PulsIn - Bs2 — Parallax Forums
PulsIn - Bs2
edited 2003-09-18 14:09 in General Discussion
I'm starting to get a little confused on how this all works.
I'm experimenting with a BS2 reading pulses then calculating the duty
cycle by using the example in the Stamp book. For a signal
generator, I'm using a Pic 16F84 to output a pwm signal at a 50% duty
cycle.
The BS2 is reading this PWM Input but the duty cycle is varying all
over the place.
BS2 Code:
Time1 var word
Time2 var word
input 7
output 0
Duty:
pulsin 7,1,time1
if time1 > 6553 then error
pulsin 7,0,time2
time2 = time1 + time2
time2 = time2/10
time1 = time1 * 10
time2 = time1/time2
If time1 = 0 then zero
debug Dec time1," percent",1,1
pause 1000
goto duty
error: debug" out of range",1,1
pause 1000
goto duty
zero: debug"No Pulse",1,1
pause 1000
goto duty
Here is the Pic Code for the PWM Signal:
doit:
pwm 6,127,100
goto doit
Sorry, I'm real rusty since I haven't played with either one for
several years and basically have to relearn most of it. Any help
would be greatly appreciated.
    edited 2003-09-13 17:04
    In a message dated 9/13/2003 5:15:07 AM Pacific Daylight Time,
    skinner02001@y... writes:
    cycle.
    over the place.
    BS2 Code:
    Time1 var word
    Time2 var word
    input 7
    output 0
    Duty:
    pulsin 7,1,time1
    pulsin 7,0,time2
    time2 = time2/10
    time1 = time1 * 10
    time2 = time1/time2
    pause 1000
    goto duty
    pause 1000
    goto duty
    pause 1000
    goto duty
    ____________________________________________________________
    Your BS2 algorithm looks like it works. If I correctly remember, the
    frequency of the duty is 500 hz, and the resolution of the pulsin command is 2
    uS.
    Assuming the above is correct, the results work on paper.
    However, what may be happening is the BS2 is not a "super fast" device and it
    is possible that when your PIC output goes from low to high, the stamp takes
    too much time (possibly up to 240 uS, almost 1/4 the length of your pulse) to
    stop reading the low pulse and start reading the high pulse. And the same
    thing might be occuring with a different length of delay when the transition
    goes
    from high to low. However, if the delay is the same for high to low, and low
    to high, then the delay should not matter. See this link for execution times.
    BS2 interpreter execution timings
    Another thougt is that the stamp and PIC do not share a common ground. If
    not, connect the stamp ground and the PIC ground together at some point.
    Have you viewed the PIC output on an O-scope? Is the PIC output a stable 50%
    duty?
    Ken
    edited 2003-09-13 20:33
    I think you have go back to the source itself which is the signal you
    input into BS2. If the level is not high enough or fluctuate, the duty
    cycle would fluctuate too. Make sure the peak is TTL level. A Schmitt
    trigger like 7414 is a must for analogue signals. If you can confirm
    the signal level then you can look into the code. The simplest
    measuring instrument would be a resistor and an LED. If you signal can
    drive the LED brightly then it's fit enough for your BS2.
    - Cheers
    --- In basicstamps@yahoogroups.com, "skinner02001" <skinner02001@y...>
    > cycle.
    > over the place.
    > BS2 Code:
    > Time1 var word
    > Time2 var word
    > input 7
    > output 0
    > Duty:
    > pulsin 7,1,time1
    > pulsin 7,0,time2
    > time2 = time2/10
    > time1 = time1 * 10
    > time2 = time1/time2
    > pause 1000
    > goto duty
    > pause 1000
    > goto duty
    > pause 1000
    > goto duty
    > doit:
    > pwm 6,127,100
    > goto doit
    edited 2003-09-15 11:15
    Great, I got it working by reading a Pulse from a 555 and it seems to
    be pretty accurate. Now for the electronics portion. What is the
    best way to tap into engine control system without being messing up
    the signal? I have a 500hz frequency with a variable duty cycle with
    an amplitude of 12 volts that I need to get down to a TTL level.
    Would simply using a Schmidt trigger be able to take a 12volt and
    convert it to a TTL signal? Will a voltage divider mess up the
    signal to the other computer even if I keep my resistor values high?
