Opinions on High Frequency data capture for miniature dyno. — Parallax Forums
edited 2003-09-21 21:20 in General Discussion
I have been researching what would be needed to accurately capture
the RPM's of a flywheel and timing each rotation down to microseconds.
The flywheel would rotate up to a maximum of about 12000 rpm or about
200 revs per second. I need to time each rotation to capture the
acceleration and speed at intervals to calculate the horspower and
torque.
I am looking into using a hall sensor or an optical encoder to
capture each rotation of the flywheel and am also looking at a BASIC
stamp to coordinate the timing and marshalling of data to a PC for
graphing, printing, and analysis. There have been a number of
messages in here for accurate timing but I'm not sure of what would
be the right way to go about this project.
Ultimately I would like to have PC software that would provide a
countdown to the operator of the dyno and when signal goes 'green'
the engine is revved up as the datalogging captures the RPM's and
acceleration under a known load and gear ratio etc. Each revolution
would be timed in subsecond units (resolution greater than 200 per
second) and sent down an RS232 serial port to the PC.
The questions I have are:
1. Would an optical encoder capture and pulse quick and accuratly
enough or would a hall sensor be better for this?
2. What would be able to take the pulses from the sensor and the
elapsed time between each revolution and store/send it down a serial
link to the PC for analysis and computation of Horspower,torque,
acceleration?
One more piece of information...I am just learning about BASIC stamps
and electonics, circuits etc. My background is in software
development in the corporate world and not so much at lower hardware
levels. I have done serial comm though.
By all means if someone out there already has a package that can do
this type of thing at the accuracy level I 'think' I need then that
would be great. I still would want to learn how anyway.
Thanks for any advice one can give.
Darren Ford
    edited 2003-08-25 16:04
    Darren,
    I used to work at a place that built test systems (including dynos) for
    electric motors. Here is how we did it.
    We used a quality quadrature encoder that cost in the neighborhood of
    $600-1000. It was interfaced directly to a PIC that sampled on the AC
    zero crossings, 60 hz.
    Data was xmitted serially at 115,200 baud to a VB/VC++ app on a PC.
    Sampling at 60 hz required that the data be sent real-time and not stored
    in the PIC.
    For encoders, you might wish to check out automationdirect.com -- never
    used their brand, but they look promising. (and inexpensive compared to
    what we used)
    I really question if a Stamp will be fast enough to do what you need.
    Especially if you try to read the encoders directly with no external
    circuitry or interface chip. There are some nifty interface chips
    available to read quadrature encoders; try googling for them.
    amg
    On Mon, 25 Aug 2003 03:48:18 -0000 "darylmer" <darylmer@y...>
    writes:
    > microseconds.
    > about
    > torque.
    > acceleration?
    > stamps
    > Darren Ford
    ________________________________________________________________
    The best thing to hit the internet in years - Juno SpeedBand!
    Surf the web up to FIVE TIMES FASTER!
    Only $14.95/ month - visit www.juno.com to sign up today!
    edited 2003-08-25 22:33
    Try US Digital for encoders and IC's that can do the sampling for
    you. Stamp may be too slow to get the data you need. Maybe the BS2p40
    but even with that you only going to get maybe 30 to 40 samples a
    second depending how efficient your code is and how much pre
    processing you need.
    Jason
    --- In basicstamps@yahoogroups.com, amg amg <controlsdude2000@j...>
    wrote:
    > Darren,
    for
    of
    AC
    stored
    > in the PIC.
    never
    compared to
    > what we used)
    need.
    > Regards,
    > amg
    > writes:
    capture
    > > microseconds.
    > > about
    and
    > > torque.
    BASIC
    for
    would
    goes 'green'
    revolution
    per
    accuratly
    serial
    > > acceleration?
    > > stamps
    hardware
    do
    that
    > > Darren Ford
    edited 2003-08-26 22:59
    I had thought about a similar use for tachometer or anemometer using an IR
    emitter/detector pair and a disk with X equally spaced holes. (X pulses per rev)
    Even if you have 100 pulses/rev at 200 rev/sec that's only 20,000 Hz. Seems the
    BS2p should be able to handle that using the Count command with the Period using
    fraction of a second with the remaining fraction available for computation.
