShots
Word
> takes 2 bytes
shots
> 'FREQOUT 1,750,2500
> 'FREQOUT 1,750,2500
> GOSUB Calc_Pct
> 'Skip_Hit:
> GOTO MAINLOOP
> Calc_Pct:
> READ Trip, TTShots
> READ Trip+1,TTHits
> store
> GOSUB CLEAR_LCD
> IF Dsply < 1 THEN
> FOR ii=2 TO 0
> NEXT
> FOR ii=2 TO 0
> NEXT
> ELSE 'Show Percent
> OUTH = %10000010
> FOR ii=3 TO 0
> IF ii = 1 THEN
> GOSUB WRITE_TEXT
> ENDIF
> NEXT
> GOSUB WRITE_TEXT
> ENDIF
> 'GOSUB Print
> RETURN
> DO_RESET:
> PAUSE 500
> PAUSE 500
> 'PAUSE 500
> GOSUB CALC_PCT
> RETURN
> DO_UNLOCK:
> LOCK = 0
> RETURN
> Print:
> 'DEBUG ? OUT15
> 'DEBUG ? OUT0
> 'DEBUG ? IN4,CR
> 'DEBUG ? IN3,CR
> 'DEBUG ? Lock, CR
> RETURN
LCD
> CODE
> WAIT_LCD:
> LOW RS
> HIGH RW
> INPUT 15'IN DB7
> PULSOUT E,1
> LOW RW
> OUTPUT 15
> LoopCount = 0
> RETURN
> CLEAR_LCD:
> LOW RS
> LOW RW
> OUTH = %00000001
> PULSOUT E,1
> GOSUB WAIT_LCD
> RETURN
> WRITE_TEXT:
> HIGH RS
> LOW RW
> OUTH = SNDCHAR
> PULSOUT E,1
> LOW RS
> GOSUB WAIT_LCD
> RETURN
> MOVE_RIGHT:
> LOW RS
> LOW RW
> OUTH = %00010000
> PULSOUT E,1
> GOSUB WAIT_LCD
> RETURN
> SHIFT_LEFT:
> LOW RS
> LOW RW
> OUTH = %00011000
> PULSOUT E,1
> GOSUB WAIT_LCD
> RETURN
> POSITION_CURSOR:
> LOW RS
> LOW RW
> OUTH = %10000101
> PULSOUT E,1
> GOSUB WAIT_LCD
> RETURN
> POSITION_CURSORB:
> LOW RS
> LOW RW
> OUTH = %10001000
> PULSOUT E,1
> GOSUB WAIT_LCD
> RETURN
> LOW RS
> LOW RW
> OUTH = SNDCHAR
> PULSOUT E,1
> GOSUB WAIT_LCD
> RETURN
> INTRO:
write
> CG
> data
> LOW RW
and
> Dsply
> NEXT
> LOW RS
> GOSUB WRITE_TEXT
> GOSUB SHIFT_LEFT
> PAUSE 50
> GOSUB WRITE_TEXT
> GOSUB SHIFT_LEFT
> PAUSE 50
> GOSUB WRITE_TEXT
> GOSUB SHIFT_LEFT
> PAUSE 50
> GOSUB WRITE_TEXT
> GOSUB SHIFT_LEFT
> PAUSE 50
> GOSUB WRITE_TEXT
> GOSUB SHIFT_LEFT
> PAUSE 50
> GOSUB WRITE_TEXT
> GOSUB SHIFT_LEFT
> PAUSE 50
> GOSUB WRITE_TEXT
> GOSUB SHIFT_LEFT
> PAUSE 2000
> GOSUB WRITE_TEXT
> PAUSE 500
> GOSUB WRITE_TEXT
> PAUSE 2000
> GOSUB SHIFT_LEFT
> PAUSE 50
> GOSUB SHIFT_LEFT
> PAUSE 50
> GOSUB SHIFT_LEFT
> PAUSE 50
> GOSUB SHIFT_LEFT
> PAUSE 50
> GOSUB SHIFT_LEFT
> PAUSE 50
> GOSUB SHIFT_LEFT
> PAUSE 50
> GOSUB SHIFT_LEFT
> PAUSE 50
> GOSUB SHIFT_LEFT
> PAUSE 50
> RETURN
> WRITE_PINS:
> 'DEBUG ? IN0
> 'DEBUG ? IN2
> 'DEBUG ? IN3
> 'DEBUG ? IN4
> 'PAUSE 500
> 'DEBUG "INS="
> 'DEBUG "OUTS="
> 'DEBUG "DIRS="
> 'PAUSE 500
> RETURN
Subject
> abuse@p...
abuse@p....
