Need help With Stepper Motor
Hi all, i have 3 fairly large stepper motors. they each have a 6 pin
connector attached to them. i have interfaced a ULN2003A (www.jameco.com)
stepper driver and configured it the same way in stampworks experiment #26.
i thought that this code below would turn the motor. what is going wrong?
coils var outb
spin
coils = %1100
coils = %0110
coils = %0011
coils = %1001
goto spin
the steppers appear to be 12V the external power GND for the stepper is
connected to VSS.
Id appreciate any help. Thanks GaryD
coils var outb
spin
coils = %1100
coils = %0110
coils = %0011
coils = %1001
goto spin
connected to VSS.
changes.
coils VAR OUTB
Setup:
DIRB = %1111
Spin:
coils = %1100
PAUSE 25
coils = %0110
PAUSE 25
coils = %0011
PAUSE 25
coils = %1001
PAUSE 25
GOTO Spin
-- Jon Williams
-- Dallas Office
From: Gary Denison [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=6vLRXIk8bQUCy_MuwgKlMPjd-RQ31z7J5T8At2d_EfdsXBUq-Ng6ifiKT3SPUWNzt45QXg]gdii@c...[/url
Sent: Tuesday, September 30, 2003 11:01 AM
Subject: [noparse][[/noparse]basicstamps] Need help With Stepper Motor
(www.jameco.com)
#26.
wrong?
coils var outb
spin
coils = %1100
coils = %0110
coils = %0011
coils = %1001
goto spin
connected to VSS.
Your use of Yahoo! Groups is subject to
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
is the code is running so fast that before the first instruction can be
executed it has loop a couple times which would make the stepper not spin.
Don't know it that is your problem but it is my guess.
Jason
Sent: Tuesday, September 30, 2003 10:01 AM
#26.
> coils var outb
> spin
> coils = %1100
> coils = %0110
> coils = %0011
> coils = %1001
> goto spin
> connected to VSS.
larger motors have more mass and need slower pulses to get started.
Once spinning, you can increase the frequency of the pulses. Once
you have gone too fast, the motor will stop abruptly and buzz. makes
you jump, but does not harm the motor.
Also, you mentioned that you have 3 'fairly large' steppers.
Steppers are random in smaller sizes, custome in all ones, but the
NEMA Standard we most often use is the inch square of the mounting
plate. a NEMA 17 is around 1.7 square, or the motor will be close
to fitting into a 1.7 square hole. (Standard does not mean exactly)
NEMA23 is 2.3 inches, NEMA34 is 3.4 inches The NEMA 23 is what is
common in laser printers. (often with a matched driver chip)
The second question is your power supply. you said a fairly large
motor, but you are limited to about 500mA with the darlington. if
your motor has a voltage rating, you can check the resistance to
determine the needed amps to drive the motor.
Just an aside here, if you increase the voltage by using a chopper
driver, you still supply the same amps, you do not calculate amps at
supply voltage, rather calculate at it's design, supply THAT amperage
regardless of voltage, but use a chopper to control pulses at higher
voltages.
Dave
drawing while the motor is running, is only an indication of the
current draw when is in the stall mode.
A true indication of the current draw by the motor is the IMPEDANCE Z
of the motor, so I=Vac/Z the impedance Z is in math terms z=Rdc+jWL
which is a complex number or Z=SQR(Rdc^2+WL^2)
where Rdc is the copper resistance of the windings, W=2*PI*Freq, and
L is the inductance of the windings.
When the motor stalls, L goes to zero.
as a part of a slot machine so i could make my own slot machine.
thanks to your help my wheels are turning. i didn't initialze the
DIRB, and i also added wait commands. my slot machine is turning out
nice. thanks again.
--- In basicstamps@yahoogroups.com, "Jon Williams" <jwilliams@p...>
wrote:
> You need to make the pins outputs and add a bit of a delay between
coil
> changes.
> coils VAR OUTB
> Setup:
> DIRB = %1111
> Spin:
> coils = %1100
> PAUSE 25
> coils = %0110
> PAUSE 25
> coils = %0011
> PAUSE 25
> coils = %1001
> PAUSE 25
> GOTO Spin
> -- Jon Williams
> -- Dallas Office
> From: Gary Denison [noparse][[/noparse]mailto:gdii@c...]
pin
> (www.jameco.com)
experiment
> #26.
> wrong?
> coils var outb
> spin
> coils = %1100
> coils = %0110
> coils = %0011
> coils = %1001
> goto spin
stepper is
> connected to VSS.
Subject
> abuse@p...
<acatano2002@y...> wrote:
> The "resistance" of a motor is not the true indication of the
current
Z
z=Rdc+jWL
and
My reference to current is based on the fact that many motors are
supplied with either amps or volts listed on the nameplate and
without a data sheet, one must determine where to start.
having ohms of the windings and voltage, ohms law yields amps. or
having amps and ohms yields volts.
Most of us do not have super accurate resistance meters for the 1/2
to 20 ohms these motors have and we just use our multi meters.
Getting close is good enough for most hobby purposes. Getting real
performance requires much more than the simple switching we do with
Stamps.
