OT: Getting images from PDFs — Parallax Forums
edited 2003-09-03 01:16 in General Discussion
Hi All,
This is a little OT, but it is for a Stamp based project. I am in the
process of making documentation for students to use a device I have made. I
want to insert various images from component spec. sheets. What is the
legality of this, and how (if legal) can I get the images out of the PDFs? I
can do a screen capture, but it never looks as good as the original.
I would like, for example, to take the image from Parallax's documentation
of the 2p40 layout, and add information like what pins go to what devices.
Jonathan
www.madlabs.info
    edited 2003-08-30 20:19
    Check thier copyright notices first - some will put in a clause saying that
    copies can be made for teaching purposes and under what conditions this is
    allowed. Other than that, you'd have to contact the publisher of the PDF and
    ask.
    I think by default, if it says copyright anywhere, you aren't allowed to
    copy without permission.
    > From: Jonathan Peakall [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=jp565O_tKSHPdOuOitQx1rssGvOL_7l-WF1FiSjJ8avpRLckvgOhhEZTPOuyFiNQ27c5KI5PCAtwVsm1Bv4]jpeakall@m...[/url
    > Sent: August 30, 2003 10:46 AM
    > Subject: [noparse][[/noparse]basicstamps] OT: Getting images from PDFs
    > Hi All,
    > have made. I
    > the PDFs? I
    > Thanks,
    > Jonathan
    > www.madlabs.info
    > from the same email address that you subscribed. Text in the
    edited 2003-08-31 03:54
    To get an image 'out' of a pdf, such as a component
    pin out, you can use the graphic select tool, to
    select the diagram or picture, and print it or put it in
    the clip board, etc...
    This graphic select tool is available in the full version
    of adobe acrobat, it may not ne available in the reader version.
    --- In basicstamps@yahoogroups.com, "Jonathan Peakall"
    <jpeakall@m...> wrote:
    > Hi All,
    the
    have made. I
    the
    the PDFs? I
    original.
    documentation
    devices.
    > Thanks,
    > Jonathan
    > www.madlabs.info
    edited 2003-08-31 15:04
    I am as much of a copyright expert as everyone else in the
    basicstamps discussion group [noparse];)[/noparse]. There is a concept in copyright law
    called "fair use," which explicitly allows the use of copyrighted
    material for educational use, criticism, and so forth. It's a
    question of balance; you can't go cheating the copyright holder out
    of legitimate income, you can't prevent the expression of ideas for
    criticism, education, and related areas. Thus, fair use would not
    allow one to photocopy 100 copies of a reading workbook to use in
    your third-grade reading classes, but it would allow one to reproduce
    excerpts, for example, photographs or schematics, in the instructions
    that you create for your electronics classes. This is especially true
    if you are assigning a project, to use your example, that uses the
    BS2p40; your assigning that chip would benefit Parallax in two ways.
    First, your students using the 2p40s should result in at least some
    sales; secondly, if students learn how to use the 2p40, some are
    quite likely to specify that device for industrial or research use
    after they graduate.
    On a more practical note, why not just ASK Parallax for permission
    to use the diagram in your class notes?
    >ask.
    >> From: Jonathan Peakall [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=uaGtKlcsNlv8eDgiEuxlbNy8_-LDV3rZ59SjtRPDcP5zuBrNSr3WCjlzOIcSxiTwY2jfmsXGfugqcajp]jpeakall@m...[/url
    >> Hi All,
    >> have made. I
    >> the PDFs? I
    >> Thanks,
    >> Jonathan
    >> www.madlabs.info
    edited 2003-08-31 15:51
    >> What is the legality of this
    Don't know about the legalities. But would imagine you'll need
    permission.
    Open PDF with Acrobat 6.
    File, Save As
    Select HTML from drop down list.
    Let it do its thing (can take awhile depending upon how large PDF
    is). When finished, check the images directory that it created.
    Kenny
    edited 2003-08-31 16:17
    That and a few other nice tools are available in the newest reader version
    6.0?
