PULSIN & DEBUGIN Conflict — Parallax Forums
edited 2003-08-21 08:20 in General Discussion
Board: BS2
PBasic: v2.5
I am having this problem having PULSIN & DEBUGIN in the same loop.
DEBUGIN kind of dominates over PULSIN. Here is my code:
counts VAR Words
pulse VAR Words
stpkey VAR Byte
pulse = 0
DO
start:
PULSIN 0,1, counts
IF counts = 0 THEN start
pulse = pulse + 1
DEBUG DEC pulse, CR
DEBUGIN stpkey
LOOP UNTIL stpkey = "0"
It won't even DEBUG. If I disable DEBUGIN, PULSIN works and also DEBUG
- Johari
    edited 2003-08-20 13:16
    At 11:46 AM 8/20/03 +0000, Johari Aziz wrote:
    >Board: BS2
    >PBasic: v2.5
    >counts VAR Words
    >pulse VAR Words
    >stpkey VAR Byte
    >pulse = 0
    >DO
    >start:
    >PULSIN 0,1, counts
    >pulse = pulse + 1
    >DEBUG DEC pulse, CR
    >DEBUGIN stpkey
    >- Johari
    Johari -
    Are you sure you wanted to use Pulsin, or did you mean to use Count ?
    Count determines the NUMBER of transitions, and Pulsin determines the time
    frame.
    Bruce Bates
    edited 2003-08-20 18:06
    I am using to count the rotation encoder disc of a motor. The time
    frame is indefinite that means I want stop the motor at anytime I
    choose and record the turns of the encoder. That's why I chose PULSIN
    and not COUNT. I use COUNT for definite timing like a tachometer. Like
    the following:
    start:
    COUNT 0, 1000, counts
    RPM = counts + 6
    DEBUG "RPM = ", DEC RPM,CR
    GOTO start
    I also use IN0 but still the DEBUGIN overides the INPUT. I think it
    just sitting there waiting for me to type something on the keyboard
    before moving on to the next step.
    - Johari
    > >Board: BS2
    > >PBasic: v2.5
    > >counts VAR Words
    > >pulse VAR Words
    > >stpkey VAR Byte
    > >pulse = 0
    > >DO
    > >start:
    > >PULSIN 0,1, counts
    > >pulse = pulse + 1
    > >DEBUG DEC pulse, CR
    > >DEBUGIN stpkey
    > >- Johari
    > Johari -
    the time
    > frame.
    > Bruce Bates
    edited 2003-08-20 19:09
    >The time frame is indefinite that means I want stop the motor at anytime I
    >- Johari
    Yes, that is the way debugin works. It waits for input. The stamp
    does not have a serial input buffer, so it cannot receive other
    characters and queue them up wile doing other things.
    -- One possible workaround is to use an external chip that does have
    a serial buffer. There are several of them available.
    -- Or a different workaround: Put a switch on another stamp input
    pin that will allow you to break into the counting process. The
    input to that extra pin could even come from the serial line, from
    either tx (BREAK) or dtr.
    -- regards,
    Tracy
    I'm trying out SERIN because it has a timeout. The objective is to
    have an alternate inputting in that loop. I'm getting there. It seems
    PULSIN is working because it display on DEBUG and also the ASCII
    character that I press. But that IF statement still don't work. That
    is if I press character "0" I want it to break the loop and jump to a
    label. Do you have any suggestion to make SERIN works better?
    anytime I
    > >- Johari
    > -- regards,
    > Tracy
