Serial Data Formatting
Hey everyone,
I have built a VB application which sends some user inputted data to the
stamp, and then the stamp does accordingly with it. My problem is I
don't know how to format data i.e. I have 2 times hrs&min that need to
be inputted and 8 checkboxes each with a different numerical value. So I
was wondering if I could just send two messages, 8 bytes each (does it
have to be only 8?). I think it would look like this:
01259010
0: ID command
1259: 12:59
0: am (1=pm)
1: checkbox numbers
0:End ID
Is this right? I'm having the hardest time trying to work on this
project because my family is in the middle of a move and we are staying
in an apartment waiting for our house to be finished,(it will be the
29th) the worst part is that all my stamp stuff is in some storage
warehouse so I can't test out my vb code. It would be much appreciated
if you could help me out.
-Mike
01259010
0: ID command
1259: 12:59
0: am (1=pm)
1: checkbox numbers
0:End ID
-Mike
First decision: Are you sending Binary or 'Ascii'.
I recommend 'Ascii', since you can see it, and
testing will be easier.
So: Sending ascii: VB
Dim MyVBStr as STRING
Dim MyHours as Long
Dim MyMin as Long
DIM IsPM as Long ' 1 == Is PM, 0 == AM
Dim CheckBoxVal as BYTE
MyVBStr = "0" & FORMAT(MyHours,"00") & _
FORMAT(MyMin, "00") & FORMAT(IsPM, "0") & _
CHR(CheckBoxVal)
MSComm1.Output(MyVBStr)
' BS2 Side
I9600 CON $54 + $4000
MyVals VAR BYTE(8)
MyHour VAR BYTE
MyMin VAR BYTE
MyBits VAR BYTE
DIRL = %1111111 ' All outputs
MainLoop:
SERIN 16, I9600, [noparse][[/noparse]MyVals\8]
MyHour = MyVals(1) - "0" * 10 + (MyVals(2) - "0")
' Above converts 2 ascii bytes "12" into stored
' variable value 12. The '- "0"' part converts
' ascii "0" into value 0.
MyMin = MyVals(3) - "0" * 10 + (MyVals(2) - "0")
MyBits = MyVals(7) ' Since passed as 'CHR', is good
' for direct copy...
OUTL = MyBits
GOTO MAINLOOP
--- In basicstamps@yahoogroups.com, "Mike Dillon" <laxboy687@e...>
wrote:
> Hey everyone,
to the
to
So I
it
> 01259010
> 0: ID command
> 1259: 12:59
> 0: am (1=pm)
> 1: checkbox numbers
> 0:End ID
staying
appreciated
> Thanks
> -Mike
-Mike
From: Allan Lane [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=0fF5GbZkmLDtLND8RdNQg-p7cbqcwCrgib83Ow289n-FqvL3AWAUOkkVG81VSJn26RxtcjK-Xg4me80QpGS29w-wKsNdyA]allan.lane@h...[/url
Sent: Sunday, September 07, 2003 9:43 AM
Subject: [noparse][[/noparse]basicstamps] Re: Serial Data Formatting
Yes, this should work.
Dim MyHours as Long
Dim MyMin as Long
CHR(CheckBoxVal)
' BS2 Side
MyVals VAR BYTE(8)
MyHour VAR BYTE
MyMin VAR BYTE
MyBits VAR BYTE
MainLoop:
OUTL = MyBits
GOTO MAINLOOP
wrote:
> Hey everyone,
to the
to
So I
it
> 01259010
> 0: ID command
> 1259: 12:59
> 0: am (1=pm)
> 1: checkbox numbers
> 0:End ID
staying
appreciated
> Thanks
> -Mike
Your use of Yahoo! Groups is subject to