    Being I am new at this, any holes in this logic other than that the error will
    be dependant on how fast the disk accelerates? To me this seems easier than
    timing a pulse as you don't have to wait, you're just taking a sample.
    edited 2003-09-19 18:43
    I read through this thread, hoping it would answer questions I have
    regarding a similar appplication. I am hoping to implement a dyno
    that I can install on a motorcycle. The dyno simply consists of a
    gear tooth speed sensor (Cherry part #GS101202 or similar) that
    watches the rear sprocket of the motorcycle. If I know the number of
    teeth on the sprocket, the circumference of the rear tire, and the
    weight of the rider and bike, I can calculate the rear wheel RPM,
    Torque, and therefore horsepower. This is a little better than the
    original application because the rates are much more reasonable. For
    instance, at 100mph wou would only see about 1000 Hz on the gear
    tooth counter. Of course I could only do this in one gear, but that
    shoudln;t be an issue for now.
    I was planning on using PULSIN or COUNT to do the actual speed
    sensing. Using either method, each result is stored and made
    available to download later and play with on Excel or a similar
    spreadsheet application.
    Here are my questions:
    How can I keep track of time so that I know when the counts are
    done? If I use COUNT, for instance, the code would simply loop thru
    a count and a write command. I would know exactly how long the COUNT
    period would be, but can I count on WRITE taking eactly one clock
    tick? If not, how will I know how long it was from one COUNT period
    to the next when the program loops?
    Is there a better way than using EEPROM space to store this? I get
    approximately 100,000 writes on my BS2sx. While I sincerely doubt I
    would ever do 100,000 runs, I would rather not wear out the EEPROM.
    If I used a seperate EEPROM and communicated to it with SPI or I2C,
    can I count on the same speed of execution for the write command?
    I would want the data storage to start on a BUTTON, which is simple.
    Should I simply have it end when the EEPROM space for that section of
    the program is full, or is there a better way of implementing this
    such that it only takes up a fixed amount of memory space?
    Kevin
    microseconds.
    about
    > torque.
    BASIC
    revolution
    serial
    > acceleration?
    stamps
    hardware
    > Darren Ford
    edited 2003-09-19 20:15
    External SRAM? With the address generated by an external counter and
    clocked by the Stamp you'd use a couple pins, plus the pins needed for
    the data, and a serial to parallel latch. Or if you've got the pins a
    byte-wide bus.
    edited 2003-09-19 23:18
    Just curious - Why does it matter what gear you're in?
    Jack
    > ... Of course I could only do this in one gear, but that
    edited 2003-09-20 00:47
    Forgive me, Kevin, but I do not see how you can calculate torque "the
    number of
    weight of the rider and bike." Can you tell me how you intend to do
    this?
    > Thanks
    > Kevin
    > microseconds.
    > about
    >> torque.
    > BASIC
    > revolution
    > serial
    >> acceleration?
    > stamps
    > hardware
    >> Darren Ford
    > from the same email address that you subscribed. Text in the Subject
    > and Body of the message will be ignored.
    edited 2003-09-20 03:20
    What's not covered so far is accounting for aerodynamic acceleration.
    With the setup he's talking about one could prepare an acceleration
    table for a standard set of conditions by accelerating to a given speed,
    shifting into neutral, and measuring the interval required to slow by
    some convenient increment. Repeating this over a range of speeds would
    allow a good approximation of the negative acceleration at a given
    speed.
    Mark Marpet wrote:
    > ... I do not see how you can calculate torque "the
    > number of
    > this?
    edited 2003-09-20 03:40
    Every dynamometer that I am aware of, from those that measure the
    horsepower of a car engine to those fit to bicycle hubs, MEASURE the
    torque; the car dynos do it using a force gage through a lever arm, the
    bike dynos using a force gage inside the rear hub. What I'm asking is
    how do you intend to get that torque. If you measure the traction
    reaction force (NOT the ground reaction force, i.e., the weight, but
    the force parallel to the ground), you could get what you want, but the
    weight of the rider and bike, I don't think, would do it, as the
    rear-wheel GRF passes through the centerline of the rear hub, so you
    can't get the rear-wheel torque from that.
    On the other hand, I could be missing something?
    > speed,
    > speed.
    >> number of
    >> this?
    edited 2003-09-20 07:13
    Hello,
    The easiest way to get SRAM for a stamp is the Rampack B from
    http://www.solutions-cubed.com/
    I have messed around with Stamp - SRAM and you can make a shift register
    interface that uses 4 or 5 stamp pins and is faster than the Rampack in
    byte sized operations (the Rampack is faster if you can read/write in
    blocks). If you have a BS2p then you can use I2C which will require 4
    stamp pins (2 for I2C, 2 for SRAM). The I2C method is a little slower though.
    The shift register interface uses 7 chips (not including the SRAM). I
    tried a circuit with a counter for the address, but it quickly got too big
    to be useful. The I2C circuit only uses 2-3 chips.
