download data — Parallax Forums
download data
edited 2003-11-01 04:38 in General Discussion
Hi!
Instead to download on the eeprom of the running BS2, I want to
downloads
datas to an external eeprom like " 24C65 " . Does anyone have some code
lines
as an example? How should I write (as sample) a date & time and take the
smallest
place on eeprom
Thank you!
Rene
    edited 2003-10-01 12:06
    I have that 21073h.pdf document but it does not tell me a lot to how match stamp
    with it.
    In fact, I want to log "month, day, hour and minute" of an event and when I was
    talking about the
    24C65, it also could be a 24C08. The thing is to leave the whole unit in place
    and take only
    the eeprom for reading at home and to transfer on PC in an EXCEL format file.
    For many
    applications as how many cars passing by the street where I live and when, it
    could be also to
    follow the in and out of an employee at office and so... I want to log an event
    in an external
    eeprom from my BS2, Iwant to pick up thoses datas from eeprom also with my BS2
    and to
    transfer it to my PC onto a text file or onto an EXCEL file!
    What a project hey!
    But also what fun to learn to do it too!
    Rene
    --- In basicstamps@yahoogroups.com, rene genest <rene.genest@q...>
    wrote:
    > Hi!
    > downloads
    code
    > lines
    > as an example?
    Have you checked
    www.microchip.com/download/lit/pline/memory/ic/21073h.pdf
    I just briefly scanned it and it looks pretty sophisticated as far as
    what to write - byte, page and others. It looks like good candidate
    for SHIFTOUT and PULSOUT operators with one catch - 24C65 responds
    to commands with "ACK"! That means more work for you if you want to
    use this "handshake". I did not read the details, maybe you can
    safely ignore it. By more work I mean you will have to shiftout/
    pulsout for each output.
    But I don't want to keep guessing, just read the article and than we
    can talk about your application.
    > smallest
    > place on eeprom
    I think you need to decide if you want to spend time coding and do
    not care about execution time or just write the required data in
    simplest format. 8k x 8 seems to me like a lot of external memory,
    but I do not know details about your application.
    Here is one possible way to code ( as in cipher ) the date:
    Since 25c65 is 8 bits wide and the smallest you can wite at one time
    is 8 bits - the simplest way would an array Date:
    Date(0) Month
    Date(1) Day
    Date(2) Year
    Date(3) Seconds
    Of course you will have to convert the Seconds into Hours/
    Minutes/Seconds or whatever precision you are looking for.
    > Thank you!
    > Rene