    Larry Gaminde
    Sent: August 30, 2003 7:54 PM
    Subject: [noparse][[/noparse]basicstamps] Re: OT: Getting images from PDFs
    > > Hi All,
    > the
    > have made. I
    > the
    > the PDFs? I
    > original.
    > documentation
    > devices.
    > > Thanks,
    > > Jonathan
    > > www.madlabs.info
    edited 2003-08-31 16:22
    I have had a lot of problems with 6. First, uninstall 5 first, or else
    you will have trouble. Second, many of our PDFs started showing bounding
    boxes around the letters. In fact, one of the things I am doing today is
    redoing all our significant PDF files to correct this and spruce them up
    (most of the PAK manuals are updated as of yesterday; more to come). So
    if you are using 5 and happy with it, I'd say stick with it until 6.1 or
    whatever. Just my opinion.
    Al Williams
    AWC
    * Control 8 servos at once
    http://www.al-williams.com/awce/pak8.htm
    > From: Larry Gaminde [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=DHxQxQMqpNF4QWrG1O67tUHGLJ5ckgnSN8g72EhFYEFlUyrbeKif16vvA9IH-HB4_k1h6D8vACwutg]lgaminde@t...[/url
    > Sent: Sunday, August 31, 2003 10:17 AM
    > Subject: Re: [noparse][[/noparse]basicstamps] Re: OT: Getting images from PDFs
    > reader version 6.0?
    > Larry Gaminde
    > From: "rdenn25" <rad0@a...>
    > > select the diagram or picture, and print it or put it in the clip
    > > board, etc...
    > > This graphic select tool is available in the full version of adobe
    > <jpeakall@m...>
    > > wrote:
    > > > Hi All,
    > > the
    > > have made. I
    > > the
    > > the PDFs? I
    > > original.
    > > documentation
    > > devices.
    > > > Thanks,
    > > > Jonathan
    > > > www.madlabs.info
    > the Subject
    > > and
    edited 2003-08-31 16:28
    I second that I installed 6 and had nothing but trouble, removed it
    reinstalled 5. I thought it was just my machine guess not, but it does have
    some nice features.
    Larry Gaminde
    Sent: August 31, 2003 8:22 AM
    Subject: RE: [noparse][[/noparse]basicstamps] Re: OT: Getting images from PDFs
    > Al Williams
    > AWC
    > > From: Larry Gaminde [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=jovI32h2BPpxnVlK3y4vfbd2gjofHtNFKQqd_XNjcgJvJLsjQTcWCflUG_J04n5efgeDqV2q_PRah_8]lgaminde@t...[/url
    > > reader version 6.0?
    > > Larry Gaminde
    > > > board, etc...
    > > <jpeakall@m...>
    > > > wrote:
    > > > > Hi All,
    > > > the
    > > > have made. I
    > > > the
    > > > the PDFs? I
    > > > original.
    > > > documentation
    > > > devices.
    > > > > Thanks,
    > > > > Jonathan
    > > > > www.madlabs.info
    > > the Subject
    > > > and
    edited 2003-08-31 16:31
    In a message dated 8/31/2003 11:23:56 AM Eastern Standard Time,
    rad0@a... writes:
    The graphic tool is available in the reader versions. Selections may be
    outline, copied, then pasted to a non.pdf document.
    Sid Weaver
    W4EKQ
    Port Richey, FL
    edited 2003-08-31 17:12
    Adobe Acrobat, except for the fact that it can be read by users of
    Macs (about 5% of all users), is inefficient :
    - bloated code
    - bad picture at low resolution
    - slow
    I never understood why it was so promoted by editors.
    Regards
    ECO
    Sent: Sunday, August 31, 2003 5:22 PM
    > Al Williams
    > AWC
    > > From: Larry Gaminde [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=RolBKBHFtw63pRQjjjZ8mcSiNAFSVg-kWp8F6UolnIYrDvD8_Fcb6axY7HG34WgoCWR1CbzbvXH4sGuo90PU]lgaminde@t...[/url
    > > reader version 6.0?
    > > Larry Gaminde
    > > > board, etc...
