Code Reset Question
Hey Guys,
I'm new to Basic Stamp programming and new to this group so please excuse
any newbie questions or comments. Rest assured, I've search the archives
for answers before asking.
I've got a simple test program (Code Below) that detects a button press but
only one button press per press. What I'm trying to do is count the number
of times the button is pressed and store the number in a variable. However,
when my Active High switch is released, following a button press, the code
gets re-initialized (i.e. the INIT: code runs again) and resets the counter
(NUMBEEPS) to 0. I've tried using the BUTTON command but the code was reset
upon button release using that method as well.
THE MEAT OF THE PROBLEM:
I have an application (with buttons) that will be displaying information on
an LCD. I don't want to re-initialize the LCD after each button press.
How can I capture button presses without re-initializing the code after the
button is released?
Thanks so much for your help!
Scott
'{$STAMP BS2sx}
INIT:
NUMBEEPS VAR Byte
NUMBEEPS = 0
LOCK VAR Bit
LOCK = 0
INPUT 4
LOW 4
DEBUG "Start",CR
BtnWrk VAR Byte
MAIN:
PAUSE 100
GOSUB CHECK_BUTTON
'---commented out---BUTTON 3,0,255,255,BtnWrk,1,DO_BEEP
'pin,downstate,delay,rate,bytevariable,targetstate,address
GOTO MAIN
CHECK_BUTTON:
DEBUG ? IN4
IF(IN4 = 0) THEN DO_UNLOCK
IF(IN4 = 1) THEN DO_BEEP
RETURN
DO_BEEP:
DEBUG ? NUMBEEPS, CR
IF(LOCK = 1) THEN MAIN
LOCK = 1
NUMBEEPS = NUMBEEPS + 1
I VAR Byte
FOR I = 1 TO NUMBEEPS
FREQOUT 2,1500,2500
NEXT
GOTO DO_BEEP
DO_UNLOCK:
LOCK = 0
GOTO MAIN
button is released?
Scott
'{$STAMP BS2sx}
INIT:
NUMBEEPS VAR Byte
NUMBEEPS = 0
LOCK VAR Bit
LOCK = 0
INPUT 4
LOW 4
DEBUG "Start",CR
BtnWrk VAR Byte
MAIN:
PAUSE 100
GOSUB CHECK_BUTTON
GOTO MAIN
CHECK_BUTTON:
DEBUG ? IN4
RETURN
DO_BEEP:
LOCK = 1
I VAR Byte
FREQOUT 2,1500,2500
NEXT
GOTO DO_BEEP
DO_UNLOCK:
LOCK = 0
GOTO MAIN
or 0 (there is a tiny chance you would exactly hit a transition and miss
both tests, but it is a very tiny chance). So you wind up at DO_UNLOCK or
DO_BEEP.
The problem seems that both of these routines end with GOTO MAIN (or THEN
MAIN, in the case of DO_BEEP). So the call stack is just rolling over and
over. Seems like you should just end with RETURN.
However, that may not be your problem. You mention that your INIT code is
called again. This could be because of a stack underflow (but I think you
are overflowing). Or it could be that you are driving something (the
speaker/buzzer maybe?) that is causing the Stamp to "brown out" or reset.
With motors, for example, it is often necessary to put a large capacitor
across the power supply to keep it from browning out. Noise coupled to the
ATN line can do this too. There are a few articles about this at
http://www.wd5gnr.com/stampfaq.htm.
Hope some of that helps.
Al Williams
AWC
*New kits: http://www.al-williams.com/kits.htm
> From: Scott Wilkinson [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=wSwjPrC2I1uMn4y06OV7OfnoTcv3hXRlv3xu8g03xdZ1UbfIlU3jqmf7EfG5wTOO6m_jaGx-gKleeypE87x51CY]smwilkinson@e...[/url
> Sent: Tuesday, September 30, 2003 9:43 AM
> Subject: [noparse][[/noparse]basicstamps] Code Reset Question
> Hey Guys,
> please excuse any newbie questions or comments. Rest
> assured, I've search the archives for answers before asking.
> button press but only one button press per press. What I'm
> trying to do is count the number of times the button is
> pressed and store the number in a variable. However, when my
> code gets re-initialized (i.e. the INIT: code runs again) and
> resets the counter
> code was reset upon button release using that method as well.
