Torque meter idea needed
Does anyone have a simple way to measure the amount of torque needed to
turn an object. In this case the takeup reel on a camera.
I'm working on a project that will use a BS2 to spin two steppers, but I
need to know how much torque is needed.
David
David
David@C... writes:
I mechanical tool called a torque wrench is available. I don't know what
ranges the come in. Another do-it yourself way is to attach an 1-inch arm to
the
shaft of the reel. At the end of the 1-inch shaft suspend a weight beginning
with about 1 ounce, and see how much weight it take to start turning the
reel. The point at which it starts to trun is the "holding torque".
If you can determine the oz/inch torque, you can convert it to gms/cm, which
is the way most steppers are labeled.
Sid Weaver
W4EKQ
Port Richey, FL
David@C... writes:
David
David,
You use a "beam" type torque wrench. the link shown is overkill but you will
get the idea.
http://www.epinions.com/hmgd-Shop_Tools-All-Craftsman_Beam_Torque_Wrench_44642
Or, you can device your own.....
If an arm that is 1 foot long is connected to the center of the rotating
device, and at the end of the arm is a 1 pound weight, and the device will just
start to turn, then you have 1 foot pound. This would be with the arm's starting
position parallel to the ground. Any other position would require a cosine
factor to be involved....you can probably get a rough idea using a 6 inch arm
and some fishing weights...as in....
....there are derivatives to this, as in inch/ounces. That is an arm so many
inches long with so many ounces on the end of it.....
writes:
the
Sid Weaver
W4EKQ
Port Richey, FL
YEP!!!
needed to
but I
> David
Hi David,
Stepper motors are rated in ounce/inches.
the idea of a lever with weight is a simple method, just use one inch
and not one foot.
and the arm must be level to the earth, not on an angle.
hang a cup and drop water in the cup until you get movement.
weight the cup. postal scale ?
re-test with weights.
also, if you expect to use some type of gearing or screws or
something, allow for friction losses. I would considder 4 times you
weight as good as gearing could have 70% losses due to friction, and
at 4 times, you should be way under powered for causing damage.
Dave
pots resistance. Use a spring or rubber band to counteract the torque needed
to pull the arm down.
0 ohms would be contracted spring. When the torque moves the arm lower, a
higher resistance would be a higher ohm reading. The spring of course than
pulls the arm back to zero with a lower torque.
-kerry
At 06:32 PM 8/21/03 -0000, you wrote:
>needed to
>but I
>> David
>Hi David,
>and not one foot.
>Dave
>from the same email address that you subscribed. Text in the Subject and
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
Very respectfully, your obedient servant.
Brig. Gen. Johnston Pettigrew
Admin@M...
WWW server hosting [url=Http://mntnweb.com]Http://mntnweb.com[/url]
Kerry Barlow
p.o. box 21
kirkwood ny
13795
607-775-1575