    > > <jpeakall@m...>
    > > > wrote:
    > > > > Hi All,
    > > > the
    > > > have made. I
    > > > the
    > > > the PDFs? I
    > > > original.
    > > > documentation
    > > > devices.
    > > > > Thanks,
    > > > > Jonathan
    > > > > www.madlabs.info
    > > the Subject
    > > > and
    edited 2003-08-31 17:23
    In a message dated 8/31/2003 8:43:30 AM Pacific Daylight Time,
    alw@a... writes:
    Al Williams
    AWC
    "Bounding boxes"? Could that have something to do with the fact that
    sometimes when I print a pdf, the text is nothing more than just a bunch of
    boxes?
    Never have that problem at work, only at home. I am using adobe 4.0, guess I
    should upgrade.....?
    Ken
    edited 2003-08-31 19:09
    Most Parallax documentation explicitly states that it may be reproduced
    for educational purposes so long as the duplicate documentation is used
    exclusively with genuine Parallax products [noparse][[/noparse]not work-alikes] and there
    is NO CHARGE to students/participants behond the cost of duplication.
    We do, of course, exclude competitors who duplicate the PBASIC language
    (extended or otherwise) for use in their non-Parallax products.
    -- Jon Williams
    -- Dallas Office
    From: Mark Marpet [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=GbL4GXmXmjCAjOxKRZ6hb2jg01C1mweBFJhlnUS0AgLm1QlVx6Va3NyQnM8SviJsHmxWpq_sKi1dhA]marpetm@s...[/url
    Sent: Sunday, August 31, 2003 9:05 AM
    Subject: RE: [noparse][[/noparse]basicstamps] OT: Getting images from PDFs
    >that copies can be made for teaching purposes and under what conditions
    >this is allowed. Other than that, you'd have to contact the publisher
    >of the PDF and ask.
    >to copy without permission.
    >> From: Jonathan Peakall [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=pe2MpWoa_GHyn1jhQHeq0pWOBnIYqjByizuqea54zzDgXed-YyQf6Cq7PG0rtXh3sG0Wyp6txePho64]jpeakall@m...[/url
    >> Hi All,
    >> the process of making documentation for students to use a device I
    >> have made. I want to insert various images from component spec.
    >> sheets. What is the legality of this, and how (if legal) can I get
    >> documentation of the 2p40 layout, and add information like what pins
    >> go to what devices.
    >> Thanks,
    >> Jonathan
    >> www.madlabs.info
    This message has been scanned by WebShield. Please report SPAM to
    abuse@p....
    edited 2003-08-31 19:54
    Hi All,
    Thanks for all of the input. I'll have to get a newer version of Acrobat,
    but I need to anyway. I ended up just re-drawing everything so far, which
    considering my options, was just as fast as anything else.
    Jonathan
    www.madlabs.info
    Sent: Sunday, August 31, 2003 8:28 AM
    have
    > some nice features.
    > Larry Gaminde
    > From: "Al Williams" <alw@a...>
    > > Al Williams
    > > AWC
    > > > From: Larry Gaminde [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=B2O1On144k5l_1oS2lzMcUqHBFmIWUkL7FGQh1H9UrIfjHcImpeFV6o97VnF2Yq7xtEtwe5IqpH6RKPY3Tw]lgaminde@t...[/url
    > > > reader version 6.0?
    > > > Larry Gaminde
    > > > > board, etc...
    > > > <jpeakall@m...>
    > > > > wrote:
    > > > > > Hi All,
    > > > > the
    > > > > have made. I
    > > > > the
    > > > > the PDFs? I
    > > > > original.
    > > > > documentation
    > > > > devices.
    > > > > > Thanks,
    > > > > > Jonathan
    > > > > > www.madlabs.info
    > > > the Subject
    > > > > and
    and
    edited 2003-08-31 21:45
    You could have displayed the image in Acrobat Reader and used a screen
    capture to import it into a graphics program. To get a screen capture, just
    press the "Print Screen" key on your keyboard. Start up your graphic program
    and paste the screen capture into it. Then just trim as needed to get the
    graphic you want.