You've been most helpful. I had looked at Parallax's SX programming
kit but there was some confusion on my part because the chip that is
in my Stamp Stack is an "SX"28AC/DP. I couldn't be positive that
there was a difference or that it would sove my issues. I
appreciate you clearing that up. I'll be sure to check out each of
the resources you mentioned.
Have a great day!
Scott
wrote:
> Yes, there is such a thing -- in fact, that's what the Stamp
interpreter
> EEPROM.
we have
has a
use very
as
spend a
Again,
And
SX
> Microcontroller."
> -- Jon Williams
> -- Dallas Office
> From: lcg30339 [noparse][[/noparse]mailto:smwilkinson@e...]
> Jon,
cost
is
to
more
> Thanks again!
> Scott
<jwilliams@p...>
> critical
> the
> You can
> is
> > -- Jon Williams
> > -- Dallas Office
Stamp
> I've
it
> and
> was
> supply
> onto
> I'm
But
> the
> on the
is
> from my
> drives
> not be
> Stamp
> there
> new to
> is
> > plain
> > Scott
> > '{$STAMP BS2sx}
> > '{$PBASIC 2.5}
press
> > Lock = 0
> > Trip = 100
> > TTShots VAR Word
> > TTShots = 0
> > TTHits VAR Word
> > TTHits = 0
> > TTPct VAR Word
> > TTPct = 0
> > HIGH 0
> > HIGH 2
> > HIGH 3
> > INPUT 4 'Hit button
> > HIGH 4
> > RS PIN 5
> > RW PIN 6
> > E PIN 7
> > starting at
> > location 100
button
> was
> > held
> > pressed
> > INIT:
> > PAUSE 20
> > OUTPUT 5'RS
> > OUTPUT 6'RW
> > OUTPUT 7'E
> > LOW RS
> > LOW RW
> > OUTD = %0011
> > PULSOUT E,1
> > PAUSE 5
> > OUTD = %0011
> > PULSOUT E,1
> > PAUSE 100
> > OUTD = %0011
> > PULSOUT E,1
> > PULSOUT E,1
> > OUTH = %00000001
> > PULSOUT E,1
> > OUTH = %00000010
> > PULSOUT E,1
> > OUTH = %00000010
> > PULSOUT E,1
> > PAUSE 100
> > GOSUB INTRO
> > PAUSE 500
> > 'DEBUG "INIT"
> > GOSUB CLEAR_LCD
> > GOSUB CALC_PCT
> > MAINLOOP:
> > 'PAUSE 1000
> > GOSUB Check_Shot
> > GOSUB Check_Hit
> > GOSUB Check_Reset
> > GOSUB Check_Alt
> > GOTO MAINLOOP
> > Check_Shot:
DO_UNLOCK
> > Dsply = 0
> > GOSUB Add_Shot
> > ENDIF
> > RETURN
> > Check_Hit:
DO_UNLOCK
> > Dsply = 0
> > GOSUB Add_Hit
> > ENDIF
> > RETURN
> > Check_Reset:
DO_UNLOCK
> > Lock = 1
> > GOSUB DO_RESET
> reboot???
