newbie - replace 3 switches - 5 Volt; 0,1 mA
Hello,
I want to replace 3 (A,B,C) handswitches with 2 switches (1,2); for
example a double click of switch1 will toggle switchB; a long click
on switch1 will activate switchA for as long as switch1 is active;...
________
--Switch1-->
| |--switchA->---
| BS2 |--switchB->---
| |--switchC->---
--Switch2-->
|________|
How to connect the input switches to the BS2 is discribed in the
Basic Stamp manual; but how can I create the 3 SPST normaly open
output switches?
I found a schematic, where a pin of the BS2 controls a transistor,
which controls a relay (as the BS2 cannot provide enough current
for the relay).
I measured the tension and current of the socket where the
switches A, B, C will be connected to: 4.9 V and 0.1 mA for
each socket.
Could you please tell me precisely what transistor or relay to
use? Moreover, as I am a complete newbie in electronics could
you please tell me whether there is a more elegant way to
implement the 3 output switches? Maybe an IC? a Solid State
Relay? What IC?
Thanks in advance for your help.
Francesco Fumanti
________
--Switch1-->
| |--switchA->---
| BS2 |--switchB->---
| |--switchC->---
--Switch2-->
|________|
output switches?
for the relay).
each socket.
Relay? What IC?
Francesco Fumanti
Would there be any feedback device for the operator? (i.e. beeper, LED
indicator?)
Do the three discrete switches you have now need to stay in a postion or
are they momentary?
Is the goal of the circuit to reduce the amnount of wire between the
switch and the device? Iis it to reduce the count of switch components
thereby reducing cost? Is it to reduce operator error? Reduce operator
training?
Sometimes it is best to know the *goal* of the project (i.e. I will get a
better response to a questions such as "How do I increase my car gas
milage" instead of a question such as "how do I adjust the timing of my
distributor?" since in the latter, you may have decided that adjusting
the distributor is the only solution, thereby limiting what others may
offer for advice on the *real* goal.)
The answer to these questions would help in guiding my (and others)
responses... [noparse]:)[/noparse]
That being said, it would be possible to use two SPST switches to produce
the output of three SPST switches using binary as such:
S1 S2 S1 S2 S3
0 0 = 0 0 0
1 0 = 1 0 0
0 1 = 0 1 0
1 1 = 0 0 1
Again, I have to work with assumptions that may not be correct in your
circumstances (i.e. there are no "combo" positions of the three switches
where more than one is closed at a time)
Vern
Vern Graner CNE/CNA/SSE | "If the network is down, then you're
Senior Systems Engineer | obviously incompetent so why are we
Texas Information Services | paying you? Of course, if the network
http://www.txis.com | is up, then we obviously don't need
Austin Office 512 328-8947 | you, so why are we paying you?" VLG
Francesco Fumanti said:
> Hello,
> ________
> --Switch1-->
> | |--switchA->---
> | BS2 |--switchB->---
> | |--switchC->---
> --Switch2-->
> |________|
> output switches?
> for the relay).
> each socket.
> Relay? What IC?
> Francesco Fumanti
> Body of the message will be ignored.
There are examples of coding the click, double click, and long click
in chapter two of stampsinClass, Earth Measurements:
http://www.emesystems.com/EarthM/em2.pdf
The question of the output switches will depend a lot on how much
isolation is required. That is, do all the swithes share the same
power supply and the same ground, and can that ground be connected to
the Stamp ground (Vss)? If so, a simple transistor or IC may well
work as a SPST switch. However, if the circuits must be isolated
from one another and from the Stamp, then you will need an
optocoupler or an electromagnetic or solid state relay. 4.9 volts at
100 ma is not much power, so there will be a solution either way.
-- Tracy Allen
>Hello,
> ________
> --Switch1-->
> | |--switchA->---
> | BS2 |--switchB->---
> | |--switchC->---
> --Switch2-->
> |________|
>output switches?
>for the relay).
>each socket.
>Relay? What IC?
>Francesco Fumanti
resistor values, wiring, pcboard, etc. to control things with a stamp
module.
jim
http://www.geocities.com/jimforkin2003/
From: Francesco Fumanti [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=80cKYA_h18IlDVc6RTi0MgmvdK6GlUpGFQEUD2ihXGyzn8VJIrK4GLtozuOu3zkrSqcgzBswheZddOH2b65hGQ]francesco.fumanti@g...[/url
Sent: Monday, September 15, 2003 3:58 PM
Subject: [noparse][[/noparse]basicstamps] newbie - replace 3 switches - 5 Volt; 0,1 mA
Hello,
________
--Switch1-->
| |--switchA->---
| BS2 |--switchB->---
| |--switchC->---
--Switch2-->
|________|
output switches?
for the relay).
each socket.
Relay? What IC?
Francesco Fumanti
The two circuits must indeed be isolated from one another.
Thanks for your suggestions. I will look into it.
Have a nice day.
Francesco
--- In basicstamps@yahoogroups.com, Tracy Allen <tracy@e...> wrote:
> Hi Francesco
> -- Tracy Allen
> >Hello,
> > ________
> > --Switch1-->
> > | |--switchA->---
> > | BS2 |--switchB->---
> > | |--switchC->---
> > --Switch2-->
> > |________|
> >output switches?
> >for the relay).
> >each socket.
> >Relay? What IC?
> >Francesco Fumanti
