maximum or minimum of an array
Is there a single PBASIC command that would find the maximum (or
minimum) of a set of values stored sequentially (either in the main
RAM, or preferably in the SPRAM or the EEPROM) of a BS2p?
If not,
would it be possible to add such a command to PBASIC vocabulary in
the future versions?
Mohammed
If not,
Mohammed
in fact the entire BASIC Stamp RAM can be treated like an array without
even declaring it explicitly. For example.
colors VAR Byte
red VAR Colors
green VAR Byte
blue VAR Byte
Since red is overlayed onto the same physical address as colors, and
green and blue are the same types, they will live in memory in this
order:
colors/red, green, blue
This means you can work with Red, Green, and Blue as named variables, or
index through them like this:
FOR idx = 0 TO 2
colors(idx) = idx
NEXT
After this loop, red will be zero, green will be one, and blue will be
two.
Another thing to keep in mind is that RAM arrays can be bits, nibs,
bytes, or words. SPRAM is accessed as bytes and words -- these issue
complicate creating an internal fuction (that you could certainly code
in PBASIC). This is not to say that the next-generation Stamp won't
have such a feature.
-- Jon Williams
-- Dallas Office
From: mohammedrasiq [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=gsSNIOVefYgTutgtEwDYI8PJk9B0XcRbMGRq6VfzXufNbeRswhKUsCYudTdonHK8eUtl0Po0byDLkdWM9CxLvSc]mohammedrasiq@y...[/url
Sent: Tuesday, September 02, 2003 5:17 PM
Subject: [noparse][[/noparse]basicstamps] maximum or minimum of an array
If not,
Mohammed
Your use of Yahoo! Groups is subject to
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
--- In basicstamps@yahoogroups.com, "Jon Williams" <jwilliams@p...>
wrote:
> No. The reason is that array boundaries are NOT enforced by the
Stamp;
without
> colors VAR Byte
> red VAR Colors
> green VAR Byte
> blue VAR Byte
> order:
variables, or
> FOR idx = 0 TO 2
> colors(idx) = idx
> NEXT
be
> two.
issue
code
> -- Jon Williams
> -- Dallas Office
> From: mohammedrasiq [noparse][[/noparse]mailto:mohammedrasiq@y...]
> If not,
> Thanks
> Mohammed
Subject
> abuse@p...