> > ENDIF
> > RETURN
> > Check_Alt:
DO_UNLOCK
> > Lock = 1
> > IF Dsply = 1 THEN
> > ELSE
> > Dsply = 1'Show Pct
> > ENDIF
> > GOSUB Calc_Pct
> > ENDIF
> > GOTO MAINLOOP
> > Add_Shot:
> > 'WRITE 1, 0
> > LOCK = 1
> > READ Trip, TTShots
> > WRITE Trip, TTShots
> > 'I VAR Byte
> > 'NEXT
> > GOSUB Calc_Pct
> > GOTO MAINLOOP
> > Add_Hit:
> > Lock = 1
> > READ Trip, TTShots
> Word
> > takes 2 bytes
> shots
> > 'FREQOUT 1,750,2500
> > 'FREQOUT 1,750,2500
> > GOSUB Calc_Pct
> > 'Skip_Hit:
> > GOTO MAINLOOP
> > Calc_Pct:
> > READ Trip, TTShots
> > READ Trip+1,TTHits
to
> > store
> > GOSUB CLEAR_LCD
> > IF Dsply < 1 THEN
> > FOR ii=2 TO 0
ascii
> > NEXT
> > FOR ii=2 TO 0
ascii
> > NEXT
> > ELSE 'Show Percent
> > OUTH = %10000010
> > FOR ii=3 TO 0
> > IF ii = 1 THEN
> > GOSUB WRITE_TEXT
> > ENDIF
> > NEXT
> > GOSUB WRITE_TEXT
> > ENDIF
> > 'GOSUB Print
> > RETURN
> > DO_RESET:
> > PAUSE 500
> > PAUSE 500
> > 'PAUSE 500
> > GOSUB CALC_PCT
> > RETURN
> > DO_UNLOCK:
> > LOCK = 0
> > RETURN
> > Print:
> > 'DEBUG ? OUT15
> > 'DEBUG ? OUT0
> > 'DEBUG ? IN4,CR
> > 'DEBUG ? IN3,CR
> > 'DEBUG ? Lock, CR
> > RETURN
LCD
> > CODE
> > WAIT_LCD:
> > LOW RS
> > HIGH RW
> > INPUT 15'IN DB7
> > PULSOUT E,1
> > LOW RW
> > OUTPUT 15
> > LoopCount = 0
> > RETURN
> > CLEAR_LCD:
> > LOW RS
> > LOW RW
> > OUTH = %00000001
> > PULSOUT E,1
> > GOSUB WAIT_LCD
> > RETURN
> > WRITE_TEXT:
> > HIGH RS
> > LOW RW
> > OUTH = SNDCHAR
> > PULSOUT E,1
> > LOW RS
> > GOSUB WAIT_LCD
> > RETURN
> > MOVE_RIGHT:
> > LOW RS
> > LOW RW
> > OUTH = %00010000
> > PULSOUT E,1
> > GOSUB WAIT_LCD
> > RETURN
> > SHIFT_LEFT:
> > LOW RS
> > LOW RW
> > OUTH = %00011000
> > PULSOUT E,1
> > GOSUB WAIT_LCD
> > RETURN
> > POSITION_CURSOR:
> > LOW RS
> > LOW RW
> > OUTH = %10000101
> > PULSOUT E,1
> > GOSUB WAIT_LCD
> > RETURN
> > POSITION_CURSORB:
> > LOW RS
> > LOW RW
> > OUTH = %10001000
> > PULSOUT E,1
> > GOSUB WAIT_LCD
> > RETURN
> > LOW RS
> > LOW RW
> > OUTH = SNDCHAR
> > PULSOUT E,1
> > GOSUB WAIT_LCD
> > RETURN
> > INTRO:
> > HIGH RS ' prepare
to
> write
> > CG
> > data
> > LOW RW
EE
> and
> > Dsply
EEPROM
RAM
> > NEXT
> > LOW RS
> > GOSUB WRITE_TEXT
> > GOSUB SHIFT_LEFT
> > PAUSE 50
> > GOSUB WRITE_TEXT
> > GOSUB SHIFT_LEFT
> > PAUSE 50
> > GOSUB WRITE_TEXT
> > GOSUB SHIFT_LEFT
> > PAUSE 50
> > GOSUB WRITE_TEXT
> > GOSUB SHIFT_LEFT
> > PAUSE 50
> > GOSUB WRITE_TEXT
> > GOSUB SHIFT_LEFT
> > PAUSE 50
> > GOSUB WRITE_TEXT
> > GOSUB SHIFT_LEFT
> > PAUSE 50
> > GOSUB WRITE_TEXT
> > GOSUB SHIFT_LEFT
> > PAUSE 2000
> > GOSUB WRITE_TEXT
> > PAUSE 500
> > GOSUB WRITE_TEXT
> > PAUSE 2000
> > GOSUB SHIFT_LEFT
> > PAUSE 50
> > GOSUB SHIFT_LEFT
> > PAUSE 50
> > GOSUB SHIFT_LEFT
> > PAUSE 50
> > GOSUB SHIFT_LEFT
> > PAUSE 50
> > GOSUB SHIFT_LEFT
> > PAUSE 50
> > GOSUB SHIFT_LEFT
> > PAUSE 50
> > GOSUB SHIFT_LEFT
> > PAUSE 50
> > GOSUB SHIFT_LEFT
> > PAUSE 50
> > RETURN
> > WRITE_PINS:
> > 'DEBUG ? IN0
> > 'DEBUG ? IN2
> > 'DEBUG ? IN3
> > 'DEBUG ? IN4
> > 'PAUSE 500
> > 'DEBUG "INS="
> > 'DEBUG "OUTS="
> > 'DEBUG "DIRS="
> > 'PAUSE 500
> > RETURN
> Subject
to
> > abuse@p...