    Hank
    Sent: Sunday, August 31, 2003 2:54 PM
    > Hi All,
    > Jonathan
    > www.madlabs.info
    edited 2003-09-01 13:58
    In a message dated Sun, 31 Aug 2003 18:12:41, "ECO" <ecourt@b...>
    writes:
    > Adobe Acrobat, except for the fact that it can be read by users of Macs
    > (about 5% of all users), is inefficient:
    > - bloated code
    > - slow
    > Regards
    > ECO
    ECO,
    The "bloated code" in a PDF file can include whatever original fonts are
    needed to make the formatting appear universally accurate and is non-platform
    specific, certainly not just for Macintoshes. I'm not aware of any readily
    available alternative document type that will do this (most definitely NOT
    Microsoft
    Word!).
    The pictures only look 'bad' if they are originally such, or if you set
    Acrobat to save JPEGs or bitmaps to a decidedly lower resolution than original.
    Vector art scales *very* nicely, which is particularly useful for schematics.
    Many print ads and articles are sent to newspaper and magazine publishers in PDF
    format, with very good resolution and relatively small file size (not much
    larger than the JPEGs that it may include). I know this to be true because I use
    Acrobat regularly both for print ads and for in-house schematics.
    I've found its speed is reasonably fast on a reasonably fast computer :-)
    The PDF format is promoted by people who want the end user to be able to see
    exactly what the originator intended. And that's exactly the reason I use it.
    While nothing is perfect, and Adobe Acrobat is not glitch-free, I feel that
    both conceptually and in reality Acrobat is a very useful tool. I applaud its
    widespread adoption, especially for technical publishing. I'm glad Parallax
    makes use of it for their documentation.
    David Reaves
    TransLanTech Sound, LLC
    Creators of the Award-Winning "Ariane Stereo Audio Leveler"
    PS: our "Ariane User Manual" PDF is substantially smaller (724kb) than the MS
    Word file that it comes from (4.4Mb).
    edited 2003-09-01 14:35
    Hank,
    That is what I have been trying. However, the results haven't been so good.
    I just got a free PDF maker, I'll let you know if it is any good.
    Jonathan
    www.madlabs.info
    Sent: Sunday, August 31, 2003 1:45 PM
    just
    program
    > graphic you want.
    > Hank
    > From: "Jonathan Peakall" <jpeakall@m...>
    > > Hi All,
    Acrobat,
    which
    > > Jonathan
    > > www.madlabs.info
    edited 2003-09-01 20:15
    Hello Jonathan.
    You can ask for the images you need in the ParallaxEducators forum
    http://groups.yahoo.com/group/ParallaxEducators/
    (you're already member of that forum) and I can upload the original ones
    in the Files area. That way you can graduate the image quality/download
    time settings for your PDF file.
    We support all the Educators using the BASIC Stamp or any other Parallax
    product in their classrooms, so just ask on that forum and we'll help
    you building the documentation of your Stamp based curriculum.
    Saludos,
    Aristides Alvarez
    International Education Program Developer
    aalvarez@p...
    Parallax, Inc. www.parallax.com
    Rocklin, California
    USA
    From: Jonathan Peakall [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=4WzP_GXBEJmgFk0tFips4dKSWFEXkMzpjMXC5fzida-q0RkIBfbFZCLNFVkFYA8W1sfKaecBBjKc1Lwh]jpeakall@m...[/url
    Sent: Saturday, August 30, 2003 10:46 AM
    Hi All,
    made. I
    PDFs? I
    documentation
    devices.
    Jonathan
    www.madlabs.info
    saying that
    this is
    the PDF and
    > ask.
    allowed to
    If you use the old adage, that copying a copyrighted work is called
    plagiarism, but copying lots and lots is called research...
    if you use something you are unsure of the actual source, show the
    link/reference to where you found it.
    contact every source for permission.
    For lifting graphics from existing pdf files, set your monitor for as
    high a dot pitch as you can, open the pdf file, zoom to get the
    graphic as large as possible and <alt> <prnt scn>, then paste it into
    Irfranview, then crop it.
    Dave