But on your comments, L is the number of windings so unless you get
that from the manufacturer you can only guess what it might be.
As far as current goes, if you over amp the motor, the windings will
saturate and not offer more performance, but will get hotter. if you
under amp, the motor will not offer as good performance. Based on
how the motor responds, close is good enough, and being wrong by a
little won't hurt anything. If the project is critical, buy new, get
the data sheet and use that.
But, a properly running motor will be HOT, 80 deg C is not uncommon.
also manufactures do not recommend using the motors at the low
voltages we are stuck with running them. a typical 5V motor will be
run at 48VDC per the manufactures data sheets. In fact, I have yet
to see a motor manufacturer publish a 5 volt graph on a data sheet.
Higher voltage requires a chopper type driver or high quality uni-
polar. not the darlingtons we use as a driver circuit.
The motor specs are nameplate volts, measured resistance and either
calculate amps or nameplate amps. it is from these that the
calculations are usually based.
Hope that helps.
Dave
L is the Inductance of the motor in Henrys no a number of windings.
You can not over amp or under amp a motor.
The running Current only depends in the Motor itself, Voltage
applied, and load.
> A clarification.
> applied, and load.
Op's should have said, Induction follows the square of the number of
turns. So, although it is related it is not number of turns. and as
you mentioned, it is expressed in Henry's.
`over amp' is a term used to describe any motors that are pulling
more amps than are expected due to load, or a power supply feeding
more current than necessary.
'Under amp' is a term used to describe a power supply that is not
sufficient to deliver the power needed by the motor.
Think of iron in a motor as being composed of billions of little bar
magnets called magnetic dipoles. You run some current thru a coil
surrounding this iron and some of the dipoles will line up north to
south, making the iron an electromagnet. Run yet more current thru
and even more will line up. Eventually, at some current, all dipoles
will be lined up. Increasing the current further will have no
additional effect because 100% of the dipoles have lined up. This is
magnetic saturation or `over amps'
Since we are talking specifically about stepper motors, some special
considerations are needed.
In a stepper motor that has the specs of 5 volts, 1 amp, 5 ohms, the
motor would be rated for 5 watts.
A chopper driver on said motor might be powered by 70 volts. if the
motor were fed 70 volts directly, the motor wires would overheat and
short.
If, on the other hand, the chopper driver were to monitor the current
out to the motor so only 1 amp was sent to a coil, it would control
the transistor so 1 amp were delivered. The feedback would signal
the driver circuit to chop or cut the current so the motor did not
see more energy.
Since the chopper circuit needs to be set for some value, an external
loop to set the current level of the chopper needs to be in place.
If one sets that to 5 amps, then the chopper will deliver 5 amps to
the motor, thus 'over amping' the motor will get hot as the energy
cannot be turned into motion but is delivered as heat. Since the
coils become saturated, they cannot do more work and energy is wasted.
In turn, if one were to set the motor driver circuit to 0.5 amps, the
chopper circuit could not deliver enough energy to energize the
magnetic field to create near the motor rated output power, thus an
under amp condition.
On a stepper motor in 6 wire , or unipolar use, we use a constant
current circuit and use a resistor to limit the current. This is
based on the watts of the motor at nameplate ratings or calculated
from knowns of the motor. ie: Volts on nameplate and measured ohms.
If you do not use the limiting resistor, the motor will act as a
short circuit because the stepper motor is not turning, no motion,
inductance will drop to zero and the motor will burn up.
Dave
- center tap to one end of the coil is 35 ohms
- across full length of coil is about 75 ohms
how do i calculate a possible power supply for these steppers
there is no voltage rating but they seem to work fine on 12 volts.
should i just build a 12 regulator? what amperage regulator should i use.
i dont want to over amp or under amp these steppers.
thanks Gary D
At 02:11 PM 10/2/2003 +0000, you wrote:
>--- In basicstamps@yahoogroups.com, "Albert Catano"
> > A clarification.
> > applied, and load.
>short.
>see more energy.
>Dave
> One more question for you guys, the resistance of coils:
i use.
> thanks Gary D
Hi Gary,
do you hve any other spec's of the motors ?
manufacturer ? Where did you get them ?
how large is the mounting plate ?
is it a square plate and round body about 2.3 " dia ?
Is it one of the pressed steel cans for the mini steppers like on a
printer ? or a more robust fully machined unit ?
There are some general watt ranges for steppers so you can work
backwards with the data you have and some guesses.
Since the wattage of the steppers is pretty constant in a size range,
you can find a similar unit, find watts of that unit, then calculate
what the volts and amps would be.
on the surface, it sounds like a high voltage motor.
for example a VEXTA, NEMA23, round body, might be 5.6 volts, 1.5
amps. resistance should be around 3.76 ohms. Watts around 8.4.
assuming a similar sized motor with about the same amp rating and 33
ohms, 1.5 x 33 = 49 volts More than likely, the motor will have
lower amps and therefore a lower total voltage.
Smaller motors may have much different spec's as they are not as
precison and will have poor efficeincies.
Newer, square body motors have higher efficiencies.
Dave
