Sample code for Memsic 2125 Accelerometer to Serial LCD???
Archiver
I know this is a simple thing to do but i still cant figure it out.
Would anyone be able to show me how to output angle measurments to the
LCD? Just a bit of sample code is all I need. Thanks
Grab the PDF and/or sample code which can be found here on the Parallax web
site:
http://www.parallax.com/detail.asp?product_id=28017
Convert the DEBUG statements found in the code to commands which are
appropriate
for your serial LCD.
Bruce Bates
>from the same email address that you subscribed. Text in the Subject and
>Body of the message will be ignored.
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
and pasting bits of the demo programs to try to make it work. I have
replaced the "debug" command with the appropriate serout comamnds and
still no good. I get something on the screen, but its just one
charactar long and is ramdom numbers, letters, and symbols.
Are you sure thats all there is to it? If so, I will try again.
Dean
Parallax web
> site:
> appropriate
> Regards,
> Bruce Bates
Subject and
>Hi Bruce, thanks. I already tried that. Spent several hours cutting
>Dean
Hi Dean -
Essentially it's replacing or converting the DEBUG commands to meet the
needs of your LCD. You didn't mention which serial LCD you're using. Are
you sure you're initializing the LCD correctly, and waiting an appropriate
amount of time before sending it data to display ?
Bruce
