Extended Temp LCD''s..
For - LCD bias you can use a switched capacitor DC to DC convertor.
Maxim, TI, and Linear Tech makes parts just for negative LCD bias. If
you use a MAX232 on your product you can borrow negative voltage from
the part, a few hundred uA shouldn't affect the MAX232 operation.
Jason
--- In basicstamps@yahoogroups.com, "Jon Williams" <jwilliams@p...>
wrote:
> Keep in mind that extended temp LCDs generally have a negative
contrast
> bias requirement. This makes them a bit of a headache in many
> applications.
> -- Jon Williams
> -- Applications Engineer, Parallax
> -- Dallas Office
> From: Timothy Medema [noparse][[/noparse]mailto:timm@c...]
> Sent: Friday, September 19, 2003 2:58 PM
> Subject: [noparse][[/noparse]basicstamps] Extended Temp LCD's..
> Do any of you have a source for extended-temperature LCD's
that
> are easy to use with a BS2? I've checked with Scott Edwards
Electronics
> (www.seetron.com) and they don't have any extended-temp equipment.
I'd
> like a temp range of about 10-100 degrees F.
> Thanks,
> Tim
> Timothy Medema
> CrystaLite, Incorporated
> 3307 Cedar St. (425) 745-6000 800-666-6065
> Everett, WA 98201 Fax: (425) 257-0232
> www.crystaliteinc.com
> <mailto:timm@c...>timm@c...
> The information transmitted is intended only for the person or
entity to
> whom it is addressed and may contain confidential and/or privileged
> material. Any review, retransmission, dissemination or other use
of, or
> taking of any action in reliance upon, this information by persons
> entities other than the intended recipient is prohibited. If you
> received
> this in error, please contact the sender and delete the material
from
> any
> computer.
> from the same email address that you subscribed. Text in the
Subject
> and Body of the message will be ignored.
> This message has been scanned by WebShield. Please report SPAM to
> abuse@p...
Jason
contrast
> applications.
> -- Jon Williams
> -- Dallas Office
that
Electronics
I'd
> Thanks,
> Tim
> Timothy Medema
entity to
of, or
> received
from
> any
> computer.
Subject
> abuse@p...