> information on an LCD. I don't want to re-initialize the LCD
> code after the button is released?
> Scott
> '{$STAMP BS2sx}
> INIT:
> NUMBEEPS VAR Byte
> NUMBEEPS = 0
> LOCK VAR Bit
> LOCK = 0
> INPUT 4
> LOW 4
> DEBUG "Start",CR
> BtnWrk VAR Byte
> MAIN:
> PAUSE 100
> GOSUB CHECK_BUTTON
> GOTO MAIN
> CHECK_BUTTON:
> DEBUG ? IN4
> RETURN
> DO_BEEP:
> LOCK = 1
> I VAR Byte
> FREQOUT 2,1500,2500
> NEXT
> GOTO DO_BEEP
> DO_UNLOCK:
> LOCK = 0
> GOTO MAIN
> from the same email address that you subscribed. Text in the
Thanks for the suggestions. I changed all PIN = 0s to PIN < 1s.
Changed GOTO to RETURN and made it so the conditional statements
(IF...) just skipped the body of the current sub instead of
executing a GOTO. I even commented out the beeper code so that the
only pin doing anything special is the button pin. I can't imagine
that would cause a brown-out. INIT: still gets re-executed when the
button is released.
Can you think of anything else I can try?
Thanks again!
Scott
Changed Code Below:
'{$STAMP BS2sx}
INIT:
NUMBEEPS VAR Byte
NUMBEEPS = 0
LOCK VAR Bit
LOCK = 0
INPUT 4
LOW 4
DEBUG "Start",CR
BtnWrk VAR Byte
MAIN:
PAUSE 100
GOSUB CHECK_BUTTON
GOTO MAIN
CHECK_BUTTON:
DEBUG ? IN4
'----IF(IN4 = 0) THEN DO_UNLOCK
IF(IN4 < 1) THEN DO_UNLOCK 'Added to try and prevent reset
'----IF(IN4 = 1) THEN DO_BEEP
IF(IN4 = 1 AND LOCK = 0) THEN DO_BEEP
RETURN
DO_BEEP:
'----IF(LOCK = 1) THEN MAIN
IF(LOCK = 1) THEN Skip_Beep 'Added to try and prevent reset
LOCK = 1
I VAR Byte
'----FREQOUT 2,1500,2500
NEXT
Skip_Beep:'Added to try and prevent reset
'----GOTO DO_BEEP
RETURN 'Added to try and prevent reset
DO_UNLOCK:
LOCK = 0
'----GOTO MAIN
--- In basicstamps@yahoogroups.com, "Al Williams" <alw@a...> wrote:
> Just from a quick glance. You do a GOSUB CHECK_BUTTON. However,
in4 must = 1
and miss
DO_UNLOCK or
> DO_BEEP.
(or THEN
over and
code is
think you
(the
reset.
capacitor
coupled to the
> Al Williams
> AWC
> > From: Scott Wilkinson [noparse][[/noparse]mailto:smwilkinson@e...]
> > Hey Guys,
> > resets the counter
> > Scott
> > '{$STAMP BS2sx}
> > INIT:
> > NUMBEEPS VAR Byte
> > NUMBEEPS = 0
> > LOCK VAR Bit
> > LOCK = 0
> > INPUT 4
> > LOW 4
> > DEBUG "Start",CR
> > BtnWrk VAR Byte
> > MAIN:
> > PAUSE 100
> > GOSUB CHECK_BUTTON
> > GOTO MAIN
> > CHECK_BUTTON:
> > DEBUG ? IN4
> > RETURN
> > DO_BEEP:
> > LOCK = 1
> > I VAR Byte
> > FREQOUT 2,1500,2500
> > NEXT
> > GOTO DO_BEEP
> > DO_UNLOCK:
> > LOCK = 0
> > GOTO MAIN
works. If it does, then check the circuitry of your output circuit. Are
you drawing too much current, causing the stamp to reset? Don't know if
this is the case or not, but I did have a problem in the past where I set an
output, pulled too much current and dropped the voltage below the brownout
setting. Can't remember the specifics, it may have been on a pick. However
if anyone can mess up a hardware project it be me!
Sent: Tuesday, September 30, 2003 7:06 PM
Subject: [noparse][[/noparse]basicstamps] Re: Code Reset Question
> Al,
> button is released.
