Newbie problem?
Hi there this is probably a newbie problem. I am trying to interface
my BS2 with a un-modified servo, but can not get it to work. The
servo moves all the way to on end and then stays there. The code I
used was:
Low 12
Loop:
pulsout 12,1000
pause 20
goto Loop.
I have also tried using a loop but to no use. I have also used all
sorts of numbers and even different servos. But I can not get it to
work and am rapidly running out of hair!!!!
Any help would be realy great.
Yours Philip
used was:
Low 12
Loop:
pulsout 12,1000
pause 20
goto Loop.
Yours Philip
1.5mS. However, the PULSOUT is in units of 2uS. So 1000 = 2mS which is
all the way over, so it sounds like it is actually working! If you want
to get it to go 1/2 way, try 750 (1500 uS) instead of 1000.
Good luck!
Al Williams
AWC
* Control 8 servos at once
http://www.al-williams.com/awce/pak8.htm
> From: jazzypip [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=BAYiPGZoNoF4VNdHswXHLvFeVjVBJpJRXARd4uQmb9BM6_nm5nz3a1VVKsrsZel_xNZvJjSkGnc8TjPAPw]jazzypip@v...[/url
> Sent: Tuesday, August 26, 2003 5:35 PM
> Subject: [noparse][[/noparse]basicstamps] Newbie problem?
> used was:
> Low 12
> Loop:
> pulsout 12,1000
> pause 20
> goto Loop.
> Yours Philip
> from the same email address that you subscribed. Text in the
Gave your suggestion a go but it still wont work, the Stamp does
ok with the usual stuff like lighting LED's etc.So the Stamp works
OK any further advise would be great..
--- In basicstamps@yahoogroups.com, "Al Williams" <alw@a...> wrote:
> Most servos need a pulse between 1mS and 2mS. So the center is
nomially
which is
want
> Good luck!
> Al Williams
> AWC
> > From: jazzypip [noparse][[/noparse]mailto:jazzypip@v...]
interface
I
> > used was:
> > Low 12
> > Loop:
> > pulsout 12,1000
> > pause 20
> > goto Loop.
all
to
> > Yours Philip
2) Do you have a common ground between the Stamp and your servo supply?
3) How are the servo's powered?
4) How is the Stamp powered?
Al Williams
AWC
* 8 channels of PWM
http://www.al-williams.com/awce/pak5.htm
> From: jazzypip [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=eLuROCxuH3Y8LxNRRC2gK44YrDF42mUk7iJ19-9lIs58NYcgifFjp5SL78y-_R9IwmSF40vdPNk]jazzypip@v...[/url
> Sent: Thursday, August 28, 2003 6:00 PM
> Subject: [noparse][[/noparse]basicstamps] Re: Newbie problem?
> Thanks for the responce to my problem,
> nomially
> which is
> want
> > Good luck!
> > Al Williams
> > AWC
> > * Control 8 servos at once http://www.al-williams.com/awce/pak8.htm
> interface
> I
> > > used was:
> > > Low 12
> > > Loop:
> > > pulsout 12,1000
> > > pause 20
> > > goto Loop.
> all
> to
> > > Yours Philip
Here are the answers to the questions you asked for...
1) Is this a standard BS2 or a /P, /SX, etc?
It is a Standard BS2
supply?
No Both the Stamp and the Servo's have their power
supply. Should They share a common Ground????
The Servo get's it's power from a mains transformer
providing 6V directly to the Servo.
The Stamp has a 9V battry pluged into my prototyping
board.
The only link between the Stamp and the Servo is the Servo control
wire which goes to normally pin 0 or 1 on the Stamp. And the program
altered to accomadate the Pin number.
Thanks for takeing the time to help with this problem.
Yours Philip
supply?
> Al Williams
> AWC
> * 8 channels of PWM
does
works
> > nomially
> > which is
you
> > want
> > > Good luck!
> > > Al Williams
> > > AWC
> > interface
The
code
> > I
> > > > used was:
> > > > Low 12
> > > > Loop:
> > > > pulsout 12,1000
> > > > pause 20
> > > > goto Loop.
used
> > all
get it
> > to
> > > > Yours Philip
BS2, PULSOUT has a period of 2 microseconds, so your legal range of
values will be 500 to 1000. A PULSOUT value of 750 should center your
servo.
-- Jon Williams
-- Dallas Office
From: jazzypip [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Tf6Yqz8TrkzCwhBVaf4Mb_jY338mVkIxfdjQZgH9irJjqbm1BDoFckAVCA2_hq7N5i_EY24w_uj2j8V9]jazzypip@v...[/url
Sent: Saturday, August 30, 2003 12:00 PM
Hello,
supply?
board.
Yours Philip
supply?
> Al Williams
> AWC
> * 8 channels of PWM
does
works
> > nomially
> > which is
you
> > want
> > > Good luck!
> > > Al Williams
> > > AWC
> > interface
The
code
> > I
> > > > used was:
> > > > Low 12
> > > > Loop:
> > > > pulsout 12,1000
> > > > pause 20
> > > > goto Loop.
used
> > all
get it
> > to
> > > > Yours Philip
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
jazzypip@v... writes:
Hello,
supply?
ABSOLUTELY MUST SHARE SAME GROUND (unless you are using opto isolators, which
I doubt)
Tie the grounds togeter at one point only, preferably at the power supply.
Avoid motor current ground sharing the same traces/wire as stamp and logic
grounds.
board.
Yours Philip
Al Williams
AWC
* NEW: PAK-VIa - Read PS/2 keyboards or mice -- double the buffer, lower
current consumption.
http://www.al-williams.com/awce/pak6.htm
> From: jazzypip [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=katKBoY9cEojZIJC7-i163d6stiAPMmbXLArrMYR3gVAbxCmx52L16levHywDEfau48GoB1ACEf5]jazzypip@v...[/url
> Hello,
> supply?
> board.
> Yours Philip
> supply?
> > Al Williams
> > AWC
> > * 8 channels of PWM http://www.al-williams.com/awce/pak5.htm
> does
> works
> > > nomially
> > > which is
> you
> > > want
> > > > Good luck!
> > > > Al Williams
> > > > AWC
> > > interface
> The
> code
> > > I
> > > > > used was:
> > > > > Low 12
> > > > > Loop:
> > > > > pulsout 12,1000
> > > > > pause 20
> > > > > goto Loop.
> used
> > > all
> get it
> > > to
> > > > > Yours Philip
I would like to thank SMARTDIM, JON WILLIAMS, AL WILLIAMS for
helping me out with this problem. All is well in the world now as I
can control servo's. Once again thanks.
Yours Philip
> Tie the grounds together and you will be pleasantly surprised!
> Al Williams
> AWC
lower
> > Hello,
> > supply?
> > board.
control
program
> > Yours Philip
> > supply?
> > > Al Williams
> > > AWC
Stamp
> > does
> > works
center is
> > > > nomially
2mS
> > > > which is
working! If
> > you
> > > > want
> > > > > Good luck!
> > > > > Al Williams
> > > > > AWC
to
> > > > interface
work.
> > The
The
> > code
> > > > I
> > > > > > used was:
> > > > > > Low 12
> > > > > > Loop:
> > > > > > pulsout 12,1000
> > > > > > pause 20
> > > > > > goto Loop.
> > used
> > > > all
> > get it
> > > > to
> > > > > > Yours Philip
in the