Subject
> abuse@p...
'flash' memory on-chip, and 368 bytes of RAM, and
256 bytes of EEPROM. So with a 16F876, a resonator,
and a few parts (regulator, pull-up resistor) you
can build what you describe.
Some PIC parts actually have 'internal' resonators,
I'm unsure about the 16F876. Typically, the internal
clocks are only accurate to 1% or so (86,400 secs/day
means they can gain or lose 864 seconds a day) so
I tend not to use them -- but a resonator costs
$0.50 to $1.00 from Digikey, so this is no big deal.
Try http://www.phanderson.com/ Peter Anderson's site
for more info.
--- In basicstamps@yahoogroups.com, "lcg30339" <smwilkinson@e...>
wrote:
> Jon,
> Thanks again!
> Scott
> critical
> the
> You can
> is
> > -- Jon Williams
> > -- Dallas Office
Stamp
> I've
it
> and
> was
> supply
> onto
> I'm
But
> the
> on the
is
> from my
> drives
> not be
> Stamp
> there
> new to
> is
> > plain
> > Scott
> > '{$STAMP BS2sx}
> > '{$PBASIC 2.5}
> > Lock = 0
> > Trip = 100
> > TTShots VAR Word
> > TTShots = 0
> > TTHits VAR Word
> > TTHits = 0
> > TTPct VAR Word
> > TTPct = 0
> > HIGH 0
> > HIGH 2
> > HIGH 3
> > INPUT 4 'Hit button
> > HIGH 4
> > RS PIN 5
> > RW PIN 6
> > E PIN 7
> > starting at
> > location 100
button
> was
> > held
> > pressed
> > INIT:
> > PAUSE 20
> > OUTPUT 5'RS
> > OUTPUT 6'RW
> > OUTPUT 7'E
> > LOW RS
> > LOW RW
> > OUTD = %0011
> > PULSOUT E,1
> > PAUSE 5
> > OUTD = %0011
> > PULSOUT E,1
> > PAUSE 100
> > OUTD = %0011
> > PULSOUT E,1
> > PULSOUT E,1
> > OUTH = %00000001
> > PULSOUT E,1
> > OUTH = %00000010
> > PULSOUT E,1
> > OUTH = %00000010
> > PULSOUT E,1
> > PAUSE 100
> > GOSUB INTRO
> > PAUSE 500
> > 'DEBUG "INIT"
> > GOSUB CLEAR_LCD
> > GOSUB CALC_PCT
> > MAINLOOP:
> > 'PAUSE 1000
> > GOSUB Check_Shot
> > GOSUB Check_Hit
> > GOSUB Check_Reset
> > GOSUB Check_Alt
> > GOTO MAINLOOP
> > Check_Shot:
> > Dsply = 0
> > GOSUB Add_Shot
> > ENDIF
> > RETURN
> > Check_Hit:
> > Dsply = 0
> > GOSUB Add_Hit
> > ENDIF
> > RETURN
> > Check_Reset:
> > Lock = 1
> > GOSUB DO_RESET
> reboot???
