DIRS question
I am looking over a program a co-worker wrote a while back trying to
understand they why and how he did what he did.
At the first of the program he declares the inputs and outputs correctly
with the DIRL and DIRH commands
DIRL=%00000000 'Pin 7-0 (low byte); Initial INPUT or OUTPUT
state
DIRH=%11111111 'Pin 15-8; 1=out, 0=in
OUTL=%00000000 'Pin 7-0, initial value; 1 = 5 volts
OUTH=%10010111 'Pin 15-0
but later he uses one of the pins to generate a pulse on pin 14 (Dith_Pin)
like the following:
PulsOut DITH_PIN,DITH_AMP 'Send Dither Pulse on output line
dir14=0 'Return output line to high impedance
Its the DIR14 I have never seen before and also why would he be calling it
'high' impedence. He has made the pin and input, correct? There is a 1k
series resistor from the pin to 5V, but couldnt this cause a problem?
Why wouldnt you just leave the pin an output and not change it? Also, is
the DIR'x' command a legal one? I couldnt find it in the documentation.
Mark
state
like the following:
Mark
What's going on is that Stamp pins have three states,
basically. These are OUTPUT HIGH, OUTPUT LOW, and
INPUT. HIGH means it's outputting a 5 volt signal.
LOW means it's 'forcing' a pin to ground -- basically
connecting the pin to a low-impedance path to ground
inside the chip. 'INPUT' means that the output drivers
are disconnected from the pin, so whatever chip is
outside the Stamp can put the pin in whatever state
it wants to.
This last state is also called 'high-impedance'.
Since the 'low-impedance' drivers to +5 and ground are
both disconnected in 'Input' mode, the 'outside'
chip's signal 'sees' a high-impedance (10 Megohms
or so). (This 'high-impedance' is the resistance
from the Stamp's receiver circuitry to ground,
inside the chip.) Thus the outside chip does not
have to drive very much current to get the
Stamp to 'see' its HIGH, nor sink very much
current to get the Stamp to 'see' its LOW.
When you do a 'PULSOUT', the Stamp sets the pin
as an OUTPUT, and does its thing with it. It
leaves the pin as an OUTPUT at the end of the
'PULSOUT'. This can lead to some drive currents
being active on the line -- so your co-worker did
an explicit DIR14 = 0 (ie, put pin 14 in INPUT mode)
to disconnect the OUTPUT drivers, and leave the
pin in high-impedance INPUT mode.
This is a very good thing to do at times. It
reduces 'idle' currents from the Stamp, and also
allows other devices to now drive the line.
correctly
OUTPUT
> state
(Dith_Pin)
> like the following:
calling it
is a 1k
problem?
Also, is
documentation.
> Thanks,
> Mark
