Need Help with EEPROM on DS1615
I'm racking my brain and not having much luck with this DS1615. I have the
basics down, I can read the Registers and retrieve time, date, temp etc. But I
can't get any info from the EEPROM!
The Data sheet has the Temperature log in 1000h to 17FFh and 64 pages at 128 to
191. I'm confused on how to read this.
My current thinking is.....
do a Shiftout to read 1000
then loop 2048 times with a Shiftin to read all the memory addresses in bytes.
Loop 2048 times with
Shiftout and a variable for the requested address
and Shiftin the byte.
But the Data sheet has me believe I need to read this Page thing. Later in the
Data sheet they mention a Read Page function 33h. Maybe I need to go that
route?
For x = 128 to 191
Shiftout the X location
Shiftin the data to a temp var
Or maybe
Shiftout the $33
For x = 1 to 64
I'm currently using a synchronous connection to the chip so I'd assume that code
to read synchronous EEPROM would work with some modifications. But Maybe I'm
assuming to much.
As you can tell I'm very confused....Can anyone help me out?! Even some general
synchronous EEPROM info would be helpful!
Tim
route?
For x = 128 to 191
Or maybe
Shiftout the $33
For x = 1 to 64
assuming to much.
Tim
http://www.high-techgarage.com/tutorial/ds1615_page3.php
Dave
From: Tim Hart [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=BM0HI8cIsAt9xdJYo0-pQwB0T8-4UGLsSUGKYDTegPouOw9vpTBRvt4qlJToZPpaTj9bA20pWPo94w]tim.hart@h...[/url
Sent: Wednesday, October 01, 2003 9:28 AM
Subject: [noparse][[/noparse]basicstamps] Need Help with EEPROM on DS1615
the basics down, I can read the Registers and retrieve time, date, temp
etc. But I can't get any info from the EEPROM!
128 to 191. I'm confused on how to read this.
bytes.
in the Data sheet they mention a Read Page function 33h. Maybe I need
to go that route?
For x = 128 to 191
Or maybe
Shiftout the $33
For x = 1 to 64
that code to read synchronous EEPROM would work with some modifications.
But Maybe I'm assuming to much.
general synchronous EEPROM info would be helpful!
Tim
Your use of Yahoo! Groups is subject to
it's stable code. But it's missing the part where you read the long term
memory.
Currently I know the Addresses I need to start reading is 1000h but my code is
not working for me...
low sclk
high rst
shiftout dout, sclk, lsbfirst, [noparse][[/noparse]ReadPage, $1000]
for MemCounter = 0 to 8
shiftin dout, sclk, lsbpre, [noparse][[/noparse]DSdata]
Debug "DSdata :", Bin8 DSdata,cr
gosub ConvertTemp:
next
low rst
Right now I'm just attempting to get the first 8 recordings. But all I get is
DSdata :00000000 and that's not so great...
Anyone have any ideas?
Tim
10/01/03 17:48 PM >>>
Did you check out this page?
Dave
From: Tim Hart [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=xPyA03qR4xicMKkJHuK_t9beeOalrtBT_U9X7DF61D2pKvdo9b2VBCOd4_KWq8LQU9-pwaebIRXX8XfGKHbd]tim.hart@h...[/url
bytes.
to go that route?
For x = 128 to 191
Shiftn the data to a temp var
Or maybe
Shiftout the $33
For x = 1 to 64
Tim
from the same email address that you subscribed. Text in the Subject and Body
>Yes....their code is the base for my project. It has a few errors but
>overall it's stable code. But it's missing the part where you read the
>long term memory.
>code is not working for me...
> low sclk
> high rst
> gosub ConvertTemp:
> next
> low rst
>get is DSdata :00000000 and that's not so great...
>Thanks,
>Tim
Tim -
It's not apparent from your code snippet whether you had a datalog mission
active prior to retrieving the data. Did you ? If not, the zeros would seem
reasonable as default memory values.
Bruce Bates
after looking at some other PIC Code I noticed some had 3 shift out commands.
One to tell the chip what they wanted to do....and two more bytes to specify the
address. My code had only two! So I modified the Shiftout command to sent 3
bytes!
shiftout dout, sclk, lsbfirst, [noparse][[/noparse]ReadPage, $10, $00]
And then the data log magically showed up! Turns out the Ds1615 requires 16 bit
addressing....and it seems quite logical in hind sight...if they only had 8 bit
addressing the chip could only store 256 unique addresses....but the 2048 would
require more addresses then that! 16 bit!
I have it working nicely now and after I give it some polishing touches it will
be done. If code can ever be done [noparse]:)[/noparse] I've never heard Microsoft say Windows
was "done"....[noparse]:)[/noparse]
Thanks for the tip,
Tim
>>> bvbates@u... 10/01/03 10:43PM >>>
>long term memory.
> low sclk
> high rst
> gosub ConvertTemp:
> next
> low rst
>Thanks,
>Tim
Tim -
Bruce Bates
