120V Contact Relay Connections
How can I Connect a 120V Contact Relay (5V-12V coil) to an output of
the stamp?? Anyone have any schematics of this ??
1K ohm resistor
+ 5 volts
Connect the other side of the relay coil to + 5 volts (or +12 volts if
using a 12 volt coil). Driving the stamp ouput pin HIGH causes the
ULN2003 output to go LOW, grounding the coil circuit and activating the
coil.
The ULN2003 has 7 Darlington transistor drivers, so you have 6 left over
for other purposes.
Dennis
From: Brian E Boothe [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=2QjamJkyX2LP-OYiKfsf8jRuiU7Ei-AOnWMbvcK-ewa2xWkHfxRUhAdHmawm50z4C2wANcNPdI50y0w]subrian@m...[/url
Sent: Friday, August 22, 2003 10:02 AM
Subject: [noparse][[/noparse]basicstamps] 120V Contact Relay Connections
Your use of Yahoo! Groups is subject to
jim
http://www.geocities.com/jimforkin2003/
From: Brian E Boothe [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=59npt3R1sr8VLftQgZHpgUD7aAqS0JlF4XL61IqtvJJwT4ljMJrZ0M96ynTwsxy1a7nvor2k5wRyrwOw]subrian@m...[/url
Sent: Friday, August 22, 2003 1:02 PM
