Current limt resistor for reset?
Hi All,
I have looked around, and havent seen anyone using a current limit resistor
on the reset button. This project will be used by students. I just want to
make sure I shouldn't put one here to protect against students holding down
the reset button too long.
Many thanks,
Jonathan
www.madlabs.info
Many thanks,
Jonathan
www.madlabs.info
jpeakall@m... writes:
Many thanks,
Jonathan
www.madlabs.info
I think Jon Williams has been recommending 220 ohms
You need current limiting resistors on pins that
could be outputs -- could try to drive ground to
+5, or could try to suck +5 to Ground. This never
happens on an input pin.
> In a message dated 8/22/2003 9:55:44 AM Pacific Daylight Time,
resistor
want to
holding down
> Many thanks,
> Jonathan
> www.madlabs.info
