Ocean Bouy Reply
Archiver
There was another of these several years ago, except that it dove
periodically as it crossed the ocean to take measurements at depth. It used
a small bladder for changing bouancy. It was solar powered. Last I read it
was supposed to replace sending ships to make the same measurements, which
were necessary weather, etc. It had little wings.
From: Jim Forkin [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=jxhp_eEahbYbzm3KBn8I0Iudr6jyolygWsdcfHcA-v2lcoTJqcSmT_cm6pyPZ8NQg7xQfPYMfw8E]jjf@p...[/url
Sent: Monday, September 08, 2003 12:41 PM
Subject: RE: [noparse][[/noparse]basicstamps] Looking for a project
a pc board that can handle the inputs and outputs is available. check out
http://www.geocities.com/jimforkin2003/
From: andy shor [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ZAAaveLlIuTUULfeVVPoosmhiVMVDNPCDviZsghTrUMq3QLS8PNuULypX6ri-elQGFkBAUiAq0cF0TPa]ashor2000@y...[/url
Sent: Friday, September 05, 2003 8:59 PM
Subject: Re: [noparse][[/noparse]basicstamps] Looking for a project
Good Day:
I am building a series of drifting bouys placed in the Gulf Stream and
tracked via satellite. The first just provides position information. However
the future units should provide voltage, water temp and salinity info.
If interested, I could use a hand on a stamp based data acquisition unit for
the bouy.....
NIMA <nimjah@y...> wrote:
Dear Friends
We are a group of 5 engineering students looking for a neat project
ideas. Prefebably biomedical project becasue it is out instructor
interest. I was wondering if any of you guys have a nice new idea
that might want to share with us.
Thank you
Do you Yahoo!?
Yahoo! SiteBuilder - Free, easy-to-use web site design software
Good Day:
the bouy.....
Dear Friends
Thank you
Do you Yahoo!?
built in, called ratfor or something similar. It used a large pyrex
test tube as the body
Bill Higdon
It used
read it
which
> From: Jim Forkin [noparse][[/noparse]mailto:jjf@p...]
check out
> From: andy shor [noparse][[/noparse]mailto:ashor2000@y...]
> Good Day:
However
unit for
> the bouy.....
> Dear Friends
> Thank you
it was a pre-compiler invented by Kernighan
and Plauger.
There was Forth Interest Group Forth (Fig-Forth).
--- In basicstamps@yahoogroups.com, "willard5612000" <w.higdon@c...>
wrote:
> First one I heard of was back in the 80's. It used a Micro with
Forth
> Bill Higdon
depth.
> It used
Last I
> read it
measurements,
> which
> check out
> > Good Day:
Stream and
information.
> However
info.
acquisition
> unit for
> > the bouy.....
> > Dear Friends
project
> > Thank you
provide forward motion as it dives. One I read about years ago sent gps
location and temp/salinity/depth data to satellites. They are starting to
use swarms of them now and giving them a lot more smarts.
Other AUVs, known as gliders, travel forward using lift generated as they
rise and fall through the water column. Internal computers change a glider’s
buoyancy by pumping mineral oil into or out of an external bladder. When the
bladder is full, the glider displaces a greater volume than when the bladder
is empty. When oil is pumped out of the bladder, the glider’s effective
volume decreases while its mass stays the same, until it becomes dense
enough to sink. When the glider reaches a predetermined depth, the oil is
pumped into the bladder and the glider rises toward the surface again. Short
wings allow a glider to travel horizontally as it rises and falls. Since
they have no motors, gliders use very little power, and can stay at sea for
weeks or even months at a time. However, they travel relatively slowly (less
then 1 knot) and can only carry one or two instruments at a time. During the
AOSN 2003 field experiment, up to 15 different gliders may be criss-crossing
Monterey Bay at any one time.
Link to free swimming ocean glider for temp/salinity...
http://www.mbari.org/MUSE/platforms/gliders.htm
Bill
From: Bill Katakis [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=DvaiUvNEBC6UEmTex4u_ZUzc6ZUhX-AUJ9o0KLU0EBTpCXW7Sw0LokwYeAAoC2VVH7jXYWR-ygY8sfY]bkatakis@a...[/url
Sent: Monday, September 08, 2003 2:51 PM
Subject: RE: [noparse][[/noparse]basicstamps] Ocean Bouy Reply
From: Jim Forkin [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=SQJXekS9j5MAQoErKvSGBCeirzp44wdMSkj9yjd8gZYT2KzTv6Tn-opsWPbYAkOj6VIUFpQORt7NUQ]jjf@p...[/url
From: andy shor [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=yDOGx0k4ZBAAl4LiR-JXRXTvsz7wfY-ecIzcW5N6h7F5sh0tSmTMQ6IruGqf3b658ZDyYmA5cqCa]ashor2000@y...[/url
Good Day:
the bouy.....
Dear Friends
Thank you
Do you Yahoo!?
some details at http://www.taygeta.com/rafos.html
Bill Higdon
--- In basicstamps@yahoogroups.com, "Allan Lane" <allan.lane@h...> wrote:
> Umm, RatFor stands for Rational Fortran --
> and Plauger.
> Forth
> > Bill Higdon
> depth.
> > It used
> Last I
> > read it
> measurements,
> > which
> > check out
> > > Good Day:
> Stream and
> information.
> > However
> info.
> acquisition
> > unit for
> > > the bouy.....
> > > Dear Friends
> project
> > > Thank you
Thanks for the link, it is fascinating. BTW,
from one of the web pages it looks like that
glass tube is around 6 feet long.
It's not clear what parts are written in C++,
while other parts are written in Forth. Still,
fascinating project.
wrote:
> Give me a break, it was long ago. It's actually Rafos, you can see
> Bill Higdon
> > and Plauger.
<w.higdon@c...>
> > Forth
pyrex
> > > Bill Higdon
<bkatakis@a...>
dove
> > depth.
> > > It used
> > Last I
> > > read it
> > measurements,
> > > which
available.
> > > check out
> > > > Good Day:
> > Stream and
> > information.
> > > However
salinity
> > info.
> > acquisition
> > > unit for
> > > > the bouy.....
> > > > Dear Friends
> > project
instructor
idea
> > > > Thank you