> Thanks again!
> Scott
> Changed Code Below:
> '{$STAMP BS2sx}
> INIT:
> NUMBEEPS VAR Byte
> NUMBEEPS = 0
> LOCK VAR Bit
> LOCK = 0
> INPUT 4
> LOW 4
> DEBUG "Start",CR
> BtnWrk VAR Byte
> MAIN:
> PAUSE 100
> GOSUB CHECK_BUTTON
> GOTO MAIN
> CHECK_BUTTON:
> DEBUG ? IN4
> RETURN
> DO_BEEP:
> LOCK = 1
> I VAR Byte
> NEXT
> '----GOTO DO_BEEP
> DO_UNLOCK:
> LOCK = 0
> '----GOTO MAIN
> in4 must = 1
> and miss
> DO_UNLOCK or
> > DO_BEEP.
> (or THEN
> over and
> code is
> think you
> (the
> reset.
> capacitor
> coupled to the
> > Al Williams
> > AWC
> > > Hey Guys,
> > > resets the counter
> > > Scott
> > > '{$STAMP BS2sx}
> > > INIT:
> > > NUMBEEPS VAR Byte
> > > NUMBEEPS = 0
> > > LOCK VAR Bit
> > > LOCK = 0
> > > INPUT 4
> > > LOW 4
> > > DEBUG "Start",CR
> > > BtnWrk VAR Byte
> > > MAIN:
> > > PAUSE 100
> > > GOSUB CHECK_BUTTON
> > > GOTO MAIN
> > > CHECK_BUTTON:
> > > DEBUG ? IN4
> > > RETURN
> > > DO_BEEP:
> > > LOCK = 1
> > > I VAR Byte
> > > FREQOUT 2,1500,2500
> > > NEXT
> > > GOTO DO_BEEP
> > > DO_UNLOCK:
> > > LOCK = 0
> > > GOTO MAIN
Great suggestion. My sense and sensibility tells me you are
correct. Unfortunately, I'm so new to this I have no idea how to
set it up correctly and therefore prove your hypothesis. Still, I
believe more evidence that you are on to something is probably the
fact that I changed the code to:
INIT:
INPUT 4
LOW 4
DEBUG "Start", CR
MAIN:
PAUSE 100
GOSUB CHECK_BUTTON
GOTO MAIN
CHECK_BUTTON:
DEBUG ? IN4
RETURN
When the button is released INIT: is still re-executed.
I'm using the Stamp Stack on a breadboard with a BS2SX chip. I'm
feeding in 7 Volts (From a RadioShack 1.5 - 12 Volt variable power
source) unregulated except via the Stamp Stacks voltage regulation.
Don't laugh. Except for the occasional shock do to mishandling an
extension cord I'm very new to this electrical stuff.
Thanks for your feedback. I'll do some research to discover the
meaning of what you said and therefore, most likely, the answer to
my problem.
Have a great day!
Scott
--- In basicstamps@yahoogroups.com, "Richard Skinner"
<rwskinner@w...> wrote:
> Not sure of your hardware setup, but rem out the Goto Unlock and
see if it
circuit. Are
know if
where I set an
brownout
pick. However
> From: "lcg30339" <smwilkinson@e...>
> > Al,
the
imagine
the
> > button is released.
> > Thanks again!
> > Scott
> > Changed Code Below:
> > '{$STAMP BS2sx}
> > INIT:
> > NUMBEEPS VAR Byte
> > NUMBEEPS = 0
> > LOCK VAR Bit
> > LOCK = 0
> > INPUT 4
> > LOW 4
> > DEBUG "Start",CR
> > BtnWrk VAR Byte
> > MAIN:
> > PAUSE 100
> > GOSUB CHECK_BUTTON
> > GOTO MAIN
> > CHECK_BUTTON:
> > DEBUG ? IN4
> > RETURN
> > DO_BEEP:
> > LOCK = 1
> > I VAR Byte
> > NEXT
> > '----GOTO DO_BEEP
> > DO_UNLOCK:
> > LOCK = 0
> > '----GOTO MAIN
> > in4 must = 1
> > and miss
> > DO_UNLOCK or
> > > DO_BEEP.
MAIN
> > (or THEN
rolling
> > over and
INIT
> > code is
> > think you
> > (the
out" or
> > reset.
