Help need to close a small relay
I would like to use a signal from an RS 232 port or a USB port that would
be generated from a program to use a basic stamp to close a small relay that
would allow a digital camera to trip. The camera is equipped with an
external cable release that is just a switch. this would allow me to fully
automate a process for information the camera is a Olympus e-10 but the SDK
for it and the firmware do not allow full automation, however the process
allows the camera to be preset, by having a way to trip the shutter the
whole process would be automated.This process must be repeatable in a
sequence of 60.
Any and all help negative or positive could save my project .
Dave Belgard
sequence of 60.
Dave Belgard
with the clamping diode already on the chip.. or if its only on relay maybe
just use a transistor to drive the relay....
http://www.rentron.com/pc-relay.htm
for both PC or BS controlled relay schematics
>sequence of 60.
>Thanks
>Dave Belgard
>from the same email address that you subscribed. Text in the Subject and
>Body of the message will be ignored.
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
relays such as on this site
http://www.geocities.com/jimforkin2003/ just program the stamp to look for
a specific ascii character and then set the appropriate output high to turn
on the transistor that can switch whatever you want including a relay. The
ascii rs-232 can be generated by any terminal program on a pc.
jim
From: Dave Belgard [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=O2ibp-LCW9lIC3e4n1N9Va4TSjx0bFytpridDu41YessNvwhEJ5l6-31xs1wZDfqd0-SudGAX2KRa84]belphoto@m...[/url
Sent: Friday, September 19, 2003 7:48 PM
Subject: [noparse][[/noparse]basicstamps] Help need to close a small relay
sequence of 60.
Dave Belgard
