Comm. vb and bs2 when compiled to exe
For each character i use
MSComm_obj.Output = Chr$(Asc(character))
FlushTxBuf MSComm_obj
It works fine (100% ok) in vb but it doesn't run anymore when i create and run
the exe-program (25% ok)
Has someone an idea to resolved this.
Private Sub FlushTxBuf(MSComm_obj As MSComm)
' flush transmit buffer
Do
DoEvents
'Debug.Print "MSComm_obj.OutBufferCount" & MSComm_obj.OutBufferCount
Loop Until (MSComm_obj.OutBufferCount = 0)
End Sub
Pieter
Do
DoEvents
End Sub
Pieter
development environment and the EXE
environment is that the VB env. is
ALWAYS p-coded. The EXE env can be
native-coded -- usually is. The
native-code is about 10 times faster.
Also, the native-code can take advantage
of some optimizations.
I don't know what you mean by
"it doesn't run anymore"? Then you say
it is 25% OK. If it's not running, how
can it be more than 0% OK?
I assume the native-code version runs
so fast the stamp can't keep up. You
may need the VB 'sleep' command:
Declare Sub Sleep Lib "Kernel32" _
(ByVal DelaymS As Long)
Then, insert 'Sleep(1)' to sleep
1 mSec in your VB program, when you want
to give the BS2 some time to deal.
Note you'll still need to call 'DoEvents',
as I don't think 'Sleep' does that.
--- In basicstamps@yahoogroups.com, "Pieter Souvereyns" <pso@t...>
create and run the exe-program (25% ok)
> Do
> DoEvents
> End Sub
> Thanks
> Pieter