> > capacitor
> > coupled to the
at
> > > Al Williams
> > > AWC
> > > > Hey Guys,
> > > > resets the counter
> > > > Scott
> > > > '{$STAMP BS2sx}
> > > > INIT:
> > > > NUMBEEPS VAR Byte
> > > > NUMBEEPS = 0
> > > > LOCK VAR Bit
> > > > LOCK = 0
> > > > INPUT 4
> > > > LOW 4
> > > > DEBUG "Start",CR
> > > > BtnWrk VAR Byte
> > > > MAIN:
> > > > PAUSE 100
> > > > GOSUB CHECK_BUTTON
> > > > GOTO MAIN
> > > > CHECK_BUTTON:
> > > > DEBUG ? IN4
> > > > RETURN
> > > > DO_BEEP:
> > > > LOCK = 1
> > > > I VAR Byte
> > > > FREQOUT 2,1500,2500
> > > > NEXT
> > > > GOTO DO_BEEP
> > > > DO_UNLOCK:
> > > > LOCK = 0
> > > > GOTO MAIN
Subject and
okay and reset is not until you dip down to 4.2 volts so I'm not sure what
is up unless your button circuitry is wrong. Please explain how you have
the button hooked up. If I understand correctly, it only resets after you
mess with the button correct? Change the following to get rid of all
hardware problems:
CHECK_BUTTON:
DEBUG "Hello"
RETURN
If it works and does not rest, which I'm sure it will not reset, then look
into the way you have the button wired up.
Normally, depending on your setup, You should have the following for a
active high:
5 vdc to button
then
button to stamp pin Plus
button to 10K resistor to ground
10k
5vdc
.button.
|---www----Ground
Stamp Pin
Pushing the button will read high, when the button is not pushed it reads
low.
Richard
Sent: Tuesday, September 30, 2003 10:24 PM
> Richard,
> INIT:
> INPUT 4
> LOW 4
> DEBUG "Start", CR
> MAIN:
> PAUSE 100
> GOSUB CHECK_BUTTON
> GOTO MAIN
> CHECK_BUTTON:
> DEBUG ? IN4
> RETURN
> my problem.
> Have a great day!
> Scott
> see if it
> circuit. Are
> know if
> where I set an
> brownout
> pick. However
> > > Al,
> the
> imagine
> the
> > > button is released.
> > > Thanks again!
> > > Scott
> > > Changed Code Below:
> > > '{$STAMP BS2sx}
> > > INIT:
> > > NUMBEEPS VAR Byte
> > > NUMBEEPS = 0
> > > LOCK VAR Bit
> > > LOCK = 0
> > > INPUT 4
> > > LOW 4
> > > DEBUG "Start",CR
> > > BtnWrk VAR Byte
> > > MAIN:
> > > PAUSE 100
> > > GOSUB CHECK_BUTTON
> > > GOTO MAIN
> > > CHECK_BUTTON:
> > > DEBUG ? IN4
> > > RETURN
> > > DO_BEEP:
> > > LOCK = 1
> > > I VAR Byte
> > > NEXT
> > > '----GOTO DO_BEEP
> > > DO_UNLOCK:
> > > LOCK = 0
> > > '----GOTO MAIN
> > > in4 must = 1
> > > and miss
> > > DO_UNLOCK or
> > > > DO_BEEP.
> MAIN
> > > (or THEN
> rolling
> > > over and
> INIT
> > > code is
> > > think you
> > > (the
> out" or
> > > reset.
> > > capacitor
> > > coupled to the
> at
> > > > Al Williams
> > > > AWC
> > > > > Hey Guys,
> > > > > resets the counter
> > > > > Scott
> > > > > '{$STAMP BS2sx}
> > > > > INIT:
> > > > > NUMBEEPS VAR Byte
> > > > > NUMBEEPS = 0
> > > > > LOCK VAR Bit
> > > > > LOCK = 0
> > > > > INPUT 4
> > > > > LOW 4
> > > > > DEBUG "Start",CR
> > > > > BtnWrk VAR Byte
> > > > > MAIN:
> > > > > PAUSE 100
> > > > > GOSUB CHECK_BUTTON
> > > > > GOTO MAIN
> > > > > CHECK_BUTTON:
> > > > > DEBUG ? IN4
> > > > > RETURN
> > > > > DO_BEEP:
> > > > > LOCK = 1
> > > > > I VAR Byte
> > > > > FREQOUT 2,1500,2500
> > > > > NEXT
> > > > > GOTO DO_BEEP
> > > > > DO_UNLOCK:
> > > > > LOCK = 0
> > > > > GOTO MAIN
> Subject and
Thanks to Richard's suggestion I set the button to be Active Low
instead of Active High and no longer get the impromptu reset. Once
again, I have effectively circumvented my limited knowledge. Thanks
again to all those who attempted to help. To the rest, I'm sure
you will have another opportunity very soon.