    Of course all of these options will be much slower than writing to the
    stamps own EEPROM.
    Chuck Chargin Jr.
    >byte-wide bus.
    >from the same email address that you subscribed. Text in the Subject and
    >Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
    edited 2003-09-20 07:15
    > torque...
    Sure. It's often the easiest thing to measure. However if you know
    mass, acceleration, velocity, and RPM, power and torque are derived
    directly, as follows:
    Force = Mass X Acceleration - Mass in lbs, Acceleration in g
    Hp = Force X Velocity / 550 - Velocity in fps, Force in ft-lbs
    Torque = 5252 X Hp / RPM
    It's easy to get wrapped around the axle in these calculations
    by mixing units, AKA "dimensions". For instance if you choose to
    use acceleration stated in fps/sec instead of "g" units then the
    appropriate mass unit is the slug, not the pound. Bear in mind
    that total acceleration must include the negative acceleration
    produced by friction, drag, grade, and so on.
    Anyway, I'm curious to hear about our colleague's approach.
    edited 2003-09-20 17:18
    I think that you and I are on the same page. You can certainly estimate
    friction drag and tire losses--separately or together--with coasting
    experiments using an accelerometer on various KNOWN downgrades, and you
    can, after figuring out ground losses, estimate aero losses via
    different speed experiments on a single grade. You can then factor all
    of that in to accelerometer-derived measurements. But, ultimately, I
    think it's easier AND more accurate to build a strain-gage into a
    torque-arm link (think of the torque arm on the old sturmy-archer
    three-speed "english-racers" (an oxymoron if ever there was one) of the
    1950s. A/D the strain gage and you are home free.
    >> torque...
    edited 2003-09-20 21:30
    Mark Marpet wrote:
    > I think it's easier AND more accurate to build a
    > strain-gage into a torque-arm link ...
    Certainly for my app it would be - I'm interested
    in measuring rider effort real-time - If I could
    get around building a custom derailleur with a torque
    link. Of course a Rohloff 14-speed gearbox would solve
    that problem, would'nt it!
    edited 2003-09-21 02:38
    Yes and no. The 14-speed gearbox seems really cool (I never heard of
    the Rohloff and had to Google it) but IT doesn't seem to be able to
    measure torque. On the other hand, if you're flush enough for that
    gearbox, you're should consider the Cycleops Powertap power-measuring
    rear hub.
    www.nashbar.com Stock number AG-7005 $799.99 each
    Of course, the strain gage would do the same thing.
    edited 2003-09-21 05:01
    > measure torque.
    It does'nt measure torque, but there is a torque arm so a transducer
    could be grafted on - Not much chance of that at the moment...
    Jack
    Well, to measure the output torque (T) of the rear wheel, I can
    measure the radius (r) from the circumference of the wheel.
    From there it is simply T=r x F. So now I need to solve for F. For
    that I simply need F=ma. m is the mass of the bike and rider. I
    have that. a is the acceleration of the bike. I get that from the
    rate of change of frequency of the gear tooth counter. Horsepower
    is simply torque at a given rpm, so from the gear tooth counter I
    get rate and rate of change of the rear wheel RPM.
    Now, like someone else pointed out, using this method is rife with
    errors. The first is that all of the force output by the rear wheel
    is not going into accelerating the bike. It pushes a lot of air,
    and that should be accounted for. As someone else pointed out, a
    simple coast down will account for that loss.
    Second, changes in air temperature, pressure, etc also influence the
    results. In a campaign of taking dyno measurements I would be
    trying to compare one modification on the bike to another, so the
    time seperating the two would be minimized. Also, measuring air
    temp, pressure, etc would help to minimize this. Along the same
    lines, wearing the same clothes, keeping the gas tank level the
    same, not going on a diet or gaining weight, doing two way runs on
    largely level ground, etc. will help keep the results stable.
    Third, someone asked about why I have to keep it in one gear. The
    answer is you don't. It could be done in any gear. I just meant
    that if I was going to set up a spreadsheet to back calculate all of
    this, I would want to keep it simple and use only one gear.
    Further, you would want to do rolling starts so clutch slip was not
    involved. You'd want to use a relatively high gear so that the COUNT
    function didn't have a large % error, etc.
    I think I got my real answer though. Use EEPROM on the chip and
    simply deal with the fact that the Stamp will wear out after 100,000
    dyno runs. I plan on being old and grey before that happens....
    Kevin
    torque "the
    > number of
    do
    > this?
