32 bit math (input 32 bit value from keypad) what''s wrong?
Are you debugging the correct variable.. ie "z".
Sent: Wednesday, October 01, 2003 8:37 AM
Subject: Re: [noparse][[/noparse]basicstamps] 32 bit math (input 32 bit value from keypad)
what's wrong?
> I still seem to be having problems with the 32 bit add routine. I am not
sure
> what I am doing wrong but here is an example that doesn't seem to work:
> 89999999 + 1
> It seems like the carry from low word sum to high word sum is getting
lost.
> Would you please provide an example of how to perform the above summation
> using debug to display the results. This is how I tried to test it:
> x0=9999
> x1=8999
> y0=1
> y1=0
> gosub add1616
> debug dec z1,dec z0
> I assume my problem must be in the way I am trying to display the sum but
I
> can't seem to figure out the problem. Thanks!
> [noparse][[/noparse]Non-text portions of this message have been removed]
what's wrong?
sure
> 89999999 + 1
lost.
> x0=9999
> x1=8999
> y0=1
> y1=0
> gosub add1616
> debug dec z1,dec z0
I