    I'm looking for the most reliable method. I thought about using a
    555 but I'm not sure what the effect would be with the main supply @
    5vdc and the trigger signal being @ 12. Sorry, don't know much about
    electronics.
    edited 2003-09-15 14:25
    In a message dated 9/15/2003 3:16:49 AM Pacific Daylight Time,
    electronics.
    _____________________________________________________________
    Since 500 hz is relativlely slow, you can feed that signal into an NPN
    transistor, like a 2n3904.
    Connections
    your 12 volt signal into 10k ohms, other end of 10k into base of a 2n3904
    68 k from 2n3904 base to ground
    2n3904 emitter to ground
    2n3904 collector to one end of 10K ohms, other end to +5 volts.
    your 5 volt signal into stamp taken from the collector of the 2n3904.
    When your duty signal is high, the stamp recieves a low and visa versa, easy
    to deal with in your software code.
    There are several other methods to do the same, opto-isolator, op-amp
    comparitor. You being "new" to electronics, the NPN transistor is probably the
    easiest at this point.
    email me off list if you want/need more detail or options for another method
    (I recently just built a duty cycle meter, but with a different uController).
    Ken
    edited 2003-09-16 12:16
    Thanks for the recommendation on the transistor. I know this topic
    can get beat to death however Now,Since I've learned how to do this
    with a stamp, and also learned how send PWM out of a stamp on convert
    it to a voltage which leads me to my next question....
    Could this be accomplished without a stamp by using an RC Network and
    simply measuring the voltage? If so, how in the heck figure out
    which values I would need for the cap and resistor when hooked to the
    500Hz signal?
    to
    with
    high?
    about
    > electronics.
    NPN
    > Connections
    2n3904
    2n3904.
    versa, easy
    amp
    probably the
    another method
    uController).
    > Ken
    edited 2003-09-16 13:50
    In a message dated 9/16/2003 4:17:30 AM Pacific Daylight Time,
    500Hz signal?
    Question #1...ARE YOUR INITIALS S.R. and do you work for a Korean Car company
    in Ann Arbor Michigan?
    Q#2....What is your end goal, do you want to measure duty cycle and output an
    analog voltage that corresponds to the duty cycle?
    Of you want to convert some digital information to analog (DAC) using an RC
    network, the only way I know how is to feed the RC with PWM. PWM can be
    generated without the stamp.
    Is that what you are trying to accomplish?
    edited 2003-09-16 17:35
    I couldn't answer each one of your question unless I can see the whole
    schematics. But there are a number of key factors that I could answer.
    1. If you are trying to tap a signal from an engine, it is difficult
    to get a fundametal frequency because there are many harmonics
    overlapping it. The question is which frequency are you tapping
    because harmonics can be close to the fundamental sometime especially
    in engines. The best way to tap a signal from engines is physically
    using optical devices just like tachomemters. I believe you can have a
    lot of infos on the net regarding this.
    2. To convert a 12V signal to a TTL level you can use a Voltage Level
    Shifter like 40109. It works both ways, 12V to TTL or TTL to 12V. Read
    the specs on 40109. You also could use a simple Zener Diode of 5.1V to
    clamp the signal down. This is a brute force way and you got to check
    how the signal looks like on scope for spikes. Usually you can filter
    it out with capacitor.
    But if you don't have much experience in electronics, you have to ask
    someone experience enough to do it for you. Then you just can focus on
    your programming.
    > electronics.
    edited 2003-09-17 00:06
    No, My name is Richard Skinner and I don't work for a car company.
    My Project:
    I have a 32 channel datalogger that has a 10 volt max input allowed.
    I have about 12 sensors hooked to it that output 4-20ma, varoius
    voltages, and a few that read resistance and a magnetic pickup that
    reads frequency, coverted to 1-10 volts. I built all the simple
    interfaces and they work great. Now, I'm face with creating an
    interface to to tap into about 6 channels of PWM (15 volt amplitude,
    500 hz), read the duty cycle, convert it to a voltage porpotional to
    the duty cycle 0-10 vdc equating to 0-100% duty cycle. I only read
    these channel anywhere from 5 times per second to only once per
    second.
