[Fwd: Re: newbie - replace 3 switches - 5 Volt; 0,1 mA]
Since this inadvertently went to me directly instead of the list I
thought I'd post it and the reponse here [noparse]:)[/noparse]
CLIP
Francesco,
Based on your use, wouldn't it seem you'd be best off with a Joystick
rather than switches? I picture the "long click" or "short click" method
as being troublesome since you would have to make real-time decisions. I
can imagine the chair moving forward while you're clicking away at the
switches trying to get it to stop! [noparse]:)[/noparse]
I know there are lots of folks using the Stamp to create projects so
there might be a number of solutions that are already available. [noparse]:)[/noparse]
Vern
Subject: Re: newbie - replace 3 switches - 5 Volt; 0,1 mA
Date: Tue, September 16, 2003 2:40 pm
To: From:
Hello Vern,
First of all thank you for your reply.
>A few questions for you first:
>Would there be any feedback device for the operator?
>(i.e. beeper, LED indicator?)
If there will be a feedback device, it will be a beeper; this question
has not been settled yet.
>Do the three discrete switches you have now need to stay in a
>postion or are they momentary?
It will be a mix (see explanation below).
>Is the goal of the circuit to reduce the amnount of wire between the
>switch and the device? Iis it to reduce the count of switch components
>thereby reducing cost? Is it to reduce operator error? Reduce operator
>training?
It is to reduce the number of switches:
My powerchair is operated by 3 switches, but I have difficulties to
operate the 3 switches; however I will be able to operate 2 switches with
much more dexterity.
The brand of my powerchair does offer a 2 switch solution, but it is
reduced to scanning: this means it is not possible to steer while
driving: one can only drive straight and has to stop to turn left or
right. Other brands however offer a non-scanning solution with 2
switches.
As I cannot change powerchair, I decided to do it by myself and chose the
Basic Stamp because it is possible to program it in Basic (I have
moderate experience with programming in Pascal and C; so I am a newbie
only at electronics ;-).
The 3 switches of my powerchair are:
switchL is to turn left
switchR is to turn right
switchG is to drive
The powerchair advances as long as switchG is active; as soon as switchG
is released, the powerchair stops independently of the state of the other
two switches; however, while advancing, the switchL steers to the left as
long as switch is active; similar for switchR. (To toggle between
forwards/backwards, I have to activate switchR for 3 seconds while
standing still.)
How will I code it with to switches:
A doule-click on switch1 will toggle the state of switchG
A simple down on switch1 will be momentary with switchL (there will be a
little delay to differentiate between double-click and simple down, but
the speed of the powerchair is so low that it does not matter if switchL
activates about half
a second later after switch1 is activated)
A simple down on switch2 will be momentary with switchR
(For security reasons, there already is an emergency stop; and it will
remain independant from the BS2.)
>Sometimes it is best to know the *goal* of the project (i.e. I will get
>a better response to a questions such as "How do I increase my car gas
>milage" instead of a question such as "how do I adjust the timing of my
>distributor?" since in the latter, you may have decided that adjusting
>the distributor is the only solution, thereby limiting what others may
>offer for advice on the *real* goal.)
>The answer to these questions would help in guiding my (and
>others) responses... [noparse]:)[/noparse]
>That being said, it would be possible to use two SPST switches to
>produce the output of three SPST switches using binary as such:
>S1 S2 S1 S2 S3
>0 0 = 0 0 0
>1 0 = 1 0 0
>0 1 = 0 1 0
>1 1 = 0 0 1
>Again, I have to work with assumptions that may not be correct in
>your circumstances (i.e. there are no "combo" positions of the
>three switches where more than one is closed at a time)
An activation of switcheL and switchR will be possible while switchG is
active (to steer while driving); so a combo position will be possible.
Moreoever the two switches I will use, will be mutually exclusive; so
(S1,S2) = (1,1) will not be possible.
I measured the sockets where switchL and switchG will be connected to,
and it read: 4.9 VDC; 0.1 mA.
If you have any suggestion, especially about how to create the circuit
for the 3 output switches, I will be glad to here about it.
Have a nice day.
Francesco
>Francesco Fumanti said:
>> Hello,
>> I want to replace 3 (A,B,C) handswitches with 2 switches (1,2); for
example a double click of switch1 will toggle switchB; a long click
on switch1 will activate switchA for as long as switch1 is active;...
>> ________
>> --Switch1-->
>> | |--switchA->---
>> | BS2 |--switchB->---
>> | |--switchC->---
>> --Switch2-->
>> |________|
>> How to connect the input switches to the BS2 is discribed in the
Basic Stamp manual; but how can I create the 3 SPST normaly open
output switches?
>> I found a schematic, where a pin of the BS2 controls a transistor,
which controls a relay (as the BS2 cannot provide enough current for
the relay).
>> I measured the tension and current of the socket where the
>> switches A, B, C will be connected to: 4.9 V and 0.1 mA for
>> each socket.
>> Could you please tell me precisely what transistor or relay to
>> use? Moreover, as I am a complete newbie in electronics could
>> you please tell me whether there is a more elegant way to
>> implement the 3 output switches? Maybe an IC? a Solid State
>> Relay? What IC?
>> Thanks in advance for your help.
>> Francesco Fumanti
CLIP
Francesco,
Vern
To: From:
Hello Vern,
>training?
switches.
switchG is to drive
standing still.)
>S1 S2 S1 S2 S3
>0 0 = 0 0 0
>1 0 = 1 0 0
>0 1 = 0 1 0
>1 1 = 0 0 1
Have a nice day.
Francesco
>> Hello,
>> ________
>> --Switch1-->
>> | |--switchA->---
>> | BS2 |--switchB->---
>> | |--switchC->---
>> --Switch2-->
>> |________|
output switches?
the relay).
>> each socket.
>> Relay? What IC?
>> Francesco Fumanti
