Capacitors
Hi people. I'm new here and wondering if you could help me out. I
have a capacitor which is fairily huge (5600 micro-farads) and has a
fairly high voltage rating considering it's capacitance). The thing
is it has THREE legs. I have no idea what to connect the third one
to. Does anyone here have any idea?
James
James
ensignkim113@y... writes:
______________________________________________________-
James,
This is a Smile shoot, but, literally how physically large is this cap? Some
caps that are physically large (standing 4" tall or better) have a third leg
that is used to help secure the cap to the board and the third leg is not
associated with the postive or negative lead.
I have seen caps explode with incorrect circuit polarity applied, but have
never seen this happen using an ohm meter. Perhaps you could connect one lead of
an ohm meter to this third leg, and check if it has a direct connection to
either the positve or negative leg. If no direct connection to either the
positive or negative leg and the cap is indeed physically large (3 to 4" or more
tall) the third lead MIGHT simply be a type of strain relief for mounting the
cap......that is, it would provide additional mechanical support for the
mounting
of the cap.
case I would expect two values on the side stating capacitance. Can't think of
another reason for three terminals.
Leroy
: Hi people. I'm new here and wondering if you could help me out. I
: have a capacitor which is fairily huge (5600 micro-farads) and has a
: fairly high voltage rating considering it's capacitance). The thing
: is it has THREE legs. I have no idea what to connect the third one
: to. Does anyone here have any idea?
: Thanks
: James
: To UNSUBSCRIBE, just send mail to:
: basicstamps-unsubscribe@yahoogroups.com
: from the same email address that you subscribed. Text in the Subject and Body
: Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
Larry Gaminde
Sent: September 28, 2003 10:00 AM
Subject: Re: [noparse][[/noparse]basicstamps] Capacitors
> Sometimes they put two caps in one can with a common connection. If this
is the
think of
> Leroy
> : Thanks
> : James
and Body
two values. It's most probably is a can shield and mounting lug.
But I would suggest a little low-voltage charging experiment before you
commit this thing to a high-current power supply transformer. Perhaps a
9-volt battery with a 1k resistor in series would let you monitor the charge
rate if you put a VOM across the cap leads. The other posting about
potential explosion of a cap is fair warning. These things can go off like a
small bomb and blow molten aluminum confetti all over the place. Been
there... done that. I would never apply full current to an unknown cap until
it goes through a slow charge and discharge. Nothing bad will happen with
the 9 milliamps max current from a 9 volt batt and 1K resistor.
Let be careful out there....
Mike Sokol
www.modernrecording.com
mikes@m...
" One should not increase, beyond what is necessary,
the number of entities required to explain anything"...
-William of Occam-
Sent: Sunday, September 28, 2003 1:15 PM
> Ground, for a metal can and mounting.
> Larry Gaminde
> From: "Leroy Hall" <leroy@f...>
this
> is the
> think of
> > Leroy
> > : Thanks
> > : James
> and Body
and
