QCad Stamp Library
I'm getting better results with QCad that expected.
http://www.winqcad.com/
The problem is the limited librarys. Does anyone have or know of a
library that has the Stamps ?
I know it will import Protel and Orcad files so if Stamps are in
those librarys, let me know.
ditto for PIC's or the chips we typically use and talk about on the
list.
Dave
list.
Dave
Would an MCU pin be considered Tristate or bidirectional? I assumed
bidirectional because you don't really have a "float" command...
Check the files section for the library. QCadStampLib.zip
> From: Dave Mucha [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=6-fDxqnDciFVBJS28fQBcm32vDZ7QSGEFhkeXjS4dtsJy1kIWQCd0OX7rMrXTjLPQRNYbvlLU8tl9Q]davemucha@j...[/url
> Sent: September 22, 2003 10:41 AM
> Subject: [noparse][[/noparse]basicstamps] QCad Stamp Library
> Hi,
> list.
> Dave
> from the same email address that you subscribed. Text in the
fact it IS tristated -- but bi-directional
should do the same thing when the pin
is set as an Input. Also, tristated
tends to imply it's output only
(Out high, out low, tristated 'off'),
so yes, bi-directional is the most
accurate.
--- In basicstamps@yahoogroups.com, PatM <pmeloy@s...> wrote:
> I whipped one up for ya, one question that I always forget to get
clarified.
> > From: Dave Mucha [noparse][[/noparse]mailto:davemucha@j...]
> > Hi,
a
the
> > list.
> > Dave
