Extended Temp LCD''s..
Do any of you have a source for extended-temperature LCD's that
are easy to use with a BS2? I've checked with Scott Edwards Electronics
(www.seetron.com) and they don't have any extended-temp equipment. I'd
like a temp range of about 10-100 degrees F.
Tim
Timothy Medema
CrystaLite, Incorporated
3307 Cedar St. (425) 745-6000 800-666-6065
Everett, WA 98201 Fax: (425) 257-0232
www.crystaliteinc.com
<mailto:timm@c...>timm@c...
The information transmitted is intended only for the person or entity to
whom it is addressed and may contain confidential and/or privileged
material. Any review, retransmission, dissemination or other use of, or
taking of any action in reliance upon, this information by persons or
entities other than the intended recipient is prohibited. If you received
this in error, please contact the sender and delete the material from any
computer.
Tim
Timothy Medema
computer.
