Making rollers for paper
Archiver
I'm building a paper cutter that will feed paper from rolls up to 5
feet wide. I need to make motorized rollers that can feed the paper
in very precise measurements.
I was thinking of making the rollers from 1 plastic pipe that would
turn around a copepr pipe, and make the motorized roller from a
threaded rod with rubber washers or something like that on it.
Do you think this would work well? Does anyone have any idea how to
make better rollers?
bearings, shafts, couplers, and other necessary hardware.
Dennis
From: ch2surf [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Q445Y-BJp5lKfEmGBmXEo1apGmdyifG4OKOSLIzrJynsnOm7rF49-GBLWcbN7-moIlBq4lSy8DR4NSxrFiOYPE4]sachacrompton@v...[/url
Sent: Saturday, September 13, 2003 12:30 PM
Subject: [noparse][[/noparse]basicstamps] Making rollers for paper
Your use of Yahoo! Groups is subject to
> Thanks
5 ft long rollers will bend like rubberbands. typically they are
either solid or large diameter and hollow. a larger rubber coating
is applied often and then cut to be round.
It sounds like a pretty hefty project and some research is in order.
If you can support the rollers at different points across, then you
can use lighter weight materials.
Paper is abrasive and dusty so considder future replacement options
when putting it together.
as far as controlling the paper, what speed are you trying to
achieve ?
can you stop the paper to cut it ?
cutting it on the fly will be even more demanding but the machines
that do that stuff are neat to watch.
Dave
locate some parts from a scrapped printing press.
On Sunday, September 14, 2003, at 02:08 AM, Dave Mucha wrote:
> --- In basicstamps@yahoogroups.com, "ch2surf" <sachacrompton@v...>
>> Thanks
> achieve ?
> Dave
