memsic sensor and rotation
Hello,
I'm trying to use the Memsic accelerometer to measure rotation, so I can
know the direction my robot is facing on a flat surface. The basic stamp
test programs that come with parallax version of the sensor work very well
for x and y tilt, but using the rotation test program doesn't yield any
change when I turn the circuit around. That's not entirely true, values
change as I turn it head over heals (pitch), or side over heals (roll), but
not as I turn it in a circle on a flat surface (yaw), which is what I want.
The sensor is perpendicular to the plane as the instructions require. Still,
no results. Does anyone have any advice on this matter? Perhaps I
misunderstood which type of rotation the sensor measures. Please note I am
using BS2sx, and have adjusted all the values in the test programs
accordingly...of course there's always the chance that I overlooked one.
Nick
Nick
The Memsic 2125 measures change in gravity. When mounted flat
(parallel to earth) it senses pitch and roll, but only up to plus or
minus 60 degrees. Their rotation example shows how to overcome this
limit by mounting the sensor perpendicular to the earth and using the
two axis' outputs to achieve a full 360 value in either pitch or
roll. By turning your circuit around its y axis you never change
either plane with respect to the earth. It sounds like you need
something more like a digital compass perhaps? I don't know any
references for these offhand but I'm sure other folks here could help.
Trent
--- In basicstamps@yahoogroups.com, nick stedman <nickstedman@s...>
wrote:
> Hello,
I can
stamp
very well
any
values
(roll), but
I want.
require. Still,
note I am
one.
> Thanks,
> Nick
and down, to those not on Earth). So if your Memsic is horizontal, it
will measure inertial acceleration, but not tilt or rotation. I hope
that helps.
On Sunday, September 14, 2003, at 03:56 PM, nick stedman wrote:
> Hello,
> can
> stamp
> well
> (roll), but
> want.
> Still,
> I am
> one.
> Thanks,
> Nick
> from the same email address that you subscribed. Text in the Subject
> and Body of the message will be ignored.