> > ENDIF
> > RETURN
> > Check_Alt:
> > Lock = 1
> > IF Dsply = 1 THEN
> > ELSE
> > Dsply = 1'Show Pct
> > ENDIF
> > GOSUB Calc_Pct
> > ENDIF
> > GOTO MAINLOOP
> > Add_Shot:
> > 'WRITE 1, 0
> > LOCK = 1
> > READ Trip, TTShots
> > WRITE Trip, TTShots
> > 'I VAR Byte
> > 'NEXT
> > GOSUB Calc_Pct
> > GOTO MAINLOOP
> > Add_Hit:
> > Lock = 1
> > READ Trip, TTShots
> Word
> > takes 2 bytes
> shots
> > 'FREQOUT 1,750,2500
> > 'FREQOUT 1,750,2500
> > GOSUB Calc_Pct
> > 'Skip_Hit:
> > GOTO MAINLOOP
> > Calc_Pct:
> > READ Trip, TTShots
> > READ Trip+1,TTHits
to
> > store
> > GOSUB CLEAR_LCD
> > IF Dsply < 1 THEN
> > FOR ii=2 TO 0
ascii
> > NEXT
> > FOR ii=2 TO 0
> > NEXT
> > ELSE 'Show Percent
> > OUTH = %10000010
> > FOR ii=3 TO 0
> > IF ii = 1 THEN
> > GOSUB WRITE_TEXT
> > ENDIF
> > NEXT
> > GOSUB WRITE_TEXT
> > ENDIF
> > 'GOSUB Print
> > RETURN
> > DO_RESET:
> > PAUSE 500
> > PAUSE 500
> > 'PAUSE 500
> > GOSUB CALC_PCT
> > RETURN
> > DO_UNLOCK:
> > LOCK = 0
> > RETURN
> > Print:
> > 'DEBUG ? OUT15
> > 'DEBUG ? OUT0
> > 'DEBUG ? IN4,CR
> > 'DEBUG ? IN3,CR
> > 'DEBUG ? Lock, CR
> > RETURN
LCD
> > CODE
> > WAIT_LCD:
> > LOW RS
> > HIGH RW
> > INPUT 15'IN DB7
> > PULSOUT E,1
> > LOW RW
> > OUTPUT 15
> > LoopCount = 0
> > RETURN
> > CLEAR_LCD:
> > LOW RS
> > LOW RW
> > OUTH = %00000001
> > PULSOUT E,1
> > GOSUB WAIT_LCD
> > RETURN
> > WRITE_TEXT:
> > HIGH RS
> > LOW RW
> > OUTH = SNDCHAR
> > PULSOUT E,1
> > LOW RS
> > GOSUB WAIT_LCD
> > RETURN
> > MOVE_RIGHT:
> > LOW RS
> > LOW RW
> > OUTH = %00010000
> > PULSOUT E,1
> > GOSUB WAIT_LCD
> > RETURN
> > SHIFT_LEFT:
> > LOW RS
> > LOW RW
> > OUTH = %00011000
> > PULSOUT E,1
> > GOSUB WAIT_LCD
> > RETURN
> > POSITION_CURSOR:
> > LOW RS
> > LOW RW
> > OUTH = %10000101
> > PULSOUT E,1
> > GOSUB WAIT_LCD
> > RETURN
> > POSITION_CURSORB:
> > LOW RS
> > LOW RW
> > OUTH = %10001000
> > PULSOUT E,1
> > GOSUB WAIT_LCD
> > RETURN
> > LOW RS
> > LOW RW
> > OUTH = SNDCHAR
> > PULSOUT E,1
> > GOSUB WAIT_LCD
> > RETURN
> > INTRO:
> > HIGH RS ' prepare
to
> write
> > CG
> > data
> > LOW RW
EE
> and
> > Dsply
> > NEXT
> > LOW RS
> > GOSUB WRITE_TEXT
> > GOSUB SHIFT_LEFT
> > PAUSE 50
> > GOSUB WRITE_TEXT
> > GOSUB SHIFT_LEFT
> > PAUSE 50
> > GOSUB WRITE_TEXT
> > GOSUB SHIFT_LEFT
> > PAUSE 50
> > GOSUB WRITE_TEXT
> > GOSUB SHIFT_LEFT
> > PAUSE 50
> > GOSUB WRITE_TEXT
> > GOSUB SHIFT_LEFT
> > PAUSE 50
> > GOSUB WRITE_TEXT
> > GOSUB SHIFT_LEFT
> > PAUSE 50
> > GOSUB WRITE_TEXT
> > GOSUB SHIFT_LEFT
> > PAUSE 2000
> > GOSUB WRITE_TEXT
> > PAUSE 500
> > GOSUB WRITE_TEXT
> > PAUSE 2000
> > GOSUB SHIFT_LEFT
> > PAUSE 50
> > GOSUB SHIFT_LEFT
> > PAUSE 50
> > GOSUB SHIFT_LEFT
> > PAUSE 50
> > GOSUB SHIFT_LEFT
> > PAUSE 50
> > GOSUB SHIFT_LEFT
> > PAUSE 50
> > GOSUB SHIFT_LEFT
> > PAUSE 50
> > GOSUB SHIFT_LEFT
> > PAUSE 50
> > GOSUB SHIFT_LEFT
> > PAUSE 50
> > RETURN
> > WRITE_PINS:
> > 'DEBUG ? IN0
> > 'DEBUG ? IN2
> > 'DEBUG ? IN3
> > 'DEBUG ? IN4
> > 'PAUSE 500
> > 'DEBUG "INS="
> > 'DEBUG "OUTS="
> > 'DEBUG "DIRS="
> > 'PAUSE 500
> > RETURN
> Subject
> > abuse@p...
