DS1822,1920 1 wire thermometer
I am relatively new to the basic stamp, and i have successfully been
able talk to my ds1822 dallas 1 wire thermometer, however they come
default for 12 bit, which is a slow conversion, I have tried several
different sequences to write to the configuration register of the
sensor to change it to 9 bit resolution which would be a faster
conversion, I am using a BS2P24 and the OWOUT command, from what i
understand by reading dallas docs that after i send the write
scratchpad command my pointer is set at location 2, 0 and 1 are read
only, and that I should be able to just send binary 00 to it for
resolution change, if anyone has a sample command that successfully
initializes the write scratchpad and then sends data to the config
registers, would be greatly appreciated.
-christopher
-christopher
Make sure you are using the correct mode for OWOUT.
mode 1 resets the bus then sends data a byte at a time.
mode 2 sends data a byte at a time THEN resets the bus.
'reset bus then send skip rom
OWOUT OWpin, 1, [noparse][[/noparse]$CC]
'send write scratchpad command and 3 bytes of data then reset the bus
OWOUT OWpin, 2, [noparse][[/noparse]$4E, $00, $00, $00]
Chuck Chargin Jr.
>-christopher
>from the same email address that you subscribed. Text in the Subject and
>Body of the message will be ignored.
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
