PulsIn - Bs2 Got it
Okay, I took the easy way out for now.
15 volt PWM Signal coming in and being clamped by a 3.9 zener (what I
had on hand) Stamp reads it and outputs a signal to a RC Network.
Works Perfect, Dead On. Voltage out X 2 = Duty Cycle
I just need the duty cycle indication withing a percent or two so
even if the stamp regulator difts a little it will not hurt me too
bad. Mainly reference readings.
' File: FREQ2.BS2
' Counts and displays frequency of pulses arriving on Pin 0
F_pin CON 7 ' frequency
input pin
VOut CON 6
pHigh VAR Word ' W3 high
pulse width
pLow VAR Word ' W2 low
pulse width
period VAR Word ' cycle time (high +
low)
freq VAR Word ' frequency
T2 Var word
T3 var word
duty var word
Output 6
Loop:
PULSIN F_pin, 0, pHigh ' get high portion of
input
PULSIN F_pin, 1, pLow ' get low portion of
input
period = pHigh + pLow ' calculate cycle
width
t2 = plow
t3 = phigh
t3 = t2 + t3
t3 = t3 / 10
t2 = t2 * 10
t2 = t2/t3
freq = 50000 / period * 10 ' calculate frequency
' display on DEBUG screen
DEBUG Home
DEBUG "Period...... ", DEC period * 2, " uS ", CR
DEBUG "Frequency... ", DEC freq, " Hz ", CR
DEBUG "Duty Cycle ..", Dec t2, "% "
t2 = t2 * 255
t2 = t2 / 100
PWM VOut, t2,150 ' output voltage
porportional to duty cycle (voltage * 2 = duty cycle
GOTO Loop ' do it again
--- In basicstamps@yahoogroups.com, smartdim@a... wrote:
> You may want to consider a MAX5101 DAC.
> It has rail to rail output. It has 3 outputs selected by two lines.
> If you run it on 5 volts, you can then easily amplify by two for a
0 to 10v output, 5 volts = 50% duty, 7.5 volts 75% etc.
> Or if you run it on 10 volts you have 0 to 10 volt output. A cheap
and dirty DAC can be made with a thing called and R2R resistor
network. It is I/O pin hungry though (8 pins), but you can use a
shift register and get away with only 3 pins.
> Ken
' File: FREQ2.BS2
input pin
VOut CON 6
pulse width
pulse width
low)
T2 Var word
T3 var word
duty var word
Output 6
Loop:
input
input
width
t2 = plow
t3 = phigh
t3 = t2 + t3
t3 = t3 / 10
t2 = t2 * 10
t2 = t2/t3
DEBUG Home
t2 = t2 * 255
t2 = t2 / 100
> Ken
skinner02001@y... writes:
________________________________________________________-
Just curious, is the 15 PWM signal buffered before you clamp it with the
zener? Is the solenoid still able to receive full battery voltage?
A word of caution.......
If you have an oscope, I would suggest you look at the "zener clamped" duty
signal. Zener diodes are not particularly fast devices. There may be momentary
spikes greater that 5 volts until the zener clamps. Over time, the momentary
spikes (if they are there ) in time will likely damage that stamp input pin.
Cool project.....I recently did the same, but with a different uP (SX28). It
has a two digit display and analog output that is fed to a data logger. We use
it at my work to look at the duty cycle of transmission lock up solenoids,
and pressure control solenoids on competitor vehicles.
I'm also changing the entire signal going to the Engine computer as
well. I'll go ahead and look at the Buffers and be done with it. At
least I was able to breadboard it all out and make sure it would work
fine (software). I had planned on having two digits as well to
display 0-99 on top for a visual reference by using a couple of bcd
drivers, but then I decided I would do multiple channels on one chip.
Once up and going, I'm moving over the the 16F84.
Richard
> In a message dated 9/16/2003 7:07:27 PM Pacific Daylight Time,
I
with the
clamped" duty
be momentary
momentary
input pin.
(SX28). It
logger. We use
solenoids,