    I figured this was a perfect place for a stamp. I have played with
    the stamp and pic's allot back several years ago and did some neat
    stuff, however I always messed with TTL level stuff so I didn't have
    to do much converting. This interface will be in a waterproof
    container, however they will be next to an engine (10 feet) so it may
    be prone to some RF.
    The reason I'm asking these questions is to save a few headaches. If
    this was anothe hobby experiment it wouldn't be too bad, however I
    have an engine to log next week so I'm kind of in a rush. I brought
    home one of the sensors today and put it on a scope. The specs call
    for 500hz but it's actually around 400hz. It puts out a real nice
    square wave from 0volts to 15 volts.
    That is what my project consist of.
    Richard
    convert
    and
    the
    > 500Hz signal?
    Car company
    output an
    using an RC
    can be
    edited 2003-09-17 00:57
    Great, I appreciate the info. I'm looking at a MC14050B Non
    Inverting Hex buffer which has 6 CMOS to TTL drivers, allows VIn to
    exceed Vdd which means I can power the chip off 5vdc, and it's okay
    to have 15 vdc going into the driver. Am I on the right track? I'm
    going to look at the 40109 as well but for some reason I can't find
    it in my Motorola books.
    Richard
    --- In basicstamps@yahoogroups.com, "Johari Aziz" <johaziz@y...>
    whole
    answer.
    especially
    have a
    Level
    Read
    to
    check
    filter
    ask
    on
    > your programming.
    <skinner02001@y...>
    seems to
    the
    up
    with
    high?
    a
    supply @
    about
    > > electronics.
    edited 2003-09-17 01:16
    You may want to consider a MAX5101 DAC.
    It has rail to rail output. It has 3 outputs selected by two lines.
    If you run it on 5 volts, you can then easily amplify by two for a 0 to 10v
    output, 5 volts = 50% duty, 7.5 volts 75% etc.
    Or if you run it on 10 volts you have 0 to 10 volt output. A cheap and dirty
    DAC can be made with a thing called and R2R resistor network. It is I/O pin
    hungry though (8 pins), but you can use a shift register and get away with only
    3 pins.
    Ken
    edited 2003-09-17 08:54
    The datasheet I have of CD40109B is from Texas Instruments. Even
    though it is known as a Quad Low-to-High Voltage Level Shifter it also
    works as High-to-Low if Vcc>Vdd. Vcc and Vdd could be of any voltage
    level between 3 to 18V. Yes 4050 also works well for your application.
    Generally it is a logic level conversion from CMOS to DTL/TTL.
    - Cheers,
    - Johari
    > Richard
    > whole
    > answer.
    > especially
    > have a
    > Level
    > Read
    > to
    > check
    > filter
    > ask
    > on
    > > your programming.
    > <skinner02001@y...>
    > seems to
    > the
    > up
    > with
    > high?
    > a
    > supply @
    > about
    > > > electronics.
    edited 2003-09-18 01:55
    NPN
    > Connections
    2n3904
    2n3904.
    versa, easy
    Ken, I built the circuit like you stated but it did not work, however
    I remove the 68K resistor that ties base to groun and It works, I get
    an inverted 5 volt signal like you stated.
    Maybe I messed up reading your instructions as I did this:
    Emitter to ground
    Base to 10k to Signal In
    Base to 68k to ground
    Collector to 10K to 5vdc
    Collector to scope / stamp
    It did not work, but again, if I remove the Base to 68K to ground it
    works.
    Richard
    edited 2003-09-18 05:28
    In a message dated 9/17/2003 5:58:11 PM Pacific Daylight Time,
    rwskinner@w... writes:
    Emitter to ground
    works.
    hmmmmmmmmm,,,
    From what you wrote in the email above, it appears you have it correctly
    configured. But to be redundant let me word one portion slightly different.
    68k directly from the base lead to the emitter lead (which of course is same
    as you stated).
    | |emitter
    68k \ gnd
    gnd
    Anyway, the purpose of the 68k resistor to ground is to improve (speed up)
    the turn off time of the transistor when the input goes low. The 68k resistor
    is an additional path to ground to discharge base emitter junction capacitance,
    as this junction capacitance is charged when the transistor is on (input is
    high).
    500 hz is not considered "high frequency" by any means, so if the circuit
    operates fine without the 68k, go for it without the resistor. And since you
    have
    an o-scope and viewed a "good" waveform, run without the 68k.