Scott
--- In basicstamps@yahoogroups.com, "lcg30339" <smwilkinson@e...>
wrote:
> Richard,
> INIT:
> INPUT 4
> LOW 4
> DEBUG "Start", CR
> MAIN:
> PAUSE 100
> GOSUB CHECK_BUTTON
> GOTO MAIN
> CHECK_BUTTON:
> DEBUG ? IN4
> RETURN
> my problem.
> Have a great day!
> Scott
> see if it
> circuit. Are
> know if
> where I set an
the
> brownout
> pick. However
> > > Al,
1s.
statements
> the
> imagine
when
> the
> > > button is released.
> > > Thanks again!
> > > Scott
> > > Changed Code Below:
> > > '{$STAMP BS2sx}
> > > INIT:
> > > NUMBEEPS VAR Byte
> > > NUMBEEPS = 0
> > > LOCK VAR Bit
> > > LOCK = 0
> > > INPUT 4
> > > LOW 4
> > > DEBUG "Start",CR
> > > BtnWrk VAR Byte
> > > MAIN:
> > > PAUSE 100
> > > GOSUB CHECK_BUTTON
> > > GOTO MAIN
> > > CHECK_BUTTON:
> > > DEBUG ? IN4
> > > RETURN
> > > DO_BEEP:
> > > LOCK = 1
> > > I VAR Byte
> > > NEXT
> > > '----GOTO DO_BEEP
> > > DO_UNLOCK:
> > > LOCK = 0
> > > '----GOTO MAIN
However,
> > > in4 must = 1
transition
> > > and miss
> > > DO_UNLOCK or
> > > > DO_BEEP.
> MAIN
> > > (or THEN
> rolling
> > > over and
> INIT
> > > code is
(but I
> > > think you
something
> > > (the
> out" or
> > > reset.
large
> > > capacitor
> > > coupled to the
this
> at
> > > > Al Williams
> > > > AWC
> > > > > Hey Guys,
asking.
my
the
and
> > > > > resets the counter
the
well.
displaying
LCD
the
> > > > > Scott
> > > > > '{$STAMP BS2sx}
> > > > > INIT:
> > > > > NUMBEEPS VAR Byte
> > > > > NUMBEEPS = 0
> > > > > LOCK VAR Bit
> > > > > LOCK = 0
> > > > > INPUT 4
> > > > > LOW 4
> > > > > DEBUG "Start",CR
> > > > > BtnWrk VAR Byte
> > > > > MAIN:
> > > > > PAUSE 100
> > > > > GOSUB CHECK_BUTTON
> > > > > GOTO MAIN
> > > > > CHECK_BUTTON:
> > > > > DEBUG ? IN4
> > > > > RETURN
> > > > > DO_BEEP:
> > > > > LOCK = 1
> > > > > I VAR Byte
> > > > > FREQOUT 2,1500,2500
> > > > > NEXT
> > > > > GOTO DO_BEEP
> > > > > DO_UNLOCK:
> > > > > LOCK = 0
> > > > > GOTO MAIN
the
> Subject and
I believe the problem is that you're never returning from your gosub
CHECK_BUTTON.
The easiest fix would probably be to add label CHECK_BUTTON_RETURN before
the return from CHECK_BUTTON, and replace the references to MAIN in
DO_UNLOCK and DO_BEEP with CHECK_BUTTON_RETURN.
Greg Ross
From: Scott Wilkinson [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=fuAW_JRCPc4GWtS9r9s6H7w3oXu1VUdeoDUObjqNk-2HWbS33zda_LmcnRRT1iv2XImFj-c6Bqe-M2jJ568Ulg]smwilkinson@e...[/url
Sent: Tuesday, September 30, 2003 7:43 AM
Hey Guys,
button is released?
