current sensor circuit
Archiver
I need a circuit that senses current of .2A and sends out a voltage when the
current is sensed.
Do you Yahoo!?
Yahoo! SiteBuilder - Free, easy-to-use web site design software
current is sensed.
Do you Yahoo!?
Or, do you want to measure a range from 0 to 200 mA and then change
that to a 0 to 4.096 voltage so that it can be read with a A/D
converter?
Your best to use a current sense resistor and add a op amp in there
for gain.
LEM makes current sense modules and are available from Digikey. They
are kinda pricey at $25 each, but it is an off the shelf solution.
Maxim makes a few current sense monitor IC's.
MAX472 should work nicely and comes in a plastic 8 pin dip, and you
can request free samples. It is programmable via external resistors.
http://pdfserv.maxim-ic.com/en/ds/MAX471-MAX472.pdf
Jason
--- In basicstamps@yahoogroups.com, Steve Platovskiy <plato012@y...>
when the current is sensed.
> Do you Yahoo!?
as low as possible to reduce losses. the comparitor can be set for
any current you want.
an op-amp instead of a comparator and you can feed an RC network for
RCtime for a sloppy and low quality analog value.
should offer 1/4-1/2-3/4 or full values.
Dave
> Do you Yahoo!?
as 0.2 Amp a.k.a. 200 milliamps? There are some simple current transformers
you can wind yourself if it's A.C., but they won't work for D.C.
Otherwise, Dave's recommendation of a resistor and comparator or op-amp
works fine for D.C. circuits. But with large currents you can lose a lot of
power to heat conversion. It's that old law of Voltage x Current = Wattage.
Hmmmmmmm.... I'm having a brainstorm that you might use a Kelvin 4-wire
bridge sort of in reverse (with a known fixed resistance) to provide a more
accurate voltage output using a very low resistance value, perhaps even the
resistance of the feed wire itself.
I'll muse on this a bit. Any thoughts???
Mike Sokol
www.modernrecording.com
mikes@m...
301-739-6842 voice/fax
301-964-5682 mobile
Sent: Wednesday, September 10, 2003 11:02 PM
Subject: [noparse][[/noparse]basicstamps] Re: current sensor circuit
> considder a comparitor with a resitor on the load. make the resistor
> Dave
> > Do you Yahoo!?
