pulsin with BS2
My project is to eventially read a PWM signal from sensors on an
engine and determine the duty cycle, then convert to a 0-10 volt
signal. The sensor out puts a 500 hz frequency.
For starters, I'm trying to test pulsin with my Scopes test pattern (
0.5 vpp @ 100hz 50% Duty Cyle).
The BS2 never sees the pulses. I'm using the Duty Cycle test program
from the Stamp Book. Is the voltage too low on the pulse?
Thanks for any help.
TTL/CMOS the positve-going threshold is typical 2.0v. You need to
amplified it using transistors.
- Johari
--- In basicstamps@yahoogroups.com, "skinner02001" <skinner02001@y...>