Scott
'{$STAMP BS2sx}
INIT:
NUMBEEPS VAR Byte
NUMBEEPS = 0
LOCK VAR Bit
LOCK = 0
INPUT 4
LOW 4
DEBUG "Start",CR
BtnWrk VAR Byte
MAIN:
PAUSE 100
GOSUB CHECK_BUTTON
GOTO MAIN
CHECK_BUTTON:
DEBUG ? IN4
RETURN
DO_BEEP:
LOCK = 1
I VAR Byte
FREQOUT 2,1500,2500
NEXT
GOTO DO_BEEP
DO_UNLOCK:
LOCK = 0
GOTO MAIN
How is your button hooked up? Is there a chance it is short
circuiting the power supply, or that it is connecting the power
supply directly to pin p4? I notice that your code makes p4 LOW and
then tests to do some something when it finds p4 HIGH. Once you make
p4 a LOW output, something pretty drastic will have to happen
externally to force it HIGH!!!
Try this program:
'{$STAMP BS2sx}
'{$PBASIC 2.5}
debug "start",cr
' LOW 4 ' try it with this commented out, and then with it back in
DO
debug in4
LOOP ' forever
-- Tracy
regulation drop-out voltage. Try 7.5 volts,
or 9 volts.
wrote:
> Richard,
> INIT:
> INPUT 4
> LOW 4
> DEBUG "Start", CR
> MAIN:
> PAUSE 100
> GOSUB CHECK_BUTTON
> GOTO MAIN
> CHECK_BUTTON:
> DEBUG ? IN4
> RETURN
> my problem.
> Have a great day!
> Scott
> see if it
> circuit. Are
> know if
> where I set an
> brownout
> pick. However
> > > Al,
> the
> imagine
> the
> > > button is released.
> > > Thanks again!
> > > Scott
> > > Changed Code Below:
> > > '{$STAMP BS2sx}
> > > INIT:
> > > NUMBEEPS VAR Byte
> > > NUMBEEPS = 0
> > > LOCK VAR Bit
> > > LOCK = 0
> > > INPUT 4
> > > LOW 4
> > > DEBUG "Start",CR
> > > BtnWrk VAR Byte
> > > MAIN:
> > > PAUSE 100
> > > GOSUB CHECK_BUTTON
> > > GOTO MAIN
> > > CHECK_BUTTON:
> > > DEBUG ? IN4
> > > RETURN
> > > DO_BEEP:
> > > LOCK = 1
> > > I VAR Byte
> > > NEXT
> > > '----GOTO DO_BEEP
> > > DO_UNLOCK:
> > > LOCK = 0
> > > '----GOTO MAIN
However,
> > > in4 must = 1
transition
> > > and miss
> > > DO_UNLOCK or
> > > > DO_BEEP.
> MAIN
> > > (or THEN
> rolling
> > > over and
> INIT
> > > code is
I
> > > think you
something
> > > (the
> out" or
> > > reset.
> > > capacitor
> > > coupled to the
> at
> > > > Al Williams
> > > > AWC
> > > > > Hey Guys,
my
the
and
> > > > > resets the counter
the
well.
LCD
> > > > > Scott
> > > > > '{$STAMP BS2sx}
> > > > > INIT:
> > > > > NUMBEEPS VAR Byte
> > > > > NUMBEEPS = 0
> > > > > LOCK VAR Bit
> > > > > LOCK = 0
> > > > > INPUT 4
> > > > > LOW 4
> > > > > DEBUG "Start",CR
> > > > > BtnWrk VAR Byte
> > > > > MAIN:
> > > > > PAUSE 100
> > > > > GOSUB CHECK_BUTTON
> > > > > GOTO MAIN
> > > > > CHECK_BUTTON:
> > > > > DEBUG ? IN4
> > > > > RETURN
> > > > > DO_BEEP:
> > > > > LOCK = 1
> > > > > I VAR Byte
> > > > > FREQOUT 2,1500,2500
> > > > > NEXT
> > > > > GOTO DO_BEEP
> > > > > DO_UNLOCK:
> > > > > LOCK = 0
> > > > > GOTO MAIN
the
> Subject and
