victor 883 motor driver PWM signal problems — Parallax Forums
edited 2003-08-23 13:21 in General Discussion
I have three victor 883 motor drivers from IFI. Two used to work
with my pak-VIII (they received the PWM signal and acted
accordingly). One, right out of the box, sometimes shows that it's
receiving a signal either right when I power up the stamp which is
controlling the pak (and giving the pak power from it's 5V output),
or when I activate the appropriate pak channel (which corresponds
with the victor). But Once I start actually sending pwm to this
victor, it stops receiving any signal.
Recently, another one of my three victors started acting exactly
the same. I sent both in for repairs and the guy sent them both back
saying that they were acting fine when he tested them... I have a
feeling it has to do with the power of the signal coming from the
pak. Anyone else have a similar problem and was able to fix it? The
people at IFI aren't very helpful. They just tell you that it's
working whether it's working with my system or not. Thanks
    edited 2003-08-22 15:09
    I'm going to take a guess. Problems like this usually work out to two
    different things. First, check to make sure you have common grounds
    everywhere and preferably tied back to one common location (a "star"
    ground). Second, decoupling capacitors. With motors you need a big
    capacitor across the supply to smooth out the brown outs. In addition,
    consider putting a .1uF and a .001 uF near the PAK (between Vdd and
    Vss). On paper, it looks like that just creates a .101uF capacitor, but
    in real life it provides different pathways for different frequency
    noise.
    You might also want to put capacitors near the motor's power leads (not
    the PWM leads).
    That's just a guess....
    Al Williams
    AWC
    * 8 channels of PWM
    http://www.al-williams.com/awce/pak5.htm
    > From: Sam [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=8QgQ50SnVQkNyu_rFMLhTYHuoRxromzW7DtvVe6NuxUgvwhjnG2-_TTUcVMyed3Fh3NSW5uJtIykGA]hard-on@t...[/url
    > Sent: Friday, August 22, 2003 8:15 AM
    > Subject: [noparse][[/noparse]basicstamps] victor 883 motor driver PWM signal problems
    > from the same email address that you subscribed. Text in the
    edited 2003-08-22 17:31
    I have a couple Victor's and have not had any problems with them, but I have
    never used a Stamp to drive them though. I use dedicated used to drive
    them. The IFI people do say from time to time in their documents, that some
    microcontrollers don't supply enough current to the Victor's to drive them
    properly. This is why they sell a signal booster. I don't know if this is
    the problem.
    If I remember right, the Victor's PWM input signals are optically isolated
    from the H-Bridge drive circuits, so you don't need to use a common ground.
    Pete Miles
    Sent: Friday, August 22, 2003 6:15 AM
    edited 2003-08-23 01:44
    This message mainly for Al Williams,
    Al,
    Would that PAK5 servo copressor be able to update 6 servos in real time? What
    would be the refresh rate? Do you have a RF link that will connect the two(a
    BS2 & PAK 5)?
    thanks,
    Leroy
    N8VRC
    BTW thinking of using it to Fly my Helicopter, but don't like the radios
    available, thinking of making my own.
    Hi Leroy,
    Actually, I think you would want a PAK-VIII to control servos. The PAK-V
    puts out PWM best-suited for controlling a light or a DC motor. The
    PAK-VIII can do PWM but it can also output fixed time slices that you
    want when controlling servos.
    As for an RF link, I don't have any knowledge of that. However, the
    protocol is simple enough (see http://www.al-williams.com/pakif.htm). I
    would imagine any of the cheap RF transmitter/receiver pairs could be
    made to do this. If you wanted RS232, the trick would be to have the
    processor on board and then talk to the processor.
    Good luck!
    Al Williams
    AWC
    * Control 8 servos at once
    http://www.al-williams.com/awce/pak8.htm
    > From: Leroy Hall [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=hGO_D1Dm6BI8QQrP8L0fpme0_m7lUUy8J_IfaJ-76XbYXD4EYo715GH5MWqhvflr5XPSrkUp7zo]leroy@f...[/url
    > Sent: Friday, August 22, 2003 7:44 PM
    > Subject: Re: [noparse][[/noparse]basicstamps] victor 883 motor driver PWM signal problems
    > Al,
    > real time? What would be the refresh rate? Do you have a RF
    > link that will connect the two(a BS2 & PAK 5)?
    > thanks,
    > Leroy
    > N8VRC
    > the radios available, thinking of making my own.