    Looking back at some "older" circuits, I have used the configuration many
    times without the 68k ohms, and did not have trouble with those circuits. So I
    guess you can run without the 68k. Again, the main purpose of the 68k is to
    improve the turnoff time of the transistor, and that is not all that important
    at
    500 hz. I generally use a "base discharge resistor" out of habit.
    Ken
    edited 2003-09-18 10:57
    Ken, Thanks for your help. It's very much appreciated.
    The signal must not be able to supply much current at all because I noticed
    that the input signals amplitude, measured before the transistor, dropped
    from 15 volts to 9volts when it was hooked to the 10K resistor. I tried to
    read up some on the transistor and "if" I understand it correctly, the 10K
    resistor between the stamp pin and base is simply there to limit the current
    going to the stamp, and the base when the transistor is off and sinking to
    the emitter, right?
    If I assumed correctly, does that mean if I increase the size of the 10K
    resistor, then it will reduced the draw down on the input signal? will that
    affect the operation of the transistor any ? For grins, I tried a 33k there
    and the input signal only dropped from 15volts down to 13 volts.
    Richard
    Sent: Wednesday, September 17, 2003 11:28 PM
    Subject: Re: [noparse][[/noparse]basicstamps] Re: PulsIn - Bs2
    > Emitter to ground
    > works.
    > hmmmmmmmmm,,,
    different.
    same
    > as you stated).
    > | |emitter
    > 68k \ gnd
    > gnd
    resistor
    capacitance,
    is
    > high).
    you have
    So I
    to
    important at
    > Ken
    In a message dated 9/18/2003 3:04:07 AM Pacific Daylight Time,
    the emitter, right?
    Richard
    _________________________________________________________________
    Richard,
    Your transistor explanation is good....and I would agree with your assesment
    that the supply circuit does not have much current capability.
    What were you using to supply the 15 volts? The original configuration should
    not cause the voltage of Vin to drop, unless VIN is really "weak" with
    regards to current output, as you mentioned.
    Or, your collector resistor is not 10k, a much smaller value..
    Transistors 101
    In this config, you are using the transistor as a switch.
    The transistor has a parameter called Beta, for a 2n3904, Beta is usually
    well over 100, but let's assume a value of 100 (A WORST CASE SCENARIO).
    The maximum current through the transistor collector will be equal to the
    voltage applied to the collector resistor (5v in your case) divided by the
    collector resistance (10k in your case)
    5v/10k = 0.0005 amps, 0.5 mA.
    To determine what value base resistor is needed, you need to know how much
    base current is needed for the transistor to "suck" .5mA through the collector
    resistor.
    This is done by dividing the collector current (0.5 mA) by Beta (100)....
    0.5mA / 100 = 5 uA.
    To "push" 5 uA through the base emitter junction you need to select and
    approprite base resistor, and know how much voltage will be put into the base
    resistor (15 volts in your case).
    To select the base resistor, use ohms law......15v/5uA = 3 Meg ohms.
    So in theory, for a 2n3904 to suck .5 mA through the 10k collector resistor
    with 5 volts on it, the base resistor could be 3 meg, with 15 volts applied.
    However, since switching speed is not an issue in this case, "we" will many
    times go overkill on base current, hence the original 10k ohm value.
    I suspect that the circuit you are currently using to test this circuit does
    not have much capacity to supply current, and that is why the voltage drops so
    low (9v) with our original config.
    You could use 100k base and 10k collector resistors, and still have it work.
    When the base resistor becomes too large, the effect will be the collector
    voltage will not go as low when the transistor is on. In reality, you will only
    be able to make the collector voltage go as low as about .6 volts, which is
    good enough.
    There are several other factors to consider to bias your transistor, but this
    is a quick and dirty "transistors 101" and gives enough information to use it
    as a switch.
    I will be out of town the next two days and will not have acess to email [noparse]:([/noparse]
    the emitter, right?
    CHANGES
    going out OUT OF the stamp, and the base when the transistor is ON and
    sinking COLLECTOR CURRENT to
    the emitter, right?
    right!!!
    Ken
    PS, it is very early in the morning here (CA) and I am late leaving for work
    (no biggie) and in my rush I might have made some typo or calculation mistakes
