highbyte, lowbyte
Hi All,
As ususal, I am missing a simple fundemental truth. I though that:
bla VAR word
bla = 6500
debug DEC bla.highbyte, DEC bla.lowbyte
would display "6500", however, I get "10025". Do I have to use the DIG
command to do what I want here?
Sorry for the simple question.
Jonathan
www.madlabs.info
bla VAR word
bla = 6500
Jonathan
www.madlabs.info
The problem is that 6500 is not 65*256+0, but rather 1964 hex which is
$19*256+$64 (or 25 and 100). The lowbyte stores the 25 part, which seems
odd but is not unusual.
Why not just say DEBUG dec bla
This will do what you want automatically. There is no easy way to look
at two bytes independently and figure the decimal digits. You have to
look at it as a whole (as opposed to hex, octal, or binary digits).
If you really wanted to pick apart digits, DIG will do it, but only if
you look at the entire 16-bit word.
Al Williams
AWC
* New servo control kit and more: http://www.al-williams.com/kits.htm
> From: Jonathan Peakall [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=5YpsmYMNMRXpOvG3x8jE7dgUudSm1a6x6PopkQ4uA_yO5BDl7jXv6klBHKz8KXTMz_tC0CeYfiskG6hd]jpeakall@m...[/url
> Sent: Monday, September 15, 2003 9:28 AM
> Subject: [noparse][[/noparse]basicstamps] highbyte, lowbyte
> Hi All,
> bla VAR word
> bla = 6500
> use the DIG command to do what I want here?
> Jonathan
> www.madlabs.info
> from the same email address that you subscribed. Text in the
I want to send a word size VAR using serout commands to a PIC co-proccesor
in a project I am working on. Using the Stamp, the user selects a value for
the PIC co-processor to use in it's program. What is the easiest way to do
this?
Jonathan
www.madlabs.info
Sent: Monday, September 15, 2003 7:39 AM
Subject: RE: [noparse][[/noparse]basicstamps] highbyte, lowbyte
> Hi Jonathan,
> Al Williams
> AWC
> > From: Jonathan Peakall [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=CC3XzLp1SsuDXgXbkOHoWoO4jZwj7dCEoFsatRqb9E-rwSsBWzsTXU10LXHx4UCfyEBgUkzXOvEh4LICKkQ]jpeakall@m...[/url
> > Hi All,
> > bla VAR word
> > bla = 6500
> > Jonathan
> > www.madlabs.info
You can send the two bytes to the PIC most efficiently and simply...
debug bla.highbyte,bla.lowbyte
and program the PIC to receive those two bytes in order to
reconstruct the word value.
Alternatively, the Stamp could send 4 hex bytes
debug hex4 bla
and the PIC would have to be programmed to receive 4 bytes and to
reconstruct the original word out of the low nibble of each. Simple
job for the PIC.
Finally, the Stamp could send decimal:
debug dec5 bla
and the PIC would have to receive 5 decimal digits, subtract 48 from
each one (so that ascii "0" to "9" become binary 0 to 9) and multiply
each digit times its appropriate power of 10 (10000, 1000, 100, 10,
1) and add them up to reconstruct the original. A lot more work for
the PIC!!
--- Tracy
http:/www.emesystems.com
>bla VAR word
>bla = 6500
>>this?
>>Jonathan
>>www.madlabs.info
>>From: "Al Williams" <alw@a...>
>> > Hi Jonathan,
so that's the magic value for an 8 bit byte.
Start with 6500 and divide by 256 = 25.factional so 25 is the value of the
high byte 8 bits
Subtract 6500 - (25 * 256) = 100 which leaves 100 so 100 is the value of the
low byte 8 bits.
You can get the same result if you divide by sucessive powers of two,
starting with 2^12 = 4096 and mapping the decimal number directly into the
binary digits and then splitting the first 8 bits and the last 8 bits..
http://www.usbyte.com/common/Binary%20number%20conversion.htm provides a
nice calculator, as does the DEBUG command
Sent: Monday, September 15, 2003 7:27 AM
> Hi All,
> bla VAR word
> bla = 6500
> Jonathan
> www.madlabs.info
Thanks!
Jonathan
www.madlabs.info
Sent: Monday, September 15, 2003 6:30 PM
Subject: Re: [noparse][[/noparse]basicstamps] highbyte, lowbyte
> You're chopping a 16 bit value into two separate 8 bit values. 2 ^ 8 = 256
the
> high byte 8 bits
the
> low byte 8 bits.
the
> From: "Jonathan Peakall" <jpeakall@m...>
> > Hi All,
> > bla VAR word
> > bla = 6500
> > Jonathan
> > www.madlabs.info
and
