Newbie output\input question
I have the chip 2P40. i have the following:
output 16
MOTOR2_C VAR OUT16
and get the error undefined symbol on the second line just trying to setup an
alias.
does this error have to to with the fact one side ofthe chip is IO the other
side is AUX????
TIA.
Do you Yahoo!?
Yahoo! SiteBuilder - Free, easy-to-use web site design software
output 16
MOTOR2_C VAR OUT16
alias.
side is AUX????
TIA.
Do you Yahoo!?
so the compiler complains.
There IS a 'pseudo-pin' 16, which refers to
the SIN/SOUT port, which is why 'output 16' doesn't
complain. I don't know the command to switch to
the 'X' ports -- anybody know it?
(Could search the Forum for 'X15')
--- In basicstamps@yahoogroups.com, "Mr. M" <the_0utsider1@y...>
> output 16
> MOTOR2_C VAR OUT16
to setup an alias.
the other side is AUX????
> TIA.
> Do you Yahoo!?
normal input / output control.
eg...
serin 16, etc etc
Regards
Chris
Sent: Thursday, September 18, 2003 5:47 AM
Subject: [noparse][[/noparse]basicstamps] Re: Newbie output\input question
> There IS NO 'OUT16', they max out at 'OUT15',
> > output 16
> > MOTOR2_C VAR OUT16
> to setup an alias.
> > TIA.
> > Do you Yahoo!?
I think Ianswered the question a bit fast.
You should read the help for mainio and auxio for the bs2p40 i/o access.
I think you need to switch to auxio and then access pin 0 to access physical
pin 16.
Cheers,
Chris
> > output 16
> > MOTOR2_C VAR OUT16
> to setup an alias.
> > TIA.
> > Do you Yahoo!?
numbers 0 to 15. To get to pin 0 on the auxilliary bank, you would do
this:
AUXIO
OUTPUT 0
To get back to the main bank ...
MAINIO
OUTPUT 0
-- Jon Williams
-- Dallas Office
From: Mr. M [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=0airOWou1eALTbTHWf8kSCAAgSNxbhWxudLqZ4ZdXDHJbC9zIAuu4KorQPghWBRnj9D-VBCfsFgqR0HL7rsIzxGQ]the_0utsider1@y...[/url
Sent: Wednesday, September 17, 2003 3:19 PM
Subject: [noparse][[/noparse]basicstamps] Newbie output\input question
output 16
MOTOR2_C VAR OUT16
setup an alias.
TIA.
Do you Yahoo!?
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
